HICKL Posted November 2, 2007 Share Posted November 2, 2007 My motor creates very little vacuum at idle so my breaks suck. I have messed with a vacuum canister but didn't like it. I've heard of adding an electric vacuum pump to boost the vacuum. Anybody got any input or cost effective solutions? Thanks Jeff Quote Link to comment Share on other sites More sharing options...
TimZ Posted November 2, 2007 Share Posted November 2, 2007 My motor creates very little vacuum at idle so my breaks suck. I have messed with a vacuum canister but didn't like it. I've heard of adding an electric vacuum pump to boost the vacuum. Anybody got any input or cost effective solutions? Thanks Jeff I had the same issue with my L6 - I ended up going with a vacuum pump pretty much identical to this one on ebay. Also, there is the Stainless Steel Brakes pump, which is a bit pricey, ...and then there is this recent HybridZ post: http://cgi.ebay.com/ebaymotors/Delco-12-Volt-Electric-Vacuum-Pump-Hot-Rod-Electric_W0QQcmdZViewItemQQcategoryZ42605QQihZ004QQitemZ140173807817QQrdZ1QQsspagenameZWDVW Quote Link to comment Share on other sites More sharing options...
ezzzzzzz Posted November 2, 2007 Share Posted November 2, 2007 A vacuum can works well too. I ran one on my 73 Z28 pulling 8 inches at 1200 rpms. It made the car streetable...well, at least the power brakes worked. Quote Link to comment Share on other sites More sharing options...
HICKL Posted November 2, 2007 Author Share Posted November 2, 2007 A vacuum can works well too. I ran one on my 73 Z28 pulling 8 inches at 1200 rpms. It made the car streetable...well, at least the power brakes worked. I don't like the vacuum can because after hitting the breaks, my motor stumbles for a few seconds while it experiences the big vacuum leak of re-filling the can. Quote Link to comment Share on other sites More sharing options...
LT1-280z Posted November 2, 2007 Share Posted November 2, 2007 You could try a restricting orifice in the line to slow down the re-filling of the can. Quote Link to comment Share on other sites More sharing options...
Chaparral2f Posted November 2, 2007 Share Posted November 2, 2007 I've got the same problem, and have been wondering about the vacuum pump off a Z31 Turbo. Someone told me it's an electric unit that is mounted under the front of the car, but I don't have any clear info yet. Quote Link to comment Share on other sites More sharing options...
specialk Posted November 2, 2007 Share Posted November 2, 2007 I've got the same problem, and have been wondering about the vacuum pump off a Z31 Turbo. Someone told me it's an electric unit that is mounted under the front of the car, but I don't have any clear info yet. Wander around on z31.com (and be sure the SEARCH a lot before you ask any questions!) Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted November 3, 2007 Share Posted November 3, 2007 280ZXT's had vacuum pumps also. Quote Link to comment Share on other sites More sharing options...
getZ Posted November 3, 2007 Share Posted November 3, 2007 I've heard of electric vaccum pumps and I have a hydraulic one that uses presssure off the power steering pump for another car that I haven't installed yet, but it requires a modified master cylinder. I think the companies name was hydroboost. Quote Link to comment Share on other sites More sharing options...
zcarnut Posted November 6, 2007 Share Posted November 6, 2007 The 1981-84 Maxima Diesel had a vacuum pump that ran off the alternator. It bolted to the back of the alternator and the pulley shaft was extended all the way through the alternator housing. This alternator/vacuum pump will bolt up the L-series engine, but requires an oil feed line and a return line to the sump. Quote Link to comment Share on other sites More sharing options...
e_racer1999 Posted November 6, 2007 Share Posted November 6, 2007 mid 80s chevy celebrity. you're welcome Quote Link to comment Share on other sites More sharing options...
HICKL Posted November 6, 2007 Author Share Posted November 6, 2007 mid 80s chevy celebrity. you're welcome What about it? Am I missing something here? Quote Link to comment Share on other sites More sharing options...
e_racer1999 Posted November 6, 2007 Share Posted November 6, 2007 do a google search for chevy celebrity vacuum pump. if you have a j/y by you, go there and get one or a few. cost is like $14 Quote Link to comment Share on other sites More sharing options...
HICKL Posted November 6, 2007 Author Share Posted November 6, 2007 Ok, now I follow you. Is that a belt driven pump? I did a google search and found a few add's but no real help. Quote Link to comment Share on other sites More sharing options...
e_racer1999 Posted November 6, 2007 Share Posted November 6, 2007 no, it's elec. here: http://www.california.com/~eagle/figs/vacpump/vac.html i got the heads up from a fellow member. Quote Link to comment Share on other sites More sharing options...
jnjdragracing Posted November 6, 2007 Share Posted November 6, 2007 Hey HICKL, We had the same issue with the blower setup we run. We purchased a inline check valve and installed it about 5 inches from the brake booster. What little bit of vacuum we were pulling would be stored by the check valve, line and brake booster. But yet again we are mainly drag race only. John Quote Link to comment Share on other sites More sharing options...
Zfan1 Posted November 7, 2007 Share Posted November 7, 2007 I too have had the same problem but installed a Stainless Steel vacuum kit I picked up off Ebay for 150 bucks. We tried the junk yard variety and most sucked ass, did work but not for long. Maybe they sat in a junk yard too long! Either way the vacuum pump works wonders as I only make 5-7" of vacuum at idle with it in gear and that would not have cut it! Quote Link to comment Share on other sites More sharing options...
