Valve to piston clearence l28et
Ok I've searched a bit and can't find this tidbit.
On the turbo engine, w/dished pistons, p90a head, will the valves clear if the chain brakes?
Or initial setup if timeing is off?
Can't remember the term positive/negative impact?
I personally have never seen a chain break, although have heard of it. Problem with making a motor non interfearence is that you give up detonaiton resistance as well as burn traval rate, etc. Install a good chain, and it will last.
