strange knock at low rpm's
bakerzxt
i have a 83 zx turbo and i hear a knock/tapping noise when i am sitting at a light and if i rev it up a little the knock/tap gets faster and louder and if i rev it up past 2000rpm it goes away but the knock/tap always comes back. sometimes i can hear it if i am cruising around at low rpms as well but it always silences when the rpms are over 2000-2500. i know that my oil is ok i have checked that numerous times and it isnt an engine knock. i think it could be either a valve tap or the timing chain is tapping against the timing chain cover. i am not sure. i have searched all of the above and found some info on the timing chain and that sometimes they stretches. so if anyone has some info on what you think it can be and what i should do about it. i know that if is the timing chain i need to get it fixed as soon as possible. thanks
Old school shade tree check. Start you engine and let it idle pull one plug wire at a time. If the knock goes way on you have a bad rod on that cylinder. A cracked piston can also be check this way.
