Mike Mileski Posted August 22, 2007 Share Posted August 22, 2007 Here is my latest iteration of a front arm that does not require the TC rod to be disconnected in order to adjust it. The custom piece is a three inch length of 1.125" OD tubing with a .220" wall thickness. This allows it to be threaded for the metric threads of the tie rod on one end (1.625" deep) and the 3/4-16 LH threads for the double adjuster on the other end (1.375" deep). The threaded end of the tie rod needs to be shortened 1/2" but then it can be threaded all the way in and locked with the jam nut. It doesn't require any future adjustments. All of the length adjustments can now be accomplished by using the double adjuster. I plan to install this on my car, adjust it to my specs and then possibly make a slightly longer version, if necessary, to ensure that all of the threaded portions are almost completely threaded in for utmost strength. Let me know your thoughts. Mike Mileski Tucson, AZ Quote Link to comment Share on other sites More sharing options...
OlderThanMe Posted August 22, 2007 Share Posted August 22, 2007 Incredible work! The TIG welds are incredible!! Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted August 22, 2007 Share Posted August 22, 2007 Gimmie gimmie..... I 'll take two! Quote Link to comment Share on other sites More sharing options...
buZy Posted August 24, 2007 Share Posted August 24, 2007 Nice Work Mike!!!!!!! Quote Link to comment Share on other sites More sharing options...
johnc Posted August 24, 2007 Share Posted August 24, 2007 Looks like a nice part. Quote Link to comment Share on other sites More sharing options...
MONZTER Posted August 25, 2007 Share Posted August 25, 2007 When the car is on a jack and the front struts are fully extended, are you worried about the tie rod/ball joint binding? It looks like the center of the joint is perpendicular to the centerline of the arm. I wonder if the joint has as much rotation as the stock ball joint. Hopefully it's all good. Looks real nice, and easy to adjust. I had to put a small bend in the front tube on mine so that the heim joint was in the middle of its range at ride height. This made it so no binding under full extension or compression. You can see the bend and angle in the front view on the picture below: Quote Link to comment Share on other sites More sharing options...
Mike Mileski Posted August 26, 2007 Author Share Posted August 26, 2007 I made the arms dimensionally identical to the tubular arms that Arizona Z Car used to sell, and I also used the exact same tie rod. I never heard of any issues with their products and they sold a bunch of them over the years. However, a friend of mine has a similar pair that I made and he races his 240Z. His car is extremely low and he runs a lot of negative camber. He had concerns similar to yours so he put the tie rod in a 12 ton press and slightly bent it just past the end of the theads to a several degree angle, approximately the same as shown in your picture. He never tried it first to see if it would work as is but is more comfortable with it slightly angled. Mike Mileski Tucson, AZ Quote Link to comment Share on other sites More sharing options...
MONZTER Posted August 26, 2007 Share Posted August 26, 2007 I have a set of AZC front arms, and they did indeed bind when topped out. This was 5 years ago and I think there design has changed. I ended up cutting off the straight front tube, and adding a bent one to fix the angle. I then decided just to build my own. Quote Link to comment Share on other sites More sharing options...
WizardBlack Posted August 27, 2007 Share Posted August 27, 2007 Very cool.... price? Quote Link to comment Share on other sites More sharing options...
Mike Mileski Posted September 20, 2007 Author Share Posted September 20, 2007 I made a tool and "tweaked" the Ford tie rod in a 20 ton press to give it some angle similar to the stock Datsun ball joint. This puts the at rest point of the tie rod in a centered position, reducing the possibility of binding. See picture. Mike Mileski Tucson, AZ Quote Link to comment Share on other sites More sharing options...
MONZTER Posted September 21, 2007 Share Posted September 21, 2007 Looks like it should be perfectly aligned now, good idea Quote Link to comment Share on other sites More sharing options...
