mustang 5.0 v8 do all come with HO?
7MGFORCE
If the V8 was in a Mustang (87-93) LX or otherwise, then it is an H.O. The GT was a body/dress package (hatch back, stripes, better interior). Many people seek out the LX V8 cars because they were lighter than the GT's. The 5.0L engine from the Mustang LX is the same as the 5.0L engine from the Mustang GT. Non-HO 5.0L engines were installed in Thunderbirds, trucks, and other non-mustang fords. The non-HO 5.0L engines had different heads and intake manifolds (as well as smaller 16 lb/hr injectors)
The engine that is in my car was from a 1989 Mustang Highway Patrol vehicle. The highway patrol vehicles were V8 LX cars.
cool i thought it was since i wouldnt find any info that said it wasnt.
i been searching this 5.0 swap and was kind of hitting the ditch.
i look at the old post. and the pics are all gone. was curious about Z8 swap.
he uses a 289? i believe. would it be the same motor mount as the 302?
i reread his write up and was curious about the wiring involve on an EFI. his was carb but i cant seem to find any write up on a EFI wiring.
any clues?
and if i carb the 5.0 HO(from 87-93) what wiring will i still need?
btw what headers are you using? im searching for a header that doesnt interfere with the steering.
The hypers are lighter, and usually have a teflon alloy skirt to help rubbing the cylinder wall. They can rev faster and higher cause of the weight savings, and they dont expand as much when they warm up. They are just fine for NA engines.
Forged pistons are stroger, but a bit heavier and hold up better to NOS and forced induction. So neither is really better than the other unless you plan on pushing the pinging limits then go with forged cause they can take more abuse.
The hypereutectic pistons and forged pistons installed by Ford were approximately the same weight (about 600 gram). As stated earlier the forged are stronger. The good thing about the hypereutectic pistons is that they expand less with temperature and can be run with less wall clearance. Both are fine for an engine that won't use nitrous or supercharging.
Over the Christmas holiday I removed the 5.0L from my car (after nearly 9 years of use). During those nine years the car has transitioned from being a daily driver with occasional trips to the drag strip to being a dedicated autocross car. I have always driven it in anger. During that nine years I never touched the stock bottom end, but I have added cam, heads, intake, injectors....
I have finally put together a new stroker short block with a new 5.0L block (4.000 bore), scat stroker crank and rods (3.25" stroke), Mahle Forged pistons (10.3:1 compression), rings and pins. The new Mahle Forged pistons weigh 393 grams. The whole rotating assembly was balanced with a Romac damper and Fidanza aluminum flywheel. I am using the same cam and heads that I had on the old engine, but have switched from a cobra intake with 24# injectors to an Edelbrock Performer RPM with 30# injectors.
The new engine is in the car. I started it yesterday for the first time. I'm going to the dyno on thursday. I can't wait.
Lincoln Mark VII's came with 5.0 HO's also. It's a little easier to find those for donor cars, since they don't have a large demand like mustangs bodies with 5.0's. They only come with AOD 4 speed. 5 speeds are easy enough to come by if you want. Make sure you get a newer 5.0, as the older ones were 5.0 HO's, but came with speed density instead of MAF later on(1988 and up?). Speed Density doesn't account for upgrades such as cam, injectors, heads, etc. Just do a little research before you find what you need. As for identification, there will be a plaque or emblem on the top of the engine that says "5.0 HO". Can't miss it, regular 5.0 v8 will not have this emblem.
  • 1 month later...
  • 1 month later...
Guest josh90gtstang
all the ones in the mustang are HO
the LX was just the bottom end you could get the 2.3 or the 5.0
the GT was only 5.0 and had a body kit thats it and interior
Explorers werent HO but the intake is WAY better than the ford HO upper/lower
Cobra intake are a little better than explorer though, but the newer 5.0 explorer intake is a cheap way to go EFI and have good CFM airflow
The ford trucks werent HO either, but i do believe most all crown vic motors were HO
How was the romac damper in regards to being out of balance or how well did it dampen... did your machinist make any comments on it?
