Pintle regulated induction system.
OlderThanMe
I just found this "pintle-regulated" induction system.
http://www.prvperformance.com/
I thought it would be VERY interesting to discuss here.
I wonder how much throttle modulation you would be able to have. I guess that would be dependent on how far the pintle enters the intake runner tract and how you control the pintle. (stepper motor, hydraulic, pneumatic, or mechanical control)
Wht are your thoughts?
OTM
Guest TeamNissan
Ya, I'm sure thats where the equal gain in hp and tq comes from on their dyno results. no?
Wouldn't it be easiest to just use a mechanic set up? Or you thinking using a motor and having that tunability?
I dont see how this it going to make it easier to take advantage of resonance.
The main benefit that I see in this design is the reduction in turbulence over the entire range of throttle positions. However, once a normal TB has gone to full throttle I dont see there being a huge amoung of turbulence due to the traditional throttle plate.
It is an interesting design though and I would love to be proven wrong. I would like to know more about the design and what its benefit is over normal throttle bodies.
Guest TeamNissan
Well its my understanding air entering comes mostly from the edges so even when a traditional throttle butterfly is full open there is still a large section to cause turbulence and restriction.
mad0018.gif DUH... What did I miss? lol
Mechanical would be the easiest I think.
By not having any disturbance in your perfectly straight and long intake tract... That way it could be modeled and calculated more accurately without having to factor in a metal shaft right in the center of the intake tract.
True...
Now if someone could develop a throttle plate that had no shaft running through the runner... Then turbulance would go down a bunch(IMO)
Guest TeamNissan
Well you suggested using actuators or stepper motors, was just my suggestion. Maybe I'm the one who missed something lol.
Gate throttles don't use a shaft through the center. Manufacturers like mazda are using them stock too but Idk how hard or easy it would be for a novice to come up with a working SEALED version. Also I have seen some good barrel valve designs too but I don't see many people using them.
  • Administrators
Not to thread jack, but..
… what about a barrel valve style TB or slide valve? No throttle shaft or Pintle valve controller arrangement in the intake tract. At WOT, just a perfectly straight shot, NOTHING in the air stream to induce eddies or disturb the flow.
Butterfly, Barrel, Spike/pintle Throttling...
Guest TeamNissan
My previous post? lol
Barrel valve would be interesting. Some simple calculus could find out the area between the two curves so that a proper cam could be made to actuate the barrel exactly so that depressing the throttle 50% would allow 50% throttle exatly.
The slide valve and barrel methods would probably be easier to fabricate but I believe the pintle/spike method would be able to flow smoother through the full range of RPMs.
For the complexity it would probably not be worth it unless you were running in a restricted racing class such as FSAE, then it would be invaluable.
One barrel maybe would use a linear response. If you have multiple barrels, then you want a dead tip-in for drivability.
Why put anything at all in there or worry about designing the 'correct cam' for the application, and simply control the intake and exhaust valves via electrohydraulic actuators driven off an engine-based pump and accumulator setup? Variable valve lift, timing, and duration will give you EXACTLY the same response as a throttle valve without anything there to muck up the flow. And you can bet the advantages of variable valve events will make more power everywhere along the powerband as lift/duration/rpm is all optimized for each point on the curve, infinately recalculated realtime as the engine is being driven! Twin 140MHz ECU processors will do that easily on a 12Cylinder engine to 12K rpms I believe.
"DEVAS"
(Since we're throwing the stuff out there...)
A funnel shaped Iris would probably be the most efficent and least turbulent I would think.
The barrel design seems interesting, and perfect at WOT, but what about the rest of the throttle range? It seems that the further you get from WOT, pretty quickly it would be more turbulent than a butterfly design, no?
