After 5 years sitting in the garage, I took the Z for a SPIN today!
BillZ260
Wasn't sure if I'd get everything I needed to get done yesterday and today but I did!
Replaced the Master Cyl (swapped up from 3/4" to 1")
Dropped the exhaust
Buttoned up the cluth line
Cleaned some welds on the exhaust
Replaced Oil pan and gasket
New dipstick
I it was pretty cold out today but I got on pace after lunch. Got everything buttoned up, test ran it to temp and checked for leaks, only a small coolant leak, maybe at the heater core lines? Need to find, but it's minimal. Dropped her off the J-stands, fired her back up. Clutch issues are apparently worked out, went right in to reverse so I backed her up and drove her around the block!
What a rush! Shifts pretty smooth, TONS of power, ZERO traction! It's perfect :)
Still tons to clean up and finish, but mechanically this thing is 95% done. Now to figure out that paint scheme I've been racking my brains on, and the interior...
Thanks Hybrid Z I'd have NEVER gotten as far as I have with out you guys!
I have some vid, will post it as soon as possible!
Thanks JSM. I was showing my wife the video and she said she'd never seen me smile like that when i got out of the car.
I don't know if that's good or bad, but the feeling was incredible. Having something that you've put all this effort into, and actually getting to EXPERIENCE it!
Thanks again to EVERYONE here that has helped me move this thing forward to the point that it is. Maybe in 5 more years it will actually be "Finnished"
Bill post some of the generic specs on your car.
Engine/Tranny
Rear end
Tire and wheel size
WAY TO GO!!!!
I know Bryan is chomping at the bit waiting to get his out and about...While I still formulate a plan for mine, WHICH I FINALLY HAVE!!!! ;)
Specs short list as requested
Engine:355/Alum RPM heads and intake, Eddy 650 Carb, Eddy "400" Cam/roller rockers, ballanced, etc...
Trans:T-5/Cobra "R" internals GM input shaft,Carbon Kevlar syncros?,Hurst Billet Pro shifter (Love it BTW)
Clutch:Ram Billet Flywheel, 10.5" PP and disc,Tilton HTOB and 1" Tilton Master (3/4" was too small)
Driveshaft: local truck driveline specialist place end pieces from Ebay/JTR
Rear: Stock R180, I think they are 3.36. I have an R-200 that I'd like to add a limited slip to.
Suspension: 1" Dropped MSA Springs, Tokico Blues, Urethane busshings, Stock front sway, no rear currently.
Wheels: 17" MoMo "Sports" (Thinking of 17" AA Torque Thrusts) Spacers, 215/45/17 Potenza's.
Probably missing some stuff. I want to change out my current Fuel Cell with one that is less visible. I havn't done anything with the interior other than the full dash pad and Autometer Phantoms. Probably missing some stuff...
I have a vid but I need to upload it to my home puter. I'll try to get that done soon. Need to find my freaking licence plate! Dunno where I put that? I think I can 'quietly' limp it to the muffler shop and get the exhaust finnished up sometime soon, but I need my plate!
Thanks for the comments guys!
----Bryan, did you get your wiring sorted?
Well, what's sad is that I actually got it running almost exactly 1 year ago to the DAY! I was traveling so much this year, I did ZERO to the far for over 9 months!!!
No burnouts yet, but the rear stepped out on my very first run a couple times. My torque curve is going to be murder on those 215/45/17's!
Bill:
Well, I sorted one problem to get another. I was getting so ticked off at the car that I had to leave it be for a while - my wife thought that I had cut my arm off or something...:)
I think that the new years day goal may have been a little lofty for me. I had a bunch of parts that I was depending on that got hung up due to new years, so...maybe this weekend.
Bryan
Saturday Morning I got up early(ish), drove as quietly as possible with open exhaust to the muffler shop. They had it for a couple hours and the work was pretty good for the price. They said I can bring it back for any minor adjustments later. Basically what I am running now is the square port shorty headers, 2-1/2" w/ a H pipe behind the tranny w/ turbo mufflers, I really like the sound.
Noticing a couple of things that bother me w/ my first runs. I've probably put 10 miles or so on the car (need to hook up that speedo!) The bearings on my NEW CHEAP ebay alternator are screaming so i'll be looking for a solution to that, I'm thinking of getting a bearking kit or something. Also the Holley Red fuel pump is really noisy, anyone notice this? I mounted it in the stock location with the rubber mounting pad but is just too loud.
Anyway, driving it home, getting on the on-ramp, this thing really moves! I'm pretty excited that everything is working and holding up after a couple of hard pulls.
Also gave my Wife and Little brother a quick ride.
Crystal:What is that SCREAMING! (this is after a short WOT in 2nd)
ME(With a grin): That is a V8!
Put about 10 miles or so on her yesterday. I noticed the motor really starts to pull hard only after about 4-4.5K, dunno if it's the cam or the carb. The car is running very well, and I am extreamly happy with how easy it is to drive around town, how it can litteraly just SCREAM when I get on it (I am really supprised how bad ass those generic turbo mufflers sound at RPM).
The only thing that is bugging me is the complete and udder lack of traction through 3rd, and my brakes. I really need to install the adjustable proportioning valve because I don't thing the rears are working at all.
Oh and the DRAIN i feel after getting out of the car once the adren stopps flowing!!! :) he he he
