LS_1 / 280Z Speedometer Question
Help, I give up. I am a 60's vintage mechanical guy with a 2007 electronic question. Finally have the LS_1 with 6 speed in the 1978 280Z. Got a Abbott Cable X box for the speedometer conversion. To get it to work I need to calibrate it. It needs to know pulses per mile in order to function. Formula = Transmission # teeth X rear axle ratio X tire revs per mile equals pulses per mile. How do I find out how many teeth on the transmission gear, I can figure out the rest.
Thanks in advance
rwwisnesky@yahoo.com
Here's some info.
http://www.thirdgen.org/techboard/ltx-lsx/320227-ls1-vss-pulse-92-a.html
http://www.skulte.com/T56.html
http://www.lt1swap.com/wiringharness.htm
Looks like the T56 is 17 Pulse per rev. However if you are using the stock PCM the speed signal from the PCM is already calibrated to 4000 Pulse Per Mile. I highly recommend using this signal and have the PCM programed for you tire size and diff ratio. This makes the speedo calibation simple = locked in at 4000 PPM. The VSS signal is required by the PCM anyway so why not use the calibrated output?
  LT1-280z said:
Here's some info.
The CableX wont work through the PCM. Use the 17 teeth number and hook the box up directly from the trans. It works great. After my initial set up I figured I was off like 12 percent, using the book I just multiplied by that 12 percent, used their settings, and bingo, right on.
MIke
  rwwisnesky said:
Question to m1noel, do you recall the wire hookup colors you used to mate to the cable x from the sensor. Cant determine which is +/- from the sensor from the shop manual.
Used the vss high BU/WH for the +
Used the vss low BN/RD for the -
Worked great- Good luck
Mike
Thanks Mike for the quick response. I was hoping you would have the answer, on my way out to the garage now to hook it up!!!! I also havr the JTR radiator on order and a Ford Taurus / Mustang electric fan (4500 cfm). Was curious what fan set up you used. The fan is a two speed so you will probably see more questions when its hook up time.
I used a two speed ford fan from John's, I really don't know what is was for, but it fit the JTR radiator really well. I used the leads from the pcm to trigger two relays, one for each speed on the fan. Cools really well even in 100 degree heat with the AC on.
And you can PM me anytime- might notice it quicker that way.
Mike
