Awsome fix for your stock differential mount. PICS!
proxlamus©
Just a thought on a cheap, strong replacement for the orginal belt/limiter.
I have used old SERPENTINE belts to make repairs on many items. I have never seen one break.....ever!
Seems to me you could cut to length, and either bolt or clamp the joint.
Might be worth a shot.
Just imagine a couple inch long, inch wide strap of metal like you'd buy at the hardware store. These straps are welded to the front and back of the diff mount and hang below the cross member. At the bottom they have a hole drilled in them, and there is a bolt connecting the front to rear. The bolt is below the crossmember, so when the diff pulls up the bolt hits the crossmember. Put a piece of hose over the bolt if you want less vibration.
SleeperZ..
your still alive out there!! havent seen ya in years!
Yes, and it's been almost two years since I've fired up the Z. I'd like to get it going this spring and take a spin around High Plains. I'm contemplating building a MegaSquirt so I can get the revs out of this cam....
