slownrusty Posted November 9, 2008 Share Posted November 9, 2008 Hi Gang - I need to purchase a new Engine Coolant Temp Sensor for my L28ET. This is the one that goes to the ECU not the gauge, it sits closes to the head in the bottm half of the thermostat housing and has a bullet connector and 3/8 NPT threads. The green pigtail wire that comes out of the sensor on mine completely broke off. It looks like this: Mine.. Courtesy Nissan keep wanting to sell me the NA version (thermotime sensor with the double wire connector) which looks like this and they say they do not have a listing for the single wire engine coolant temp sensor that came on the L28ET (??): I also tried NAPA and they were no help, they wanted to sell me the same sensor as Courtesy. Can any of you help please? Scratching my hair on this one. Many Thanks - Yasin Quote Link to comment Share on other sites More sharing options...
Administrators RTz Posted November 9, 2008 Administrators Share Posted November 9, 2008 Hi Yasin, The early cars (pre '80) had the water temp sensor in the lower T-stat housing. In that application, the 33001 sensor Courtesy is trying to sell you would be correct. Later cars (P79/P90) have the sensor at the base of the head, at the rear of cylinder 5, passenger side. Nissan changed the name to cylinder head temp. It serves the same functional purpose as the water temp. sensor. It differs slightly from the 33001 due to being a 'dry' sensor. I don't have that part number handy, but could dig it up if you need it. Sooo, If the problem you're trying to solve is the broken wire... that is a water temp switch and, if memory serves, it runs the injector cooling fan in your application. If I get time later, I'll dig through the schematic to verify that's the only thing it runs. Quote Link to comment Share on other sites More sharing options...
woldson Posted November 9, 2008 Share Posted November 9, 2008 83 turbo 82 n/a My n/a also has a vaccume thingy down below those 3 sensors. Some day I'll have to figure out what it is for. Quote Link to comment Share on other sites More sharing options...
Careless Posted November 9, 2008 Share Posted November 9, 2008 i found this: ACDELCO Part # E1884 {#19022029} SENSOR,ENG COOL T/GA with BLADE TERMINAL; EXC. DIGITAL DASH http://198.208.187.182/servlet/com.entigo.acdelcocatalog.servlet.ProcessImageServlet?languagecd=EN&countrycd=US&user=InternetUser&mfgname=null&prodlinecd=null&acpartnbr=E1884 and this: AIRTEX Part # 1T1181 w/o Digital Gauge and this: AIRTEX Part # 1T1182 GL Model w/Digital Gauge and this: STANDARD MOTOR PRODUCTS Part # TS69 {TEMPERATURE SENDING UNITS} with Mechanical Dash or STANDARD MOTOR PRODUCTS Part # TS495 {TEMPERATURE SENDING UNITS} with Digital Dash Quote Link to comment Share on other sites More sharing options...
Careless Posted November 9, 2008 Share Posted November 9, 2008 i realize the bottom ones have no thread and might be slim-fit so that an open-ended pipe fitting can be place around it and sealed with teflon tape and thread sealer as well as thermostat silicone. Then the hilt on the sensor will abutt the pipe fitting so that it does not back out or leak. at least that's what it looks like anyhow. Quote Link to comment Share on other sites More sharing options...
Careless Posted November 9, 2008 Share Posted November 9, 2008 Yasin, Disregard the part numbers above, here is what you need: RED is the Thermotime Switch (as ron suggested, and it is what you're looking for), and it is to control the rad-fan, I believe. The GREEN is for the ECU, and it is the Temperature sensor. Use the numbers on the Diagram to cross-ref the numbers on the second column of the parts-list. Quote Link to comment Share on other sites More sharing options...
Careless Posted November 9, 2008 Share Posted November 9, 2008 it could be that it runs the Rad fan if there is one, or the Injector fan as ron indicated. Quote Link to comment Share on other sites More sharing options...
hughdogz Posted November 9, 2008 Share Posted November 9, 2008 I used the CHTS for my Wolf install. I think Bo (KTM) used the coolant temp sensor located in the thermostat housing, and he's logging the CHTS as reference. Ron says the two sensors have the same voltage versus temperature curve. [Edit: I was trying to say you want a sensor, not a switch for the ECU] Quote Link to comment Share on other sites More sharing options...
Administrators RTz Posted November 9, 2008 Administrators Share Posted November 9, 2008 Well this is getting out of hand now, isn't it? It is not a Thermo-time switch. The thermo-time is for the cold start injector.... L28ET's didn't come with a cold start valve, nor the switch. It is not a water temp. sensor of any kind. It has nothing to do with ECU function. It is a water temp. switch. It's part of the auxiliary injector cooling fan and auxiliary radiator fan circuit. Yasin, I spent a little time with the schematic. The switch does nothing else. You've removed the fans, so the switch no longer serves a purpose. Quote Link to comment Share on other sites More sharing options...
slownrusty Posted November 9, 2008 Author Share Posted November 9, 2008 Ron - Wow...many many thanks for doing the research for me!! I *so* greatly appreciate it. Here I was thinking all along that it was a critical sensor for me to replace! I really need to just remove the factory EFI and install my standalone! Many thanks to all that chimed in. My best - Yasin Quote Link to comment Share on other sites More sharing options...
jacob80 Posted November 9, 2008 Share Posted November 9, 2008 One question. I know that 2 wire sensors are much better than one wires, so would the head temp sensor threaded into the head work better with megasquirt than the one-green wired sensor on the thermostat housing? Quote Link to comment Share on other sites More sharing options...
Administrators RTz Posted November 10, 2008 Administrators Share Posted November 10, 2008 jacob80 said: One question. I know that 2 wire sensors are much better than one wires, so would the head temp sensor threaded into the head work better with megasquirt than the one-green wired sensor on the thermostat housing? One LAST time... rontyler said: It is not a water temp. sensor of any kind. It is a switch. Period. Quote Link to comment Share on other sites More sharing options...
Careless Posted November 10, 2008 Share Posted November 10, 2008 sorry r0nz. got carried away with my clicky finger and Nissan FAST. I guess a BSPT plug should be the best replacement, in Yasin's case, for this "sensor"... *teehee!* Quote Link to comment Share on other sites More sharing options...
