slownrusty Posted October 27, 2007 Share Posted October 27, 2007 Can Anyone please help. I am looking for the ARP part number for the L Flywheel. Their website does not have a listing. Thanks in advance! Yasin Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted October 27, 2007 Administrators Share Posted October 27, 2007 I just looked in my ARP catalog. No listing for Datsun Nissan flywheel bolts. Sorry. I did find in the ARP catalog that the Toyota 3SGTE engines utilize 8 flywheel bolts, M12x1.25x1†long. That is the same dimension as the Datsun L-series Flywheel bolts. This ARP 8 bolt kit part number is 203-2801. On paper it looks like they might work, though I can not condone the use of another flywheel bolt not intended for this application due to possible safety risks. Here is a complete list of all Datsun/Nissan ARP hardware as my catalog shows. (shameless plug). These can be ordered through Rusch Motorsports as well. Here are all the ARP listings for the L-6 engines; L24, L-26, L-28 Main studs 202-5406 Head studs 202-4206 9mm Rod bolts 202-6003 8mm Rod bolts 202-6002 All other Datsun/Nissan ARP hardware as listed in my catalog; Rod Bolts; L-16 102-6001 L-20B/Z-22 202-6001 SR-20 202-6005 VG30E & ET 202-6003 VG30DE & DETT 202-6004 VG35E 202-6006 (Pro series ARP 2000) Head studs; (all have 12 point nuts) A-12 202-4202 A-14 202-4203 L-16/18/20B 202-4201 RB20/25DE & DET 202-4301 RB26DETT 202-4207 (ARP 2000 series) SR20DE & DET 102-4701 CA18DE & DET 202-4702 (u/cut studs) VQ35 202-4701 (u/cut studs) Main Studs; L-16/18/20B 202-5401 VG30, SR20 DET 202-5402 VQ35 202-5801 (4 bolt main) Exhaust/Intake studs Stainless steel 170,000 PSI Tensile strength exhaust/intake studs, M8x1.25 thread… Studs utilize internal hex for inserting the studs, 170,000 PSI tensile, and come with 12 point nuts. Come in packs of 4, 8, 10, and 12. Come in lengths of 32mm(1.25â€), 38mm (1.5â€), 45mm(1.75â€), 51mm(2.00â€), 57mm(2.25â€) 4pack; 32mm 400-8001 38mm 400-8002 45mm 400-8003 51mm 400-8004 57mm 400-8005 8 pack; 32mm 400-8011 38mm 400-8012 45mm 400-8013 51mm 400-8014 57mm 400-8015 10 pack; 32mm 400-8021 38mm 400-8022 45mm 400-8023 (OE length Datsun L-6) 51mm 400-8024 57mm 400-8025 12 pack; 32mm 400-8031 38mm 400-8032 45mm 400-8033 51mm 400-8034 57mm 400-8035 Hope that helps, Paul Quote Link to comment Share on other sites More sharing options...
S30TRBO Posted October 27, 2007 Share Posted October 27, 2007 I did find in the ARP catalog that the Toyota 3SGTE engines utilize 8 flywheel bolts, M12x1.25x1†long. That is the same dimension as the Datsun L-series Flywheel bolts. Yasin, I am running the Toyota ARP flywheel bolts as Paul mentioned on my OS Giken setup. Same thread as Datsun works great. Quote Link to comment Share on other sites More sharing options...
slownrusty Posted October 27, 2007 Author Share Posted October 27, 2007 Great info! Many thanks to you Paul and Joe. Yaisn Quote Link to comment Share on other sites More sharing options...
MONZTER Posted October 28, 2007 Share Posted October 28, 2007 Hi Paul, Do you know if ARP now makes 10mm studs and 12pt nuts that would fit the FI intake. I also tapped the head on the outside exhaust flange for 10mm so I would need six if you could get them. Thanks Jeff Exhaust/Intake studs Stainless steel 170,000 PSI Tensile strength exhaust/intake studs, M8x1.25 thread… Studs utilize internal hex for inserting the studs, 170,000 PSI tensile, and come with 12 point nuts. Come in packs of 4, 8, 10, and 12. Come in lengths of 32mm(1.25â€), 38mm (1.5â€), 45mm(1.75â€), 51mm(2.00â€), 57mm(2.25â€) 4pack; 32mm 400-8001 38mm 400-8002 45mm 400-8003 51mm 400-8004 57mm 400-8005 8 pack; 32mm 400-8011 38mm 400-8012 45mm 400-8013 51mm 400-8014 57mm 400-8015 10 pack; 32mm 400-8021 38mm 400-8022 45mm 400-8023 (OE length Datsun L-6) 51mm 400-8024 57mm 400-8025 12 pack; 32mm 400-8031 38mm 400-8032 45mm 400-8033 51mm 400-8034 57mm 400-8035 Hope that helps, Paul Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted October 29, 2007 Administrators Share Posted October 29, 2007 Jeff, I couldn’t find any 10x1.25 mm studs, or “any†10mm studs for that matter in the catalog. ARP does offer various metric bolts. 6x1, 8x1.25, 10x1.25 and 10x1.50. The 6 and 8 MM bolts come in the following lengths… 12, 16, 20, 25, 30, 35, 40, 45, 50, 55, 60, 65, 70, 75, 80, 90, and 100mm lengths. The 10mm bolts come in 20, 25, 30, 35, 40, 45, 50, 55, 60, 65, 70, 80, 90, and 100 mm lengths. All bolts are offered in either hex head or 12 point, Black oxide or stainless. Wrench sizes for the 6mm bolts is an 8mm wrench, for the 8mm bolts is a 10mm wrench, and for the 10mm bolts, a 12mm wrench. Hope that helps, Paul Quote Link to comment Share on other sites More sharing options...
MONZTER Posted October 29, 2007 Share Posted October 29, 2007 Thanks Paul, I got the 8mm stainless studs a long time ago when ARP started doing the import stuff. Somewhere ARP found me stainless 10mm 12 point nuts, but they had no matching Stainless studs. I have to use 10mm studs for the top of the intake flange, as I have angled the runners up relative to the head and bolts will not fit in the holes without hitting the runners (does that make any sense?) Oh well I have ugly black oxide studs I will be stuck with for now. Thanks again for looking. Best Regards Jeff Quote Link to comment Share on other sites More sharing options...
Tony D Posted September 10, 2014 Share Posted September 10, 2014 FYI to update the post, ARP now offers a "KA24" Flywheel Bolt Kit with the same under-head grip length as the 3SGTE kit listed above. The kit only has the six bolts for the Nissan Application, instead of 8 for the Toyota. P/N 102-2802 They also have a listing for RB26 FW Bolts with under-head grip length of 1.180", handy if you have bottom tapped your flywheel flange bolt holes and want an extra 0.180" thread engagement, or have some desire to use a hardened clamping washer so your nice soft aluminum flywheel doesn't stand such a chance of embedment and loosening of the bolts due to shock and vibration (HINT HINT!) Here's the 2014 Linkey: http://arp-bolts.com/kits/Make.php?_Make=17&_EngModelID=* 1 Quote Link to comment Share on other sites More sharing options...
burkeys Posted November 7, 2014 Share Posted November 7, 2014 The matching washer to go with the ARP RB26 flywheel bolt (arp #102-2801) that Tony D mentioned is ARP part # 200-8710, you must order 6 of the washers. Note: The inner diameter chamfer on the washer goes against the head of the bolt. If you do not do this, the washer may cut the head of the bolt off. I have not tried this yet, so I do not know if the clutch will clear bolts with washers under them but I think it will work...Ill try to post more when I get it together. Thanks Tony. Quote Link to comment Share on other sites More sharing options...
TimZ Posted November 8, 2014 Share Posted November 8, 2014 Orrrr.... The RB flywheel bolts will also allow the use of a flexplate spacer for the same purpose if you can find one. Quote Link to comment Share on other sites More sharing options...
