Rear suspension options for 400-500hp
Guest Anonymous
Guest Anonymous
I have seen the video of the supercharged v8Z blazing his tires at a running start and am wondering what type of suspension he is running?
I am not totally convinced the r200 will handle 400-500 hp. I would still like to use an IRS the only other idea would be a vette(have heard of it done by Georgia Z club) but how practical is that?
I would also like something numerically lower than the 3.55 gears am I dreaming or could this be done?
Zman,
I believe the Z you are referring to is running IRS with an R-200. It seems the success with the IRS and a high-torque application varies from breaking parts like they were twigs to "how in the hell does he get away with that".
Derek Grubb is running a 71 with a Buick turbo and his car has run a best of 10.59 with a 1.49 60' on 6" slicks. He is using an LSD with 3.36s (custom), but the rest is stock Nissan IRS including halfshafts. I have heard, however, that he has broken axles.
I am running the same drivetrain with less HP but I still launch hard with a transbrake and 275 BFG DRs and have a best 60' of 1.55. My car is also a 71 with Illuminas all around at the softest setting when racing, generic sport springs in the front, JTR rear spring perch mod, welded 3.54 diff, ZXT CVs with an adaptor and both swaybars removed. Another key to keeping my setup together is my homemade diff strap that keeps the nose of the diff planted like a solid mount but still retaining the stock rubber mount.
I think some of the keys to keeping the stock IRS together are: proper driveshaft angle, avoiding extreme halfshaft angles (cured by using CVs), keeping the nose of the diff planted, avoiding massive wheelspin and wheelhop, and of course, being lucky to find quality used parts. Remember the used diffs, stub axles and halfshafts we get from the boneyards are upwards of 25yrs old and that used R-200 might still have the original lube from the factory biggrin.gif
Cannot say that what I am doing will work for everyone, but so far I am having good results and will continue to have faith in the IRS setup.
Scottie
71 240GN-Z
Scottie's GNZ
OK my first question is this: Do you want to reinvent the wheel? Add more work to an "Already Hard project"? There are a number of guys here on this site that can attest to this: The week link in the R200 is BY FAR the u-joilt equipped half shaft units... Bottom line... If you are worried about anything, then get Scottie's buddy to make you a set of those Axle Shaft adapters and then get yourself a pair of 280ZX turbo CV Axle shafts, and weld your R200 Axle flanges tot he adapters, slap the CV axles in, and you are done... No fuss, no muss... My 500HP small bloock is throwing nearly 500Ft# of torque to the rear end and I'm doing just fine.
Mike
http://hometown.aol.com/dat74z/myhomepage/auto.html
"I will not be a spectator in the sport of life!"
mjk
I feel another key to this is the tire compound and size. When a 225 (for example) gets enough torque, it's going to be the weak link that breaks. Put a 12" wide, soft compound slick on the same car, and the resulting weak link may develope elsewhere. This is one reason I have not actively seached for a LSD. I get a nice pattern without it, but when one side (tire traction) breaks loose, I consider it a "popoff" valve for the drivetrain (note: this is for street use, as an LSD is most desireable for the road course).
Terry
The car in the video you refer to is Darius supercharged LT1 (I think it may be stroked to 383 as well??).
He has an R230 from a Z32TT. There are actually a couple of people that I have heard of who have done this swap. Mostly they do it by using only the inboard Z32 CV, and a (custom?) flange and UJoint outboard.
There is a person on this forum who has been discussing the possibility of using the entire Z32 rear drivetrain by modifying things like the 240 carriers and the Z32 halfshafts.
Certainly seems like switching to CVs and seeing how they hold up would be wise - no sense taking on a complex and $$ project if you don't need to. If you have a 240, the ZXt CV halfshafts are a simple, bolt in swap. They can be had for less than $150 at most yards.
240Z.jeromio.com
Guest needwaymorespeed
Im currently working on putting the complete rear end from a tt 300z in my car-just finished one of the jigs yesterday.
my reasons for doing it are these
1- it will give me the rear disc brakes with twin spot calipers-these are nice aluminum and say nissan on the sides of them-looks real cool- rear rotors are big-11.5"from memory" and vented
2- a viscous rear end-far superior and the pricing for the rear ends from a 87-89 turdo z with a lsd is ridiculous
3-the stub axles stock 240 z and 280 stub axles are very small-theres been several guys with higher horsepower cars that have broken these
4-actual rearend is a r230=its big 230mm works out to be over 9 inche ring gear-its slightly bigger than a ford 9 inch-aand we all know how tuff they are
5-wanted cv joints this rear end has them
6-wanted 5 lug-rear end has it
7- want to run deep offst wheels " the 300 z tt wheels have a 6 and 1/16 offset and those sweet cobra r wheels that mike kelly has are a deep offset also-so when I make my new Knuckle Im going to add 1 inch of width to it so that I wont have to buy spacers for the rear of the car-wider track width is a plus also.
whats the actual cost to do this the rear end with 2 shafts rear rotors calipers and knuckels cost me 650.00-from a salvage yard-
will have to spend a 100.00 to cut and respline the cv shafts-are cars are much narrower than the 300 z tt
plus a 100.00 for metal-going chrome moly -lightweight and strong
I also have to buy or make a new rear brace to clear the fiined cover-they cost 80.00
total cost 1000.00 give or take a 100.00
plus the driveline plus lots and lots of time to do it but hey we love these cars right!!???!!
not cheap but I dont want to break a rear halfshaft -u-joint or loose a stub axle.
cost to do it the other way
11.5 rear dis brakes 500.00-can go smaller for less money
r200 rear end thats lsd 300-8000
cv shafts-150.00
cv shaft adapter -if you can get it from scottie-sounded like it was a lot of work for scottie to get these for everyone- was a little over a 100.00
have to have a rear brace to clear finned r200 cover also 80.00
grand total 1130.00 for the r200 set up "thats if you can find a lsd for 300"versus 1000.00 for the r230 set up which is definately better in every way except the hassle of doing it.
anyways thats my take on it I wanted a Irs with the durrability of a solid axle-hopefully ill get it. there's a thread on this in drivetrain section under complete r230 rear in 240.
Curtis
whew that was way too much typing...
Curtis, that's an awesome plan. Are you going to offer the custom hub carrier you're making? Where are you getting the axles resplined? What ratio in the diff? What ratios are available in the yards?
Pete Paraska - 73 540Z - Marathon Z Project
pparaska@home.com
Pete's V8 Datsun 240Z Pages
Thanks
Youre welcome for the info.
Pete
Ive ben thinking about marketing them ,just wasnt sure what type of interest there would be for them.
I am looking at moser engineering or a local shop on having the axles shortened and resplined.
I know of two ratios available for thee r230 rear ends
3.54 for infiniti Q45-not sure from what year to what year guessing 90-96 anybody know for sure
3.68 for 90-96 300 z tt the na have the r200 rearend in them
Curtis
R180 - Nissan diff. with 180mm ring gear
R200 - Nissan diff. with 200mm ring gear
R230 - Nissan diff. with 230mm ring gear
R180s were commonly in the 240z, 510 (I think) and a bunch of 4x4's.
R200s are much beefier, and were in the 280z, 280zx, 300zx (84-89, often called Z31's), and naturally aspirated 300zx (90-96, often called Z32's)
R230s are from the 300zx twin turbo's (Z32s, 90-96), as well as the infinity Q45 I believe.
Probably lots of other cars too, the 240sx, 200sx, etc probably had some variation on these. Basically all RWD nissan diffs fit in here somewhere.
Richard Lewis - 1972 240z, Powered by a Nissan 2.8L Turbo Inline 6.
Drax240's Turbo Site
Beginners Turbo FAQ & Answers
Does the R230 from the Infiniti mount the same as the one in the TT Z32?
yes there the same. I acually have the r230 and half shafts and knuckels form the infiniti and rotors and calipers from the tt.
only difference I could find between two cars is infiniti has non vented rotors with single spot calipers and the 3.54 ratio
tt has vented rotors twinspot calipers and lower 3.68 ratio.
the knuckles are even the same.
Curtis
  • 1 year later...
No the R230 will not bolt in. You will have to:
Make a front diff mount.
Get a R200 mustache bar and redrill (machine shop!!)
Get 2 sets of side shafts to make one set (need 4 inner CVs, to use inboard and outboard)
Have new side shafts made (shorter)
Have a new driveshaft made.
Unless you are using monster torque and HP, use the R200, that is bolt in.
Tim
Funny this thread should pop up again!!
Last night I finished insdtalling my custom rear knuckles that are talked about in this post-they look great! youd think it camr from the factory this way!
Ill take some pics,just dont have anywhere to host them.
now I Have to make my front member for the r230 and shorten the cvshafts
Curtis
i would love to see the pics also.
How much power are you looking to put down?
i mean i know 300ZX TT guys with n/a rearends that are putting down more the 500+hp and the rear end is fine.
so is this R230 worth it if ur putting down say 450rwhp?
the Z32 R200 is LSD too.
Plus i would think its cheaper to buy.
mike
