~KnuckleDuster~ Posted June 1, 2008 Share Posted June 1, 2008 I attempted to seach for this and didn't come up with anything. When shifting and or abruptly letting off the gas I get a loud knock from the rear. It will do it on and off but it seems worse when cold.. any ideas or suggestions? This is on a 71 TIA -Adam Quote Link to comment Share on other sites More sharing options...
TravRMK Posted June 1, 2008 Share Posted June 1, 2008 Check your u-joints. Quote Link to comment Share on other sites More sharing options...
quicker240 Posted June 2, 2008 Share Posted June 2, 2008 Ck your diff front mount.I say you broke it. Quote Link to comment Share on other sites More sharing options...
Hopelessly Confused Posted June 2, 2008 Share Posted June 2, 2008 I second travrmk''s advice. I had the same problem with my '75 280 and it ended up being the u-joint on my half-shaft. Quote Link to comment Share on other sites More sharing options...
~KnuckleDuster~ Posted June 2, 2008 Author Share Posted June 2, 2008 I second knuckleduster's advice. I had the same problem with my '75 280 and it ended up being the u-joint on my half-shaft. Remember how much it cost to fix? Quote Link to comment Share on other sites More sharing options...
Challenger Posted June 2, 2008 Share Posted June 2, 2008 First check your u joints like travis said. I had the same knocking noise and it turned out the driveshaft u joint was shot. Quote Link to comment Share on other sites More sharing options...
~KnuckleDuster~ Posted June 2, 2008 Author Share Posted June 2, 2008 Cool, Thanks for the replies guys Quote Link to comment Share on other sites More sharing options...
Hopelessly Confused Posted June 2, 2008 Share Posted June 2, 2008 Sorry knuckleduster, I can't help you with price. I just pulled a good half-shaft off my parts car. Quote Link to comment Share on other sites More sharing options...
woldson Posted June 2, 2008 Share Posted June 2, 2008 I believe it was quite cheep, around $40 for joints and someone to remove them. I did the joints on my 82. When I had them in a 20 ton press to remove the joint I had to lay into it kinda hard than BOOOM parts went flying eveywhere! I finished the shaft my self and had a diesal place do the other. Luckly there was no damage to the yoke. Outside of it been slow to pull the half shafts its not too bad, and dose not have to be done offen. Quote Link to comment Share on other sites More sharing options...
AK-Z Posted June 3, 2008 Share Posted June 3, 2008 could also mean that you need new bushings for the front diff mount. Quote Link to comment Share on other sites More sharing options...
mannyvig Posted June 3, 2008 Share Posted June 3, 2008 I have driven in that car just a dew days before you bought it and I know for a fact that it is the front diff mount. Quote Link to comment Share on other sites More sharing options...
m4xwellmurd3r Posted June 3, 2008 Share Posted June 3, 2008 i've got a busted diff mount too i bet. actually it just needs new bushings all around. I can't jack the car up from the diff because the diff just lifts up. in lower gears if I gun it too hard it'll knock too hahaha Quote Link to comment Share on other sites More sharing options...
pch Posted June 9, 2008 Share Posted June 9, 2008 Have you check those straps/mounts I told you about. Check the link to arizonazcar Quote Link to comment Share on other sites More sharing options...
