S130Z Posted May 19, 2008 Share Posted May 19, 2008 i have a S130 83 280zx and i upgraded to a n42 intake with a 60mm TB. now the motor shakes and idles rough. it smokes and i believe it is runnig rich. i need some advice as to what might have gone wronge. its my DD and i have not had it running for more than a week. Quote Link to comment Share on other sites More sharing options...
zmaster Posted May 19, 2008 Share Posted May 19, 2008 Adamsilver said: i have a S130 83 280zx and i upgraded to a n42 intake with a 60mm TB. now the motor shakes and idles rough. it smokes and i believe it is runnig rich. i need some advice as to what might have gone wronge. its my DD and i have not had it running for more than a week. This is what I have been told.....Locate on the engine, where the top radiator hose connects to the engine. wiggle the temperature sender connector. most likely it has been sitting a while, and the connections have corroded a little bit. try that and start your engine. This should fix the problem you are havinng with your car. "NOTE" ( I would not recomend doing this while the car is running, your hand will be too close to the fan blade on the engine, and you can get seriously injured.) Quote Link to comment Share on other sites More sharing options...
S130Z Posted May 19, 2008 Author Share Posted May 19, 2008 i tried that several times with no luck. it is running alot worse now. i took it for a test run because i hoocked up a lost vac line and it seemed like it ran a lot better but during the test it still had no power.i had a large puff of black smoke for a minute and now it hesitates to start and idles a lot lower. Quote Link to comment Share on other sites More sharing options...
jtmny1999 Posted May 19, 2008 Share Posted May 19, 2008 What you do with your AAC valve? looks like you have a vaccum leak. if you removed the AAC valve you need to adjust the idle with the screw on the 60mm TB. Quote Link to comment Share on other sites More sharing options...
zmaster Posted May 19, 2008 Share Posted May 19, 2008 that would have been my second thought is a vacuum leak, or your temperature sender could be bad. a new one is about 15 bucks at the auto store. Quote Link to comment Share on other sites More sharing options...
S130Z Posted May 20, 2008 Author Share Posted May 20, 2008 i had a vac leak when i first put it on. i fixed that. i put my aac back on with a few mods to the tb spacer. i pulled my spark plugs that i put on at the same time as the intake and thay were all black. i cleaned them but dont think that that helped. i had the car running and unplugged 4 of the 6 plugs after i cleaned them and the car ran the same as with all them on. but when i pulled the cylinder closest to the fire wall the car stalled out. and i know i am gettting spark through the wires cuz they shocked me soo bid i bled. Quote Link to comment Share on other sites More sharing options...
zmaster Posted May 20, 2008 Share Posted May 20, 2008 Dude I have been shocked a few times by the ignition system before, and that isn't the best feeling in the world....on top of that i think it could kill you if your not carefull. Be safe, and use a spark plug wire puller. it reduces the chance of shock. Also check you timing. Quote Link to comment Share on other sites More sharing options...
woldson Posted May 20, 2008 Share Posted May 20, 2008 Hummm something is odd here. Put back on the original tb and give us some pics please. Quote Link to comment Share on other sites More sharing options...
S130Z Posted May 20, 2008 Author Share Posted May 20, 2008 the throttle body is not the problem. i noticed oil leaking form my head so im pretty sure its a blown head gasket. the only thing i am wondering is how i blew my head gasket immediatly after changing to the n42 intake. i have all the original vacs and sensors hooked up so im pretty baffled Quote Link to comment Share on other sites More sharing options...
woldson Posted May 21, 2008 Share Posted May 21, 2008 So what dose the comprssion test tell you? Quote Link to comment Share on other sites More sharing options...
S130Z Posted May 21, 2008 Author Share Posted May 21, 2008 i just ran the compression test and all my cylinders sat at around 140psi. the last time i checked them they sere at 178psi Quote Link to comment Share on other sites More sharing options...
woldson Posted May 21, 2008 Share Posted May 21, 2008 Post a viedo of said problem. You have a problem for sure, I dought your engine is all of a sudden crap. Spend your money on fixing what is in front of you, that knowlage will help you for ever. Quote Link to comment Share on other sites More sharing options...
280zx 2by2 Posted May 22, 2008 Share Posted May 22, 2008 try taking off the filter and play with the throttle and see what happens only thing else i can think of is a ring failing but you have the same compression so DO YOU HAVE ANY OIL IN THE CAR? that was to sound dramatic Quote Link to comment Share on other sites More sharing options...
S130Z Posted May 22, 2008 Author Share Posted May 22, 2008 i do have oil in the car. i checked it before i checked the compression. the oil smelled really bad, not like regular oil smell, i almost threw up. i am about 100 miles past my oil change mileage though. Quote Link to comment Share on other sites More sharing options...
woldson Posted May 22, 2008 Share Posted May 22, 2008 I assume you are a male by trade, so with this in mind did someone pour liquid throw up crud into you oil? Now before helping you any more, how much experience do you have in automotive? Quote Link to comment Share on other sites More sharing options...
S130Z Posted May 22, 2008 Author Share Posted May 22, 2008 i have enough experience to rebuild a carborated motor. i am enrolled at NTI but dont start till october. i took a semester class in basic automotive repair. Quote Link to comment Share on other sites More sharing options...
woldson Posted May 22, 2008 Share Posted May 22, 2008 You have come to the right place to learn, have searched efi bible? Quote Link to comment Share on other sites More sharing options...
S130Z Posted May 22, 2008 Author Share Posted May 22, 2008 i have not searched the efi bible, is it online or a book? Quote Link to comment Share on other sites More sharing options...
zmaster Posted May 23, 2008 Share Posted May 23, 2008 its online go to google, and type in datsun efi bible. you should be able to find it then. Quote Link to comment Share on other sites More sharing options...
S130Z Posted May 23, 2008 Author Share Posted May 23, 2008 i pulled the connectors off the fuel injectors one by on and the only cylinders that seemed to be effected by this was numbers 1 and 4 Quote Link to comment Share on other sites More sharing options...
