philfree Posted December 29, 2007 Share Posted December 29, 2007 Hi I found out that i have a f54 block with p80 head. Is this right i can't find any documentation on the p80 does anyone have any information. Thanks Philfree Quote Link to comment Share on other sites More sharing options...
OlderThanMe Posted December 29, 2007 Share Posted December 29, 2007 I don't think Nissan made a P80... You should have either a P79 or a P90. The P90 head came on the turbo cars and the P79(N/A cars) is almst identical except that the exhaust ports are round rather than rectangular. There are several in depth discussions here on HybridZ about the different Z car heads. THIS ONE FOR EXAMPLE Hope that helps, OTM Quote Link to comment Share on other sites More sharing options...
philfree Posted December 30, 2007 Author Share Posted December 30, 2007 Hi I took a pic of the number it's a a bit hard to read as i used my phone but it's a p80 in my book link: http://philfree.250free.com/p80.jpg Thanks philfree Quote Link to comment Share on other sites More sharing options...
Warren Posted December 30, 2007 Share Posted December 30, 2007 it reads P90...an 8 wouldn't look like that...the bottom part of the 8 would be round, not the top. Quote Link to comment Share on other sites More sharing options...
Careless Posted December 30, 2007 Share Posted December 30, 2007 Warren is right. in a casting of an 8, the bottom circle is usually the one that is visually "on top", if you were to pretend they were two separately layered circles. good call, Warren. Quote Link to comment Share on other sites More sharing options...
philfree Posted December 30, 2007 Author Share Posted December 30, 2007 Hi So the head has been switched right? how do i tell if it's had a whole motor swap or a only a head swap if it's had a motor swap it would have a turbo motor right? Thanks Philfree Quote Link to comment Share on other sites More sharing options...
BurnoutZ Posted December 30, 2007 Share Posted December 30, 2007 Huh? An f54 block with a p90 head is fairly common? Nothing to worry about its perfectly normal l28turbo motor. Quote Link to comment Share on other sites More sharing options...
philfree Posted December 30, 2007 Author Share Posted December 30, 2007 Hi Yes i would really like it to be but it's a 1979 and ive been told Nissan never sold turbo 280zxt's in Australia also it's not turbo.... this could explain why it's running rich consistently because of the na computer and the turbo injectors Thanks Philfree Quote Link to comment Share on other sites More sharing options...
240Zed Posted December 31, 2007 Share Posted December 31, 2007 Its not a turbo motor. P90 heads were fitted to late model 280zx's in Australia, and as you know they were all NA, no turbo 280zx's were sold in Oz. I have a 240K Skyline with a P90/F54 carbie motor which I think is probably from a 280C or a Patrol. It wouldn't have turbo injectors. Quote Link to comment Share on other sites More sharing options...
philfree Posted January 2, 2008 Author Share Posted January 2, 2008 Hi I am not trying to drag this on. But i went into the local Nissan dealer today to check the engine number and vin number. Seems its not on their system so they have told me with reasonably high certainty that the car is imported. this is where i am lost. I have a 79 so its one of the early ones with a f54 block and a p90 head and 3speed auto. did this combination ever come out of a factory like this? Also can you tell if the pistons are dished or flat top by taking the plugs out? Thanks Any help much apreciated Quote Link to comment Share on other sites More sharing options...
X64v Posted January 2, 2008 Share Posted January 2, 2008 philfree said: Also can you tell if the pistons are dished or flat top by taking the plugs out? Yes. Quote Link to comment Share on other sites More sharing options...
Gollum Posted January 10, 2008 Share Posted January 10, 2008 Does the car have t tops? If so it's most likely NOT a 79'. If it was imported there's a good chance the years got screwed up. I'd definately check the pistons via pulling a plug. If it's got flat tops don't worry too much about it. If that's the case then the running rich is EFI related. Check fuel pressure, AFM, and vacuume lines (make sure they're connected right and not blocked). Quote Link to comment Share on other sites More sharing options...
