Bolt size for crankshaft pulley on S130s?
PhilbertZ
I was doing a plug change and was planning to adjust the valves while I was at it. I had everything ready to go, but when it came time to bring the first cylinder to TDC, I had a rude awakening.
First, the crankshaft pulley was pretty darn hard to reach from above, so I had to put the car up, remove the skid plate, lower fan shroud, and get under it...then, I realized that I didn't have a socket large enough for the bolt! I tried 1 inch and 22mm sizes - not even close! After about an hour of trying everything I had from hands to pliers (and lots of patience), I gave up.
Does anyone here know the exact bolt size for this guy so I can get the right socket and take care of this?
Am I missing something here that would have made it easier? I had the plugs all out so compression shouldn't have made an impact on the progress, right?
Thanks in advance!
  (goldfish) said:
27mm, but I'm able to spin the engine by the damper by hand with all the plugs out.
Thanks guys for the replies.
Goldfish - what "damper" are you referring to? Have a photo or can you please explain what it is and how to turn it? I tried manually with my hands and a rag, with all the plugs out. but nothing budged...
just the crank pulley. Stupid question but was it in neutral?
Perhaps loosen off the belts too.
