Ivan280zt Posted December 25, 2002 Share Posted December 25, 2002 i just got done with my front five lug conversion (77 280z) using z31 hubs and scca mikes spacers and everything came out just perfect but when i went to put my calipers on (stock ones with new pads) they wouldnt fit on. i know that z31 rotors are thicker (because they are wented) so what do i have to do now? should i just go and get toyota four piston calipers or is there way to trim down my pads (stock ones). also what year did those four pistons caliper come off (i need exact years) and how much am i looking to spend on remanufactured ones. any help would help alot. Quote Link to comment Share on other sites More sharing options...
denny411 Posted December 25, 2002 Share Posted December 25, 2002 me if this is too obvious, but did you push the pistons back into the calipers? I know it would be an obvious mistake, but at the end of a long day when things have gone less than right, I`ve missed things that I normally wouldn`t. How much too thick are the rotors? could they be turned? I myself would go with the Toyota calipers anyway, but thes are all good ?`s Quote Link to comment Share on other sites More sharing options...
Mudge Posted December 25, 2002 Share Posted December 25, 2002 Master cyl, take the cap off it, and push on the pistons, some cars need a C clamp (well, it helps). Quote Link to comment Share on other sites More sharing options...
Ivan280zt Posted December 25, 2002 Author Share Posted December 25, 2002 ok here it is. rotors have just been turned today, calipers are pushed all the way in and i mean all the way, cap is already taken off and there is no any fluid in the lines yet. Quote Link to comment Share on other sites More sharing options...
Ivan280zt Posted December 26, 2002 Author Share Posted December 26, 2002 Daw i am using z31 rotors. Quote Link to comment Share on other sites More sharing options...
mike240zt Posted December 26, 2002 Share Posted December 26, 2002 z31 rotors vented require 88 toyota 4x4 v-6 model calipers Quote Link to comment Share on other sites More sharing options...
zcarnut Posted December 26, 2002 Share Posted December 26, 2002 You can use the calipers from the 1986-88 Toyota four-wheel-drive truck. This caliper is exactly the same as the 1979-85 Toyota caliper, EXCEPT it is made wider for a 22mm thick rotor (the same thickness as the Z31 rotor). The 1988 Toyota V6 caliper is heavier but has more pad and piston area and hence requires a one inch diameter master cylinder (this is my present set up on my 260Z). Quote Link to comment Share on other sites More sharing options...
Ivan280zt Posted December 27, 2002 Author Share Posted December 27, 2002 man afther long crapy day of work this is the only place that gets me relaxed. thanks alot to everyone Quote Link to comment Share on other sites More sharing options...
