TrumpetRhapsody Posted February 12, 2008 Share Posted February 12, 2008 Well it's getting to the point where I need to bolt my transmission to the engine, and all of that into the car. Only problem is that I lack the hardware to do so. I've asked around some if anyone has spares, but they seem to be a precious commodity. I've checked the service manual to no avail, and searching here proved pointless. You can imagine bolt, size, engine, tranny, etc didn't narrow it down much on here. If no one has any to spare, can I at least get some sizes and specs that I can take to a hardware store to get what i need. Like I said: engine to transmission, motor mounts, tranny mounts... any nuts and bolts needed to insert the engine and tranny into the car. While searching I saw a couple of old threads asking similar questions go unanswered, hopefully mine won't have the same fate. I don't have the luxury of having a hardware store within 30min of my shop to go buy some bolts, test fit, then go back and buy the size that fits. I need a one time purchase run. TIA -Chris Quote Link to comment Share on other sites More sharing options...
sweetleaf Posted February 12, 2008 Share Posted February 12, 2008 Here's a great option. http://stores.ebay.com/Restoration-Stainless Quote Link to comment Share on other sites More sharing options...
TrumpetRhapsody Posted February 12, 2008 Author Share Posted February 12, 2008 That might not be bad as a last resort, but that's a little pricey for some bolts. I'd prefer to hit up a local hardware store to save on cash. I'm doing a budget build here. Thanks for the link though, I might hit that up if I run out of options. Is there not a list of all the bolt sizes for each individual application somewhere? Quote Link to comment Share on other sites More sharing options...
junglist Posted February 12, 2008 Share Posted February 12, 2008 http://www.boltdepot.com/ you could get the tools to measure pitch, length and all that for stuff you can't get answers on. Quote Link to comment Share on other sites More sharing options...
sweetleaf Posted February 12, 2008 Share Posted February 12, 2008 Search, this has been discussed before. Also, hardware stores usually do not have the proper bolts. Try here ----> http://www.mcmaster.com/ Quote Link to comment Share on other sites More sharing options...
TrumpetRhapsody Posted February 12, 2008 Author Share Posted February 12, 2008 sweetleaf said: hardware stores usually do not have the proper bolts. I wondered about that. Yeah I've seen that McMaster link before. I'll poke around there some. I was just hoping to be able to pick this stuff up locally. I suppose I do have two weeks to place an order and have it shipped though. Yeah I tried searching along these lines but the results weren't terribly helpful, like I said. I need to work on using the google search feature more. It yielded a little more help. Quote Link to comment Share on other sites More sharing options...
JSM Posted February 12, 2008 Share Posted February 12, 2008 Which tranny are you bolting up? T5? I've got a turbo motor w/T5 out of the car that I could possibly take the bolts out and measure. I cant do it until this weekend though. Quote Link to comment Share on other sites More sharing options...
TrumpetRhapsody Posted February 12, 2008 Author Share Posted February 12, 2008 I'm pretty sure the bolts are the same for all the Nissan trannys (could be blowing smoke though). I've got the B style 4spd. I've got the length pegged I think. I measured 1.25in into the block, so add another .5in or so for the tranny lip. What I need are the metric sizes, diameter if you will. I'm also pretty sure the bolt grade is 7 (had 7 stamped into one of the motor mount bolts). Thanks for the help. This is probably pretty pitiful of a request but I'm not having much luck finding what I need. Quote Link to comment Share on other sites More sharing options...
wickiewicked240z Posted February 13, 2008 Share Posted February 13, 2008 what I found is 3 M10x1.5 bolts that are about 2 1/2 inches and one 2 inch M10x1.5 bolt Quote Link to comment Share on other sites More sharing options...
TrumpetRhapsody Posted February 13, 2008 Author Share Posted February 13, 2008 Good to know. I'll grab a bulk of various M10X1.5 bolts and nuts. What about from the motor mount into the engine bay mount. The bolt there is smaller... Quote Link to comment Share on other sites More sharing options...
ktm Posted February 13, 2008 Share Posted February 13, 2008 sweetleaf said: Search, this has been discussed before. Also, hardware stores usually do not have the proper bolts. Try here ----> http://www.mcmaster.com/ Ace and True Vaue hardware stores do have the proper Class 10.9 (SAE Grade 8.8) bolts if you know what to look for. However, they do not carry some of the longer bolts that are necessary, such as the bell housing to block bolts. Quote Link to comment Share on other sites More sharing options...
TrumpetRhapsody Posted February 13, 2008 Author Share Posted February 13, 2008 ktm said: However, they do not carry some of the longer bolts that are necessary, such as the bell housing to block bolts. Shoot, those are the main ones i'm concerned about. What about like Autozone or O'Rileys? Am I just going to have to break down and order a kit? It's starting to look that way. Quote Link to comment Share on other sites More sharing options...
mom'sZ Posted February 13, 2008 Share Posted February 13, 2008 here's a link to a thread where the bellhousing bolt sizes are discussed http://forums.hybridz.org/showthread.php?t=115555&highlight=engine+stand Quote Link to comment Share on other sites More sharing options...
TrumpetRhapsody Posted February 13, 2008 Author Share Posted February 13, 2008 Bellhousing... there's a search term I didn't use! Thanks! Quote Link to comment Share on other sites More sharing options...
2eighTZ4me Posted February 13, 2008 Share Posted February 13, 2008 I think the bolts that bolt the motor mounts to the rubber insulator mounts on the crossmember are 8x1.25 and they're about an inch long. Quote Link to comment Share on other sites More sharing options...
TrumpetRhapsody Posted February 13, 2008 Author Share Posted February 13, 2008 Excellent, excellent. I may grab about 10 of each to take out weekend after next if I haven't found someone selling a set. Quote Link to comment Share on other sites More sharing options...
TrumpetRhapsody Posted February 13, 2008 Author Share Posted February 13, 2008 Made a run to "Fastenal" today to see about picking up some bolts. This is pretty much all they had. Nothing with full threads, no full thread 8mm 1.5's. I think I may make a call to that Z junkyard in big-phil's video and see if he'd ship me the bolts I need. Quote Link to comment Share on other sites More sharing options...
TrumpetRhapsody Posted February 13, 2008 Author Share Posted February 13, 2008 Well that was easy. I should've done that days ago. He even thought of some bolts I forgot I needed. Driveshaft bolts, etc. Case closed. Quote Link to comment Share on other sites More sharing options...
