L series Buildup
Mr.INSANE
I run a 12-1 91 octane 3.1 liter stroker, with FULL 36 deg timing, which is all in by 2000 RPM, with no detonation. Many said I wouldnt be able to do it, but its been running that way for almost three years now. I run a HIGHLY modified P90, but I didnt modify the combustion chamber, other than shaving it .1". QUENCH is the key, and you need NO MORE THAN .025" clearence from piston to head to make that quench efficiant. If your using a 2mm head gasket, you might as well just use a N42, open chamber design, as they will both have the same quench charecteristics at that wide of a Piston to head clearence. My next NA motor will be 13-1 pump gas engine, with water/meth injection.
