Zetsaz Posted November 18, 2024 Share Posted November 18, 2024 How did you end up mounting it? Quote Link to comment Share on other sites More sharing options...
TrumpetRhapsody Posted November 19, 2024 Author Share Posted November 19, 2024 18 hours ago, Zetsaz said: How did you end up mounting it? Right now it's just sitting in there, since I removed the forward console mounting bracket for weight reduction lol. Eventually I plan to put that back in and solid mount the cage to it. Quote Link to comment Share on other sites More sharing options...
TrumpetRhapsody Posted November 19, 2024 Author Share Posted November 19, 2024 Updates! I found that I was still using the opto-isolator tach input/output circuit with EDIS, as originally suggested by B&G. MSExtra now recommends using the VR circuit, so I swapped to that. I haven't noticed a huge difference, but the placebo effect has me thinking it's running a bit smoother. I'm still having trouble fully eliminating my light ping above 10psi, even with timing pulled back to 15* and running 11.9 afr. I'm worried about EGTs (which I'm not monitoring) if I pull any more timing. I'm starting to wish I'd spent the time on some headwork before reassembling the longblock. Maybe I'll look into installing my methanol kit until I'm ready to take the plunge into E85, but I hate to have to do that temporarily. I just don't know what else I can troubleshoot. I do have a pretty constant miss at idle that I haven't been able to track down, but I can't see how that would have anything to do with my ping. Quote Link to comment Share on other sites More sharing options...
TrumpetRhapsody Posted November 21, 2024 Author Share Posted November 21, 2024 I haven't done a test run yet, but I'm 99% sure I found the cause of my knock "issue". When I made my custom timing indicator I didn't have a good way to verify TDC, so I just eyeballed it based on the cam marks and never circled back. I bought a proper piston stop, and lo and behold I was set at 11* over-advanced . That'll do it. Quote Link to comment Share on other sites More sharing options...
TrumpetRhapsody Posted February 4, 2025 Author Share Posted February 4, 2025 (edited) Black Friday got me GOOD. I picked up MS3 Pro Mini, ProTunerZ 14mm fuel rail and manifold adapters, Deatschwerks 800cc injectors, Radium 10 micron stainless fuel filter, Aeromotive Stealth 340 in-tank retrofit kit, and all the bits to rebuild my soft lines with -8AN PTFE hose. E85 here I come! Over the last two months I pulled my tank to clean and install the in-tank retrofit. I used 1/4" wood blocks to space down the tank for clearance, plus thin pieces of foam on the passengers side so the pump unit wasn't touching the body directly. I had to bend the fuel level sender arm to clear the giant foam baffle. I also replaced the expansion tank hoses to be E85 compatible, using 2 90* fittings to make the u-turn on the 5/8" vent. Back of the car is done, and only had to rework one leaky hose-end! Now on to the front hoses, fuel rail and injectors. I'll tune with the 800cc injectors running 91 for awhile, then eventually rewire for MS3, add a flex fuel sensor, and start tuning for E85. Edited February 4, 2025 by TrumpetRhapsody Quote Link to comment Share on other sites More sharing options...
TrumpetRhapsody Posted May 3, 2025 Author Share Posted May 3, 2025 (edited) Since the last post I swapped in the 800cc injectors and ProTunerz fuel rail, but haven't gotten to re-doing the front lines yet. My idle PW is almost identical, and they seem to actually run smoother. Over time I had developed yet another exhaust leak, so I decided to have a flex coupler welded in and upgrade to a real muffler while I was at it. I'm also going to try the oblong locking exhaust nuts this time, to see if I can stop blowing out the gasket when the stock ones work loose. While the manifolds were off I swapped to my soft wastegate spring, since the hard spring was pushing a minimum of 14-16 which was a bit spicy at part throttle. The new spring wasn't giving me more than 12psi at max dutycycle, so after trying the reversed wg routing and getting a minimum of 18psi, I upgraded to a 4-port MAC boost solenoid. Now I'm able to hold from 6-18psi easily, and at only 60% duty I should have room to push past 20psi once on E85. I also wrapped my downpipe, because why not. Next up I need to fabricate some sort of air box and cold air feed, to stop sucking in hot engine bay air during the summer. Eventually I'll get around to wiring in MS3, new seats, roll bar. The list never ends. Edited May 3, 2025 by TrumpetRhapsody Quote Link to comment Share on other sites More sharing options...
TrumpetRhapsody Posted July 17, 2025 Author Share Posted July 17, 2025 (edited) Tisk, late again! Back in early June I took the plunge and ripped out MS2 and EDIS, to completely rewire for MS3 Pro Mini with LS3 COP, a dedicated relay box, flex fuel, dizzy signal from a Jeep CAS for sequential fuel, and more sensors. I ran into some interesting issues. On the MS3 1.6 firmware I found a bug where Fan Control would not work properly on the PWM-Idle output, so I had to run 1.6.2 beta2. Oddly, having swapped to directly feeding MS3 from my crank VR sensor (instead of EDIS), triggering the fan was causing a phantom RPM signal to fire the injectors and coils thinking the engine was starting. I suspect my troubleshooting of that may have fried the firmware on my LC1, so I ended up upgrading to an LC2 which reads much smoother! I still need to figure out what's causing that, but so far I'm not seeing noticeable effects when the fan kicks on and the engine is running. To get my E85/Flex going I still need to cut bend and replumb my engine bay fuel lines through the new sensor, and I haven't wrapped the harness so no pics just yet. Eventually I also need to modify the Jeep CAS to fit the L28 slotted drive so I can get going with sequential. Still, it's running so much smoother on semi-sequential rather than batch mode. The AFR and fuel pressure safety features are also a godsend! Edited July 17, 2025 by TrumpetRhapsody Quote Link to comment Share on other sites More sharing options...
TrumpetRhapsody Posted August 22, 2025 Author Share Posted August 22, 2025 (edited) At long last I finally got my engine bay fuel lines replumbed. Working around the brake lines in a confined space was an adventure, but things look so much cleaner now. It's to the point I need to pull and paint my valve cover, and start dressing things up. It's been interesting watching my fuel temps. I'm definitely going to spend some time seeing how that affects my tune. I have a bit more dialing in to do on pump gas, then I'll swap to E85 and start cranking up the timing. I also got fed up with seeing my voltage go nuts once my alternator was heat soaked, so I decided to finally upgrade from the 280zx 60a to a Powermaster 7294 100a alternator. I went the route of cutting 1.5" off the front of the factory mount, drilling it most of the way for a 10mm bolt, and tapping the backside so I don't have to use a nut. I was already using a turnbuckle for the adjustment, so I'm running the stock belt. I still see a bit of a voltage drop below 800rpm, so I found a 2.125" pulley I'll swap on when it's not 100* out. Edited August 22, 2025 by TrumpetRhapsody 1 Quote Link to comment Share on other sites More sharing options...
Mitchel0407 Posted August 26, 2025 Share Posted August 26, 2025 I suspect the stock alternator on my ’77 280z is dying as the car runs a bit rough on low rpm and the voltage needle bounces around. The battery also won’t charge properly so I bought a new battery to see if this will help but if not I’ll need to replace my alternator as well. Can you make an detailed explanation as to how you wired the new GM style alternator? I found a bunch of information on the mounting of the GM 1 (or 3) wire alternators but not much on the wiring. Quote Link to comment Share on other sites More sharing options...
TrumpetRhapsody Posted August 26, 2025 Author Share Posted August 26, 2025 (edited) 14 minutes ago, Mitchel0407 said: Can you make an detailed explanation as to how you wired the new GM style alternator? The model I mentioned is a 1-wire so it's just a large gauge wire from the + post to the battery, and the factory ground wire for good measure. Awhile back I swapped from the 260z ammeter to the 280z voltmeter but I haven't bothered wiring in the charge light, so the T plug just stays unplugged and tucked away. Edited August 26, 2025 by TrumpetRhapsody Quote Link to comment Share on other sites More sharing options...
