Evos 9sec 2jz build - 9's, 8's, and 7's done going for 6 sec pass now!
looking awesome. Are you going to put interior back in or paint the inside?
I am going to put most of the interior back in the driver/passenger compartment. Factory door panels wont fit anymore due to the cage so I am just going to build some nice covers for them if money permits they will be made of carbon fiber. For the hatch are I would really like to paint it and leave it alone but it will most likely end up with some factory covers and some sheet metal covers. Right now I am working on closing all the holes in the interior including firewall and right afther that Bad Dog frame rails are getting fitted.
Edited by Ivan280zt
  • 1 month later...
As of past two months I have been working on rust repair, closing all the random holes, and frame rails upgrade I figured that this would be good time to post pictures of finished radiator. I ran into little issue where driver side radiator hose was too short with two -16 fittings on there hose would have been only about 2-3 inches long which would bind up and not look very good. To fix that issue radiator was made into dual pass unit with inlet/outlet on the same side. Here are pictures of that process.
Dividing the end tank
Moroso cap and filler neck
All done
Welded from inside
Edited by Ivan280zt
I figured that since I have made some good progress on underbody of the Z it would be appropriate time to post some pictures of how its all coming together.
Bad Dog frame rails (great quality and amaizing fitment)
Yes I know it looks like crap but I am working on improving that...
I ended up cutting all the rust spots on the old rails out and fitting the new ones over. Fittment of the Bad Dog rails is fantastic it just took few hours to put stock rails back into original shape lol.
Test fitting
JT of F@D Autocare rocking out with his welder
Getting there!
Two coats of primer
Same thing on the passenger side frame rail
For the next little project I am going to fixt that rusted out box in the trans tunnel. More on that later on this week.
Edited by Ivan280zt
Last few times that I worked on the Z I forgot to bring the camera so I will just explain what was done instead.
All the edges were smoothed out to perfect finish few edges were rolled over each other in the back (no pics) until everything turned out into somewhat "factory" look. Afther that all the rivets got cut out and everything got welded.
Kinda hard to tell in the picture but the welds turned out awesome JT really did awesome job!
There were two seperate welds per one corner (two corners) that is why there are two very wide spots of seam sealer.
Same thing was done from inside of the car.
I belive thats about it for now I am not planning on doing much work over the next few weeks since I have decent amount of side work to do and its really getting hot down here...
Edited by Ivan280zt
  • 9 months later...
Funny thing how few weeks worth of side work end up turning into six months worth of building and fixing your friends cars but its all good I got myself $10K for doing it. Even though I did not work on my Z in over six months that did not mean that I could not stock up on parts so that way when side work is done I would have most of the parts ordered and ready to be installed. Well I finished my last motor build three weeks ago and I am taking break from everyone elses crap and going full time on my project I sure have been dreaming about this time for over six months! Here are pictures of what I have waiting on to be installed:
Painless wiring harness and switch box for whole car
557.jpg?t=1302995846
RCI five point harness for both seats and hardware kit
558.jpg?t=1302995846
Weldon fuel filter with bracket and fuel pressure regulator with true -8 return
562.jpg?t=1302995846
Gsc S2 cams (10.2mm lift with 274deg duratin), Gsc beehive springs with titanium retainers, and ID (injector dynamics) 1000cc injectors
564.jpg?t=1302995846
565.jpg?t=1302995846
Eagle electronics 2jz 200amp alternator and BIC performance solid engine mounts
567.jpg?t=1302995846
All star catch can with summit -10an fittings and -10an hose
570.jpg?t=1302995846
B&M pro rachet, B&M oil cooler, lokar dipstick, summit fittings and 20feet of -6an hose
575.jpg?t=1302995846
Haltech platinum sport 2000 with haltech wide band and race pack display dash
576.jpg?t=1302995846
Crap load worth of $$$ in OEM parts (did I mention that I left Jaguar and now work as Lexus tech!)
Twin turbo oil pump, crank sensor, coil cover, headgasket, timing belt...
582.jpg?t=1302995846
583.jpg?t=1302996236
584.jpg?t=1302996236
-16an fitting and hose for radiator
585.jpg?t=1302996236
Used twin turbo valve covers with -10an fittings
588.jpg?t=1302996236
AEM 5bar map sensor and two 150psi pressure sensors
589.jpg?t=1302996236
Helmet hook, tool for -3/-4an ptfe lines
592.jpg?t=1302996236
Fuel system fitting and hoses -10an for feed and -8an for return
594.jpg?t=1302996236
Custom made radiator fan and shroud for my particular setup
595.jpg?t=1302996236
597.jpg?t=1302996236
Por 15 with prep chemicals and 100square feet of floor insulation
600.jpg?t=1302996236
Neil Chance torque convertor little over 3K rpm stall (used for 150 miles)
602.jpg?t=1302996998
Billet distributor block off plate
608.jpg?t=1302996998
609.jpg?t=1302996998
Floor drain plugs from MSA
110.jpg?t=1302996998
109.jpg?t=1302996998
Brand new OEM twin turbo coils
4-16-2011024.jpg?t=1302997528
M&W pro 16cdi box (stupid expensive!} and ngk iridium plugs
4-16-2011028.jpg?t=1302997528
TRD oil cap, TRD 160deg thermostat, and haltech single channel hall sensor
4-16-2011032.jpg?t=1302997528
ATI Th-350 with JW bell housing full reverse manual valve body and trans brake (yeah like I will use that on my r200 lol)
4-16-2011035.jpg?t=1302997528
Dash cap from MSA
511.jpg?t=1302997938
I hope that this update is worthy for six month absence of updates : ) More updates in next two weeks...
Edited by Ivan280zt
Man I cant even begin to explaing how I feel about rust repair... For what is worth I am trying to find all the small spots of rust and repair them so here are some pictures of that and some other random crap.
This is what was left of my factory trans crossmember mounts
227.jpg?t=1303950223
231.jpg?t=1303950306
Much better here
246.jpg?t=1303950355
Cut this whole piece out and replaced it with steel plate
262.jpg?t=1303950409
Welded and sealed
540.jpg?t=1303950505
Here you can see three square spots that had to be cut out and redone
544.jpg?t=1303950564
542.jpg?t=1303950632
543.jpg?t=1303950682
I ended up selling my MSA urethane air dam becuase that thing was flexing whenever I would go over 100mph so now I am going to run stock 280z lover valance with carbon fiber BRE replica "spook" sp? lower lip
503-1.jpg?t=1303950760
506.jpg?t=1303951770
507.jpg?t=1303951017
This part was sooooo much fun...NOT!!! Down to the factory primer.
546.jpg?t=1303951106
550.jpg?t=1303951245
4-16-2011007.jpg?t=1303951322
4-16-2011008.jpg?t=1303951398
I took alot of crap off this is just from small section
4-16-2011010.jpg?t=1303951451
Edited by Ivan280zt
I guess when you do this few hours a night over two week period it really does not feel like alot of work was done. When I got middle section of the car stripped to some decent level I took front fenders off and started working on fender wells.
4-16-2011003.jpg?t=1303951921
4-16-2011005.jpg?t=1303952128
4-16-2011012.jpg?t=1303952163
4-16-2011009.jpg?t=1303952217
Not done yet but it looks better already.
4-16-2011014.jpg?t=1303952263
4-16-2011013.jpg?t=1303952303
Rust spot right under the sway bar mount on driver side frame rail just great...
4-16-2011015.jpg?t=1303952347
4-16-2011018.jpg?t=1303952431
Talk about pile of garbage 3 of the struts were blown (bad strut section job from years ago), every bushing, ball joint, steering rack all just gone to **** but thats OK this is good time to replace all of it "while I am at it" LoL
4-16-2011020.jpg?t=1303952473
Got the 280z strut housings, stub axles, and R200 LSD finned cover from parts car at F&D AutoCare (local Z car specialist)
003.jpg?t=1303952646
Edited by Ivan280zt
If you haven't laid down cash yet i would seriously consider the TTT rear struts and use the larger r230 with CV axles from a gtr or Z31. unless you can find larger stub axles they WILL break at the track.
Stony,
I got all the stuff for CV conversion about 2.5 years ago but since my car has been down I let JTaylor use my billet adapters and axles on his RB25 280z and he has been running mid 9's with 1.4 sixty foot and he has not broken anything yet so I will use that setup for while and just see how far it gets me. If or when it brakes I will just go with 9" rear end and call it a day : )
Edited by Ivan280zt
Got some more work done in the last week. Here are some pictures of the dash and seats mounted.
514.jpg?t=1304314637
006.jpg?t=1304314799
008.jpg?t=1304314845
009.jpg?t=1304314883
5-2-2011008.jpg?t=1304314924
NRG quick release hub
5-2-2011014.jpg?t=1304314962
5-2-2011029.jpg?t=1304315015
Reman steerig rack
5-2-2011001.jpg?t=1304315052
5-2-2011002.jpg?t=1304315112
Took all these parts to get powdercoated in fine wrinkle black (texture finish). I also cut off spring pearches from strut housing so I can use my coilovers.
5-2-2011037.jpg?t=1304315153
5-2-2011038.jpg?t=1304315267
Then I cut off crap load of bracket from around rear diff that I dont need any more.
5-2-2011042.jpg?t=1304315325
Edited by Ivan280zt
Two more holes closed off. They were my own fault due to the previous cage work.
5-2-2011016.jpg?t=1304473852
5-2-2011017.jpg?t=1304473988
Started stripping out rear section of the car
5-2-2011032.jpg?t=1304474037
5-2-2011033.jpg?t=1304474122
5-2-2011034.jpg?t=1304474167
Most of my order from Arizona Z Car came in last night I will take few pics of that in next few days.
Edited by Ivan280zt
