bens1088 Posted August 14, 2008 Share Posted August 14, 2008 So the engine was getting extremely hot, pulled the thermostat to see that it looked like it was at the bottom of the ocean for the last 30 years. In the process, two bolts snapped. I reversed drilled them to only dig myself into more problems. I cleared one, but need to tap it/rethread it. The other one has half a bolt in it cut straight down the middle. I said screw it i'll just pull the thermostat housing. I pulled the first bolt no problem, second one ...of course....snapped... its a 79NA, never had a rebuild. I am contemplating a swap now but I am in CA (smog ) Anyone have any suggestions? Ive never swapped an engine but id love to learn. what do i do?! Quote Link to comment Share on other sites More sharing options...
JSM Posted August 14, 2008 Share Posted August 14, 2008 Those can have a tendency to do that. I'd work on just getting the bolt out. No need for an engine swap unless your really unhappy w/ it. Quote Link to comment Share on other sites More sharing options...
bens1088 Posted August 14, 2008 Author Share Posted August 14, 2008 alright im just not gonna worry about the thermostat housing bolt its not going anywhere ill just try and rethread the others Quote Link to comment Share on other sites More sharing options...
JIM73240Z Posted August 14, 2008 Share Posted August 14, 2008 i had a bolt strip out the treads in the housing. i just drilled bigger and tapped it. while you are doing all of that, take the radiator out and get it rodded. i chased my overheating engine for several weeks only to find it at the last place i looked, the radiator. from the cap it looked good and clean. i guess not on the inside. good insurance anyway. jimbo Quote Link to comment Share on other sites More sharing options...
woldson Posted August 14, 2008 Share Posted August 14, 2008 Seen a few with bolts missing there. I think my 82 was like that:). If I change my thermostat again I will use some anti-seize. Quote Link to comment Share on other sites More sharing options...
MJLamberson Posted August 14, 2008 Share Posted August 14, 2008 Yeah mine did that too, strip/break no matter how cautious you are... Quote Link to comment Share on other sites More sharing options...
Xnke Posted August 14, 2008 Share Posted August 14, 2008 Hmmm... I've pulled 4-5 thermostat housings in junkyards and never once broken a bolt...of course, there were '72 units...age difference? Quote Link to comment Share on other sites More sharing options...
bens1088 Posted August 15, 2008 Author Share Posted August 15, 2008 lol consider yourself lucky then Quote Link to comment Share on other sites More sharing options...
Tony D Posted August 15, 2008 Share Posted August 15, 2008 These parts are availabe new from the Nissan Dealer as well. They are not as expensive as many people think... Quote Link to comment Share on other sites More sharing options...
