mrpratt Posted July 19, 2007 Share Posted July 19, 2007 Just picked up my 75 rhd 280Z, and the tachometer doesn't work. The previous owner said he thinks its just something is disconnected. Any common problems with this? thanks in advance Quote Link to comment Share on other sites More sharing options...
ihavearustedz Posted July 19, 2007 Share Posted July 19, 2007 theres a big plug/cable behind the tach. check if its there by looking in the engine bay coming out to the tranny, mines orange not sure if all are ill try and get a picture,i used a picture i found on here ( hope noone minds) , you can see the cable hanging into the tunnel coming from under the brake booster, it has that orange sheild around it Quote Link to comment Share on other sites More sharing options...
mrpratt Posted July 20, 2007 Author Share Posted July 20, 2007 thanks man that is good info, i will check that out when i get the chance Quote Link to comment Share on other sites More sharing options...
Warren Posted July 20, 2007 Share Posted July 20, 2007 Orange sheathed cable going to the tranny should be the Speedometer cable, not the tach cable. Quote Link to comment Share on other sites More sharing options...
ihavearustedz Posted July 20, 2007 Share Posted July 20, 2007 whoops, my fault. got them mixed up i feel dumb Quote Link to comment Share on other sites More sharing options...
m1ghtymaxXx Posted July 21, 2007 Share Posted July 21, 2007 Dunno about z's, but on 280zx's its fused. Same fuse does the oil pressure guage, and 1/4 tank fuel guage Quote Link to comment Share on other sites More sharing options...
mrpratt Posted July 21, 2007 Author Share Posted July 21, 2007 m1ghtymaxXx said: Dunno about z's, but on 280zx's its fused. Same fuse does the oil pressure guage, and 1/4 tank fuel guage well, i took the whole dash apart and everything is still hooked up, so its not that. I will check the fuses and see if that is it. I hope so. I will search and see if I can find a diagram of the fuses on here since I don't have an owners manual (if it would be in there?) Quote Link to comment Share on other sites More sharing options...
m1ghtymaxXx Posted July 21, 2007 Share Posted July 21, 2007 mrpratt said: well, i took the whole dash apart and everything is still hooked up, so its not that. I will check the fuses and see if that is it. I hope so. I will search and see if I can find a diagram of the fuses on here since I don't have an owners manual (if it would be in there?) it doesnt have a diagram on the fuse panel cover? Otherwise just go through all your fuses a change whichever are burned out. Wouldn't take too long Quote Link to comment Share on other sites More sharing options...
mrpratt Posted July 22, 2007 Author Share Posted July 22, 2007 lol... there is a diagram, but it is in japanese, since the car is actual JDM I can't believe I didn't anticpate that. Oh well, I will just have to get in there and see what fuses are blown. Is there even a tachometer fuse for sure? Quote Link to comment Share on other sites More sharing options...
deja Posted July 25, 2007 Share Posted July 25, 2007 mrpratt said: lol... there is a diagram, but it is in japanese, since the car is actual JDM I can't believe I didn't anticpate that. Oh well, I will just have to get in there and see what fuses are blown. Is there even a tachometer fuse for sure? try these http://www.atlanticz.ca/zclub/techtips/explodedviews/280z/77fsm/fuses%20&%20relays.gif This is from a 77 280z shop manual. That resistor in the above link can get loose. It might be bundled under some tape and can be hard to locate. Quote Link to comment Share on other sites More sharing options...
