kcambron Posted December 21, 2008 Share Posted December 21, 2008 Will a 1975 trans x member work on my 1973? I'm putting in a "stock" 5 speed from a 1981 280zx. I'm to the point of welding in new floor pans and I would like to brace up the trans tunnel area (my 73 project didn't have a trans xbrace in it). Thanks to all the guys have helped on this site, the amount of knowledge and fab skill floating around here is pretty amazing. Quote Link to comment Share on other sites More sharing options...
z-ya Posted December 23, 2008 Share Posted December 23, 2008 No, I don't think you can use a 280Z cross member in a 240Z. The 240Z cross member bolts upward into captured nuts in the mounting points. The 280Z one uses long bolts that mount horizontally with nuts. Quote Link to comment Share on other sites More sharing options...
rags Posted December 23, 2008 Share Posted December 23, 2008 73 will bolt the same as a 280, horizontal bolts. I think only the Series 1 cars use the vertical mounting bolts. Joe Quote Link to comment Share on other sites More sharing options...
z-ya Posted December 23, 2008 Share Posted December 23, 2008 Joe, My late 72' has vertical bolts. Pete Quote Link to comment Share on other sites More sharing options...
rturbo 930 Posted December 23, 2008 Share Posted December 23, 2008 Joe, My late 72' has vertical bolts. Pete Strange, IIRC, my early '72 has vertical bolts. Quote Link to comment Share on other sites More sharing options...
rags Posted December 23, 2008 Share Posted December 23, 2008 Pete, Very weird! I've never seen a series II with vertical bolts. Joe Quote Link to comment Share on other sites More sharing options...
z-ya Posted December 23, 2008 Share Posted December 23, 2008 My late 71' (aka, the work bench), the club car (mid 72'), and my Silver 240Z (June 72') all have vertical bolts. Pete Quote Link to comment Share on other sites More sharing options...
ktm Posted December 23, 2008 Share Posted December 23, 2008 Just to chime in, my 5/72 build 240z has vertical bolts. Quote Link to comment Share on other sites More sharing options...
rags Posted December 23, 2008 Share Posted December 23, 2008 Ok so to completely throw any sort of logic to when the mounting position changed from verticle to horizontal, who has a 73 with vertical bolts? Quote Link to comment Share on other sites More sharing options...
rturbo 930 Posted December 23, 2008 Share Posted December 23, 2008 Wait a sec, I think I've misinterpreted. This is a pic of the mounts on my 240z. My 280z looks the same (well, with less rust). Are these the horizontal or vertical mounts? Seems pretty vertical to me, but I was thrown off since you mentioned the 280z uses horizontal bolts. Maybe it's the 77-78 280zs only? Quote Link to comment Share on other sites More sharing options...
rags Posted December 23, 2008 Share Posted December 23, 2008 That's the engine crossmember. I was referring to the trans crossmember. I believe all of the engine crossmembers mount the same. Joe Quote Link to comment Share on other sites More sharing options...
rturbo 930 Posted December 23, 2008 Share Posted December 23, 2008 That's the engine crossmember. I was referring to the trans crossmember. I believe all of the engine crossmembers mount the same. Joe Oh. It appears I can't read today. My bad. Anyways, now that that's cleared up, 240z has vertical bolts, 280z has horizontal bolts. 240z is a 11 or 12/71, 280z is a 1/76. Quote Link to comment Share on other sites More sharing options...
kcambron Posted December 24, 2008 Author Share Posted December 24, 2008 Sooo, my 73 has horizontal bolts, will say,a 1975 trans x member work with a non turbo 5 speed? Quote Link to comment Share on other sites More sharing options...
Dayz Posted December 24, 2008 Share Posted December 24, 2008 I can't help you out with the transmission but the bolt vertical for manual or horizontal for automatic I believe. Quote Link to comment Share on other sites More sharing options...
