drag slicks and R200 diff
zthis
Anybody have any experience running cheater slicks
(ET Streets or BF Goodrich drag radials) on a
stock R200 i'm currently running 12.4s 2.0 60ft
with a 355 chevy, auto, and 24550R14 street tires
i need traction will the drivetrain stand up to
slicks or should i start lookin for rear end parts
now ?
Curtis
Curtis,
Low 12's / High 11's will not destroy an R200. What may potentially break are the half shafts. I've run a handful of 1.60 sixty foot times with 275/50/15 BFG Drag Radials on OEM U-jointed half shafts. The key point to consider is the U-joint angles. If running stock, or lowering springs; the half shafts will be more prone to breaking under heavy loads.
A U-joint does not have the "Constant Velocity" that a CV joint has. What this means, is that the further the u-joint is angled, the more velocity differential it experiences. I'm a believer that a U-joint can be stronger than a CV axle. However, keeping the U-joint flat is a problem unto itself.
Good luck!
-Andy
