MJLamberson Posted February 3, 2008 Author Share Posted February 3, 2008 yeah i still need to go get that engine from you... soon i promise, been busy with bad weather Quote Link to comment Share on other sites More sharing options...
MJLamberson Posted February 3, 2008 Author Share Posted February 3, 2008 well I took a look at the valve train, everything looked in place. I put the valve cover back on, fired her up and shes back to her old self, running like a champ, weird stuff, maybe she was just PMSing...anyways thanks everybody for your help...again. good day! Quote Link to comment Share on other sites More sharing options...
HoustonZ Posted February 3, 2008 Share Posted February 3, 2008 I'll bet you it is one of the thermo sensor connectors. I had the exact same thing happen to me. The problem was totally random, and eventually stranded me. Took a few days of trying absolutely everything before I discovered a short in the thermotime sensor. Quote Link to comment Share on other sites More sharing options...
MJLamberson Posted February 3, 2008 Author Share Posted February 3, 2008 Cold Fusion said: I'll bet you it is one of the thermo sensor connectors. I had the exact same thing happen to me. The problem was totally random, and eventually stranded me. Took a few days of trying absolutely everything before I discovered a short in the thermotime sensor. this isnt qiute random, only after high revs Quote Link to comment Share on other sites More sharing options...
OlderThanMe Posted February 4, 2008 Share Posted February 4, 2008 Trash the stock EFI and go to carbs... No more weirdness going on. Or go to an aftermarket EFI. Quote Link to comment Share on other sites More sharing options...
Guest TeamNissan Posted February 4, 2008 Share Posted February 4, 2008 olderthanme said: Trash the stock EFI and go to carbs... No more weirdness going on.Or go to an aftermarket EFI. I agree 100% and even on a shoe string budget its easily doable. Quote Link to comment Share on other sites More sharing options...
bucket240z Posted February 4, 2008 Share Posted February 4, 2008 I've got a few carb setups too if you decide to go that way. When you get the engine we can discuss it if you want. Quote Link to comment Share on other sites More sharing options...
hoov100 Posted February 4, 2008 Share Posted February 4, 2008 z31 EFI swap.........probably the cheapest and most reliable factory, smog able FI swap for people in CA. Quote Link to comment Share on other sites More sharing options...
TimZ Posted February 4, 2008 Share Posted February 4, 2008 Dragonfly said: If you find it has come off and you want to put it back on make sure that the cam lobe is pointed upward like in the photo. It will take a little bit of work to get it back on as well as the very real posiblity of adding a little of your own blood to the oil. If you do not have a valve spring compressor that will work with the head on the engine the best way to put the rocker back on is to take two fairly large flat head screwdrivers, place the tips on either side of the spring retainer (make sure your lash pad is in place and facing the correct direction first) with the shafts coming back towards you on either side of the cam lobe. Using one hand to raise the backs of the screwdrivers and the cam as a pivot point to push the spring down carefuly put the tip of the rocker onto the lash pad and the back of the rocker over the pivot, now release the pressure on the screwdrivers and everything should be good. It would also be a good idea at this time to check your valve lash on all your valves. Also if the screwdirvers just will not stay on the spring retainer go ahead and lower the pivot as far as you can and you may be able to put the rocker on without compressing the spring any but if you do that you absolutely have to reset your valve lash on at least that one. Dragonfly All good advice - I find that it is much easier to remove or install a rocker if you loosen the locknut on the lash adjuster and screw the adjuster down as far as it will go. Once you do that, only a very small amount of valve spring compression is generally needed to get the rocker on. Also, if you don't find anything obvious with the valvetrain, you might want to check to see if you've fouled a plug or two. EDIT: crap - didn't see that there was a second page of posts. Quote Link to comment Share on other sites More sharing options...
MJLamberson Posted April 3, 2008 Author Share Posted April 3, 2008 Well I figured this one out to, my message for hybridz today is this: "crappy breathers wont allow the any breathing... My cheapo breather got a film of oilish stuff on it and you couldnt even blow though it, I replaced it with the KN style breather and the issue never comes back, thanks for all the advice. Quote Link to comment Share on other sites More sharing options...
