NZeder Posted April 1, 2008 Share Posted April 1, 2008 Hi Octane Racing do the Ross Full Metal Jacket RB balancers for under $500 AUD see http://hioctaneracing.com.au/eshop/index.php?manufacturers_id=52 Quote Link to comment Share on other sites More sharing options...
strokerzedd Posted April 2, 2008 Share Posted April 2, 2008 I just ordered the high hp ATI from Summit Racing http://store.summitracing.com/partdetail.asp?autofilter=1&part=ATI%2D917752&N=700+115&autoview=sku for $489 plus shipping ( which has got to be cheaper than Australia to Canada) plus it comes with the larger water pump pulley. Almost have all my parts together, motor is being built and the fuel cell/surge tank is almost complete. Quote Link to comment Share on other sites More sharing options...
Careless Posted April 2, 2008 Author Share Posted April 2, 2008 Anyone know which one goes on an RB30? Or do they make one for the RB30 separately, as the R32 and R33 are even different part numbers (probably has to do with the crank snout). Quote Link to comment Share on other sites More sharing options...
NZeder Posted April 2, 2008 Share Posted April 2, 2008 Anyone know which one goes on an RB30? Or do they make one for the RB30 separately, as the R32 and R33 are even different part numbers (probably has to do with the crank snout). I think you will find it is not the crank snout but the acc pulley on the front has a different offset. I am lead to believe that the R32 has the different offset for the 3rd pulley but R33/R34 are the same. I see that Ross has different part numbers for RB20, RB25, RB26 (R32), RB26 (R33), RB26 (R34) and the RB30. If I am going to get one I am thinking I will get the Ross unit for the following reasons. 1. Well made product 2. Locally made (well sort of just over the Tasman sea) 3. They have a listing for the RB30 4. The front (3rd) pulley is a bolt on and I don't want or need it Quote Link to comment Share on other sites More sharing options...
Chris Duncan Posted July 8, 2015 Share Posted July 8, 2015 (edited) Know this is an old thread but posting updated info The GTR-Z is back on the front burner and I was trying to lighten the stock balancer by cutting off the front P/S pulley. I succeeded in cutting off the pulley but right at the end of the cut it started acting funny on the lathe and the center mount part came loose from the main part of the balancer. Apparently the way it's built the front pulley connects the main body to the mount bore so the pulley is now scrap metal. So shopping for a new balancer Stock R32 rb26 balancer. 13 lbs, 10 oz. Avg Ebay price $300 Unless it's a newly manufactured part the rubber ring that connects the hub to the outer ring is about 25 years old. This rubber will deteriorate and the balancer will separate. Have had this happen on a '75 280Z. Stock balancers can also be rebuilt with a new rubber ring. It's a specialty service and one guy that does it is located in Oregon. http://www.hbrepair.com/ He charges $115 plus shipping. Fluidamper 11 lbs. best Ebay price $365 R32 610901 R33/34 610911 the only difference is a small amount of offset to the pulleys This is a really nice steel balancer that uses liquid as the balancing medium thus it never needs rebuilding and it self adjusts to the engine build/tune. The outer P/S pulley is removable. ATI Super Damper 7 lbs. best Ebay price $400 An aluminum and steel damper. Uses a set of o-rings to dampen. Is rebuildable and can be tuned with different o-rings. Believe the outer P/S pulley is removable but have not confirmed. there's other balancers available (USA) but the prices are higher Edited July 8, 2015 by Chris Duncan Quote Link to comment Share on other sites More sharing options...
Chris Duncan Posted July 15, 2015 Share Posted July 15, 2015 ATI Super Damper 7 lbs. best Ebay price $400 An aluminum and steel damper. Uses a set of o-rings to dampen. Is rebuildable and can be tuned with different o-rings. Believe the outer P/S pulley is removable but have not confirmed. ATI Super Damper just arrived. The P/S pulley is removable and it weighs 5 lbs. 7 oz. without it. So 8 lbs. 3 oz. of weight off the front of the car and off the rotating weight. Quote Link to comment Share on other sites More sharing options...
