lsd price?
1 tuff z
David,
Used open R200 diffs go between $100.00 to $300.00 depending on condition. Motorsport Auto sells the Nismo limited slip assemblies to install in a R200 for ~$750.00.
Hope this helps.
Ruben
'72 240Z
I saw these LSDs in their catalog, and the 45 lb/ft breakaway torque seemed a little "loose" to me. Is this a normal or good setting? Also, is the Quaife LSD a worm gear (can't remember the correct name for this type in my old age) or clutchless type of carrier?
Mike is correct the Quaife is a worm gear (Gleason Torsen) type LSD.
I seem to recall reading a post from John Coffey indicating that the 45 lb/ft breakaway for the Nismo unit is an old recommendation and too low, at least for autocross. Nissan Motorsport recommends 70 lb/ft breakaway which takes into consideration the better tires that are available nowdays.
Nissan Comp still recommends 45 ft. lb. breakaway. Ron Johnson "suggests" a higher breakaway torque number for high horsepower and autocross applications. I ran 70 ft. lb. in mine.
Autocross is very hard on clutch type LSDs. If you campaign a full season you can expect to rebuild the LSD once a year. But, since I bought my Quaife in 1999 I don't have to worry about that stuff!
quote
Reider racing sells limited slips for $450 for the 12mm ring gear r200.
Do they still have them available? I thought it was just posted last week that they're no longer available thru Reider? John, do you know what one should expect to pay to have gears setup? ie. buying a clutch or quaiffe posi and having unitrax set it up with gears etc should cost approximately how much?
