Careless Posted December 30, 2008 Share Posted December 30, 2008 Hi ladies and gents, So I finally got my trans back on. Started the car up for the first time since june with some comp-cams break in lube (thick like molasses!) and some Rotella T just for the first hundred or so miles. No exhaust, but it smells of gas, and gas only. Rad was topped off and air was bled. No bubbles, no coolant burning, no oily residue anywhere that I had cleaned. BUT, my transmission still won't let me in and out of gear. With the car on jackstands, and the driveshaft not in place I can feel the output shaft spinning, my car is doing 13 km/h and I'm not on the gas. This was the same issue I had before I took the entire thing to pieces and took the trans off. I'm kinda sadenned by it cause I wanted to drive it before new years, but I'm glad I did the porting and headgaskets, rebuilt nearly everything on the engine except for the rings/bearings, and oil pump. I just don't want to be surprised when the transmission comes off and there's something in there that's going to be costly to fix. Atleast if some of you know what the problem may be (or have had similar issues), I could get a headstart. The shifter shakes violently and there is a new clutch and flywheel. It's my 87 Turbo with FS5R30A. halp plez? Quote Link to comment Share on other sites More sharing options...
dr_hunt Posted December 30, 2008 Share Posted December 30, 2008 It is normal for a manual trans to spin the output shaft in neutral when cold, sometimes even hot when the driveshaft is not attached. As for your other symptoms I have no idea other than mounts. Quote Link to comment Share on other sites More sharing options...
Careless Posted December 30, 2008 Author Share Posted December 30, 2008 righto. i was just told the same by a friend of mine. we'll see how it goes Quote Link to comment Share on other sites More sharing options...
woldson Posted December 31, 2008 Share Posted December 31, 2008 Best O luck man. Sucks a bit living with the mabey........ Fingers crossed. Quote Link to comment Share on other sites More sharing options...
Careless Posted December 31, 2008 Author Share Posted December 31, 2008 So's i topped off the trans with some Redline MT90, drained the crap stuff. I started it and realized that I couldn't do an "air-run" to check all the gear changes cause my 3 and 6 spark plug wires were pooched! got that solved and it idled like a dream! then I rode through the gears on the stands with no problems other than getting used to the half-weight flywheel... kinda scary getting drive-train shudders on 4 jacks, 2 feet off the ground! The real test comes on new years day when I put the exhaust on and torque down the flywheel bolts and hand brake. Gotta put the heat shield onto the brake booster and fan shroud on for now with the clutch fan that isnt... clutchin. lol (got my fan controller and a ford wonder-fan ) Will see how she be. thanks for the crossed fingers. if we cross all of em and add em up, we got a total of like... 12 fingers! Quote Link to comment Share on other sites More sharing options...
Evan Purple240zt Posted December 31, 2008 Share Posted December 31, 2008 Add another set of fingers! My car actually creeps forward in neutral in sub zero weather sometimes. Evan Quote Link to comment Share on other sites More sharing options...
dr_hunt Posted December 31, 2008 Share Posted December 31, 2008 Careless said: The real test comes on new years day when I put the exhaust on and torque down the flywheel bolts and hand brake. :shock: You must be kidding!!!! Torque down the flywheel bolts?!!!! And you wonder why it vibrates the shifter!!!! Quote Link to comment Share on other sites More sharing options...
stony Posted December 31, 2008 Share Posted December 31, 2008 dr_hunt said: :shock: You must be kidding!!!! Torque down the flywheel bolts?!!!! And you wonder why it vibrates the shifter!!!! Man i was thinking the same thing???? did you really run it with loose flywheel bolts???? I had my flex plate bolts back out on me on the dyno (always use locktite) and it vibrated like a mofo..... Quote Link to comment Share on other sites More sharing options...
woldson Posted January 1, 2009 Share Posted January 1, 2009 Heehee. Quote Link to comment Share on other sites More sharing options...
Careless Posted January 2, 2009 Author Share Posted January 2, 2009 I MEANT DRIVESHAFT BOLTS! lol sorry to alarm everyone. My head is still attached to my neck, and shoulders. I had just snugged the DS bolts up because they're hard to get to, so in the event that they had to be removed it wouldn't be so difficult. But I'm tightening them on tonight for good (crosses fingers). The flywheel bolts are torqued to 80ft lbs as per manual. Quote Link to comment Share on other sites More sharing options...
Careless Posted January 2, 2009 Author Share Posted January 2, 2009 dr_hunt said: And you wonder why it vibrates the shifter!!!! It vibrates the shifter because the car was misfiring. bad plug wire on 5 and 6. now seems like 6 intermittently. Also took some getting used to while air-driving the car. shuddering while in gear. Found out it's the fidanza flywheel just doing what it's doing... BEING LIGHT!!! gotta give it a bit more loud pedal. Quote Link to comment Share on other sites More sharing options...
dr_hunt Posted January 2, 2009 Share Posted January 2, 2009 Well, you had some of us wondering there for awhile. Quote Link to comment Share on other sites More sharing options...
Careless Posted January 2, 2009 Author Share Posted January 2, 2009 dr_hunt said: Well, you had some of us wondering there for awhile. no worries. I even loctited my valves to my seats and my valve cover bolts so i can never get to them. and I also loctited my turbo shaft so it doesnt spin. I don't want this car to go anywhere once it's working good! Quote Link to comment Share on other sites More sharing options...
woldson Posted January 3, 2009 Share Posted January 3, 2009 Careless said: no worries. I even loctited my valves to my seats and my valve cover bolts so i can never get to them. and I also loctited my turbo shaft so it doesnt spin. I don't want this car to go anywhere once it's working good! Hey, least that will reduce "ware and tare"! Don't forget to grease the brakes and friction disk. Quote Link to comment Share on other sites More sharing options...
dr_hunt Posted January 3, 2009 Share Posted January 3, 2009 Actually it's pretty obvious that the nut behind the wheel is "loose" Probably loctite that too. Quote Link to comment Share on other sites More sharing options...
Careless Posted January 5, 2009 Author Share Posted January 5, 2009 lol. started her today and she ran out of gas will post up here if i fixed my sticky pilot bushing issue Quote Link to comment Share on other sites More sharing options...
eec564 Posted January 5, 2009 Share Posted January 5, 2009 I've done that before, started a car that was just barely out of gas or tried to start a car that was out and had been under the knife for a while. Makes you just crazy! Especially if your gas gauge doesn't work. Quote Link to comment Share on other sites More sharing options...
Careless Posted January 7, 2009 Author Share Posted January 7, 2009 found my timing was way out too! aligned it to the opposite end of the balancer marks! Idles a little high at 900 @ 15* BTDC, instead of 750 in the manual... I suspect it's from the lightweight flywheel. RUNS LIKE A PEACH THOUGH! Quote Link to comment Share on other sites More sharing options...
