PanzerAce Posted May 31, 2008 Share Posted May 31, 2008 I know that noone does this swap for the gas savings, but what mileage are you guys getting with your RB swaps? Quote Link to comment Share on other sites More sharing options...
rbs30 Posted May 31, 2008 Share Posted May 31, 2008 I know that noone does this swap for the gas savings, but what mileage are you guys getting with your RB swaps? Depends. I have a standard r32 gtr that gets 14L/100kms or i have an RB30det 240z with a lot of goodies on it that gets nowhere near that. Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted June 1, 2008 Share Posted June 1, 2008 I got right at 30mpg driving the 1,200 miles to this years DNI event and back. I have not really tried to determine the day to day driving mileage, but if I had to guess, I'd say 18 to 22 mpg.... Quote Link to comment Share on other sites More sharing options...
Cal Poly Zmanaustin Posted June 1, 2008 Share Posted June 1, 2008 I got right at 30mpg driving the 1,200 miles to this years DNI event and back. I have not really tried to determine the day to day driving mileage, but if I had to guess, I'd say 18 to 22 mpg.... This is interesting. What size injectors are you running and how much timing are you running? Are you running stoich at cruise 14.7:1 or are you running even leaner like 17:1? Oh, and what rear end ratio? 4:11? Someone before said they were getting like 35mpg all stock, but that was running 3.36 gears. I think this would give me a better idea relative to mine. Thanks. Quote Link to comment Share on other sites More sharing options...
tokesGTR Posted June 1, 2008 Share Posted June 1, 2008 I can't imagine how sluggish an RB26/25 would feel with 3.26 gears. 4.111's are stock in R32's, and that feels just about right. Maybe just slightly too short on the highway, but that's about it. FWIW, my R32 GTR with basic mods (full exhaust, apex'i intake pods, tuned ECU, boost restrictor pulled) will get 15-17 MPG in the city and maybe 23-24 on the highway if I stay around 110 and don't get into boost at all. Amazing what a couple hundred pounds does for a cars fuel efficiency. Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted June 1, 2008 Share Posted June 1, 2008 This is interesting. What size injectors are you running and how much timing are you running? Are you running stoich at cruise 14.7:1 or are you running even leaner like 17:1? Oh, and what rear end ratio? 4:11? Someone before said they were getting like 35mpg all stock, but that was running 3.36 gears. I think this would give me a better idea relative to mine. Thanks. My inj's are 72lb and the timing I believe is around 38 deg at cruise (I'd have to check on that). The afr's were at around 14:9 to 15:2 under vacuum at cruise. The rear end is the 88ss 3:7 VLSD with the rb25det trans. Quote Link to comment Share on other sites More sharing options...
ww Posted June 1, 2008 Share Posted June 1, 2008 Isn't that still a pretty tall final drive ratio with the RB25DET tranny? We ended up putting 4.38's in my friends RB25DET powered 240Z and I was planning to put my Quaife into an R200 with at least 3.90's and possibly 4.10's. Quote Link to comment Share on other sites More sharing options...
ZDrifter Posted June 1, 2008 Share Posted June 1, 2008 This is interesting. What size injectors are you running and how much timing are you running? Are you running stoich at cruise 14.7:1 or are you running even leaner like 17:1? Oh, and what rear end ratio? 4:11? Someone before said they were getting like 35mpg all stock, but that was running 3.36 gears. I think this would give me a better idea relative to mine. Thanks. I think your talking about me...But I have 3.63's. On the highway the best I got was 35mpg and around town probably anywhere around 22-26 depending on how I drive I would like to go up to 3.90's though. I ran a 13.6@105mph at the track with 3.63's. I would like to see what it would be with the gearing change. Oh and by the way on the highway at 70mph Im at about 2700rpm. On the dyno in 4th gear I got up to 147mph. Quote Link to comment Share on other sites More sharing options...
Racinjitter Posted June 4, 2008 Share Posted June 4, 2008 Stock fuel mileage for my S1 rb25det is 30mpg on the highway... Didnt calculate city driving. That is with a 3.7 CLSD. Quote Link to comment Share on other sites More sharing options...
Pyro Posted June 4, 2008 Share Posted June 4, 2008 I think your talking about me...But I have 3.63's. On the highway the best I got was 35mpg and around town probably anywhere around 22-26 depending on how I drive I would like to go up to 3.90's though. I ran a 13.6@105mph at the track with 3.63's. I would like to see what it would be with the gearing change. Oh and by the way on the highway at 70mph Im at about 2700rpm. On the dyno in 4th gear I got up to 147mph. What rear end are you using that is a 3.63 ratio?? Quote Link to comment Share on other sites More sharing options...
Careless Posted June 5, 2008 Share Posted June 5, 2008 What rear end are you using that is a 3.63 ratio?? prolly a 3.36 from the 76 280z 2+2. Quote Link to comment Share on other sites More sharing options...
ZDrifter Posted June 6, 2008 Share Posted June 6, 2008 Sorry I meant a 3.53 which is the stock R200 gearing correct?? I havent dug into my rear end so Im guessing thats what I have for a stock 1978 R200 Quote Link to comment Share on other sites More sharing options...
Pyro Posted June 6, 2008 Share Posted June 6, 2008 typically called a 3.54 39:11 = 3.545 Quote Link to comment Share on other sites More sharing options...
Evan Purple240zt Posted June 7, 2008 Share Posted June 7, 2008 I get low 30s on the highway in my 240sx. Round town, leadfoot mcgee gets high teens. Its not tuned all that well for economy honestly. Lots of stop and go. Evan Quote Link to comment Share on other sites More sharing options...
mrcheeze36 Posted June 7, 2008 Share Posted June 7, 2008 prolly a 3.36 from the 76 280z 2+2. Actually its the 74' 260Z 2+2 with the 3.36. Quote Link to comment Share on other sites More sharing options...
Z-Monster Posted June 7, 2008 Share Posted June 7, 2008 Guys i get 22mpg here on 97 octain gas in Malaysia. this is mostly bumper to bumper town driving and occasional highway boosting. i'm running on a TO4S turbine @ 1 bar or boost, 4.11 final drive on my R200 MLSD, stock rb25det 5 speed gearbox, SR20 injectors 450cc, with 375WHP. i have clocked close to 30mpg on highway cruzin b4 with the same set up. Quote Link to comment Share on other sites More sharing options...
Careless Posted June 7, 2008 Share Posted June 7, 2008 Actually its the 74' 260Z 2+2 with the 3.36. good call Quote Link to comment Share on other sites More sharing options...
Wedge Posted July 15, 2008 Share Posted July 15, 2008 Funny how an SR20DET is rated at around 25 mpg higway ? Quote Link to comment Share on other sites More sharing options...
