proxlamus© Posted November 6, 2007 Author Share Posted November 6, 2007 yep yep. just $15 for extra Quote Link to comment Share on other sites More sharing options...
Careless Posted November 7, 2007 Share Posted November 7, 2007 for extra what? and whats the diff between gsx1000 and 600 tb's ? size i guess? injector size too? what else? are they good to use as well? Quote Link to comment Share on other sites More sharing options...
olie05 Posted November 7, 2007 Share Posted November 7, 2007 Ok this thread is getting off topic. I keep looking back at it waiting for an update, only to see more questions about the GSXR throttle bodies. Read these websites and become better informed on the motorcycle throttle bodies. http://msefi.com/viewtopic.php?t=6627 http://forums.hybridz.org/showthread.php?t=127069 http://forums.nicoclub.com/zerothread/226806 Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted November 8, 2007 Author Share Posted November 8, 2007 im sorry guys i meant $15 extra for shipping. Olie.. thank you sooo much for those links! wow! And your project looks amazing so far! Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted November 14, 2007 Author Share Posted November 14, 2007 I have never in my life had more of a problem then with this stupid screws... I have 2 - 2006 units and brand new hardware (obviously) and I have stripped so many of these damn screws. I noticed there is a blue thread locker on them.. and OMG. I have a better chance loosening a rusted 30 year old screw then I do with these things. Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted November 14, 2007 Share Posted November 14, 2007 you talking about the phillips screws on the carbs??? if there is any sort of paint on the head of the screw make sure you take a little dental pick and get all of the paint out of it before you try to take it apart. then just go at it with a good new screwdriver that still has sharp edges. you really shouldnt be stripping them off though... Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted November 14, 2007 Author Share Posted November 14, 2007 yeh those damn phillips screws on the carbs! I have a NEW set of precision phillips screw drivers.. and I cant get em loose Quote Link to comment Share on other sites More sharing options...
nismopu Posted November 14, 2007 Share Posted November 14, 2007 have the same problems with 4age 20v ITB's and those damn screws!!! Just drill the heads off and drill/ re tap the threads out later. peace. Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted November 14, 2007 Share Posted November 14, 2007 actually try taking a pencil butane torch and heat up around the threads and then go at it.. Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted November 14, 2007 Author Share Posted November 14, 2007 Oh.. interesting note.. these ITB's are MIKUNI! wonder if itll bolt up to a tripple carb manifold Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted November 14, 2007 Author Share Posted November 14, 2007 oops Quote Link to comment Share on other sites More sharing options...
olie05 Posted November 14, 2007 Share Posted November 14, 2007 I'm pretty sure the spacing on your throttle bodies is 80mm. Spacing on the mikuni manifold (for DCOE's, PHH, etc) is 90mm. And i'm also pretty sure you throttle bodies are spigot mount. You would have to weld a flange to the TB to get them to "bolt on". I did see one guy weld the throttles onto his manfiold... http://www.preludepower.com/forums/showpost.php?p=932168&postcount=116 Quote Link to comment Share on other sites More sharing options...
texis30O Posted November 19, 2007 Share Posted November 19, 2007 I am thinking of getting rid of mt Turbo Tom kit and making my own kit...then I stumble apon this thread.....I have been thinking about making a intake plenium in my head for some time now....this thread is not helping my pocket book. I have a IS 300 as well as the Z and there is a guy that has done the ITB conversion with the GSX-R 1000 TB's and the car is insanely powerful.........I have had this idea in the back of my head for the Z......... Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted November 20, 2007 Author Share Posted November 20, 2007 Materials are all in.. I will be cutting and preparing for welding over fall break.. project should be done in 2-3 weeks. we will see how it turns out and Ill post lots of pics =) Quote Link to comment Share on other sites More sharing options...
md614 Posted November 20, 2007 Share Posted November 20, 2007 yeh those damn phillips screws on the carbs! I have a NEW set of precision phillips screw drivers.. and I cant get em loose I work on motorcycles, so I know what you are going through. Get a small pair of channel loc pliers and loc on the head of the screw. Comes off every time. If not apply heat. Hope that helps. Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted November 21, 2007 Author Share Posted November 21, 2007 I drilled through most of the screws.. heated up some of them.. and tried a new set of screwdrivers at Home Depot (while i worked .. haha) and got em loose great success! Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted November 27, 2007 Author Share Posted November 27, 2007 The cutting began today.. muahaha. Just need to weld on the runners to the flange.. and weld up some mounting tabs for a secure unit. Then the pressure plenum project begins Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted November 29, 2007 Author Share Posted November 29, 2007 Sorry its a cell phone pic.. but progress! Yes its a bit off.. but this was mock up stage. I have Cyln. 1-2 5-6 all welded up now! =) Quote Link to comment Share on other sites More sharing options...
olie05 Posted November 29, 2007 Share Posted November 29, 2007 Yes! I love this progress. How long are your runners? Have you considered clearance to the strut tower and/or brake shield? I measured 12.5" from the head to the first obstacle (allowing for a little bit of velocity stack) on my car. Also, are you just mocking and tacking? I was planning on making a jig for my setup, but I'm not going to be welding it myself. Looks great so far! edit: n/m i just realized what the tape was there for! Quote Link to comment Share on other sites More sharing options...
texis30O Posted November 29, 2007 Share Posted November 29, 2007 those runners seem long Quote Link to comment Share on other sites More sharing options...
