Head gasket/deck height
Currently the engine is at the builder and he told me that the piston is SLIGHTLY above the deck (#6) by .003.
Block was decked but the builder did not request that it be zero decked.
Solution is to use a Felpro head gasket #1144-061 (or -053) to resolve any possible issue of piston interference.
Engine internals:
Eagle 4340 Forged Steel Steel Internal balance
2pc rear main seal 3.75†crank
Mahle Forged Racing Pistons 11:1 (.040 over bore)compression ratio Phosphate Dipped and Teflon Coated
6†Eagle ESP 4340 Forged Steel H Beam Rods with ARP 8740 Bolts
Mahle Moly Racing Performance Ring Set
King Race Bearings Rods and Main
ARP main studs
ARP head studs
My questions are:
Is this normal for the piston to protrude out of the bore?
If I use this gasket, is it made for the .040 overbore
Can anybody source these gaskets cheaper or recomend an alternative as these are expensive at $80 EACH!!!
Thanks,
David
When a block has been decked, sometimes pistons can wind up above the deck. It's really not a big deal unless it's excessive, and 0.003" isn't enough to worry about.
That gasket has a 4.2 bore and is 0.061" thick compressed, way overkill IMO. It's expensive and you lose all the quench benefits.
I would use one of the 0.041 felpro gaskets, like the 1003. That will give you a quench distance of 0.038, which is just about perfect. If you want a little more, Ferrea makes a 4.060 bore 0.045 thick head gasket which is very nice. You can get them from CV Products.
John
John
Basically what I would have suggested, I just wouldn't have had any part numbers.
On most engines the general concensus seems to be about .040" quench distance as being good. On a race only engine, a tighter quench could be used, but requires very CAREFUL assembly and measuring process.
This is usually something (for a street engine) to err on the side of slightly too much quench distance instead of not enough.
I do agree .003" piston hight above the deck isn't much to worry about.
Measure the piston installed-height once the rotating assembly is together. In my engine I specified +0.001" installed height (piston above deck by 0.001") but in reality the flat part of the piston is at -0.004". These are mid-grade hypereutectic pistons, with significant graininess and unevenness on the flats.
When I applied clay to the piston to check quench gap and piston-cylinder gap, well, upon unbolting the heads the depth of the clay was 0.015" more than I expected from my calculations. Part of that may be elastic spring-back of the clay after the head bolts were untorqued.
Bottom line: small tolerances do matter when the gaps get close, but even a moderately large tolerance stackup should (I hope!) be OK when gaps are relatively large. My quench gap came out to 0.055" - while I was shooting for 0.040". The price, I suppose, is a slight decrease in combustion efficiency and concommittant increase in required timing advance.
Getting piston deck heights to come all within 0.003 or 0.004 of each other is pretty difficult. I'd go with the 0.038" as your smallest piston-to-head clearance and be very happy! That's about ideal!
I've had the tops of pistons cut down a few thous. to bring everything close using stock rods. With aftermarket rods, and pistons, it's usually easier though. I've also been known to take a few thousandths off the top of a piston myself, using a lot of checking (relative to the ring lands, valve pockets, etc.) by using sandpaper and a figure 8 motion. It takes a long time. That was because I had a piston that was 0.004" higher than all the others and it bugged me. I probably could have left it alone :).
