vspec Posted February 9, 2009 Share Posted February 9, 2009 Ok i have searched all around these forums(probably not good enough) but i can't seem to get it running. I did a compression check and got around 140ish on all 6 cylinders. i used a spark tester and all 6 are getting good spark i installed a brand new fuel pump and regulator and am getting good fuel pressure. it cranks but it just won't start, it almost wants to fire but maybe it's out of time? oh yeah and when i pull the spark plugs there are soaked in fuel. Quote Link to comment Share on other sites More sharing options...
nismopick Posted February 9, 2009 Share Posted February 9, 2009 All engines need 3 basic things to start: Proper spark Proper fuel delivery Proper amount of air If the plugs are wet w/ fuel, it's flooded. Check your CHTS and AFM connections. Then, clamp off the fuel line after the fuel filter & crank the car at full throttle for 5-10 seconds. Release fuel line, crank again. Quote Link to comment Share on other sites More sharing options...
roger.svoboda Posted February 10, 2009 Share Posted February 10, 2009 what nismo pick said but what I did was disconnect the wire from the pump so it would not run. Be sure your battery is fully loaded and/or have a backup. Hold the accelerator to the floor and start cranking. Let her crank a long while. If you don't get a response let things rest a few minutes then do the long crank again with the throttle wide open. You should get some action. It will run a few seconds then die. Repeat until you now longer get any response. Took about three or four times on my 83 turbo. Now reconnect the wire to the fuel pump and she will probably fire and run normally. no wide open throttle. Quote Link to comment Share on other sites More sharing options...
MJLamberson Posted February 10, 2009 Share Posted February 10, 2009 Have you checked the timing? Quote Link to comment Share on other sites More sharing options...
vspec Posted February 10, 2009 Author Share Posted February 10, 2009 how do i check the timing when it's not running? do i just hook up a timing light and crank it? and i disconnected the fuel pump relay and it fired up and died, so maybe too much fuel? Quote Link to comment Share on other sites More sharing options...
MJLamberson Posted February 10, 2009 Share Posted February 10, 2009 Play with the dizzy while trying to start it. Edit:what about firing order? Quote Link to comment Share on other sites More sharing options...
FlatBlack Posted February 10, 2009 Share Posted February 10, 2009 Did anyone open up the cover on your AFM? I did a motor swap last semester, my AFM's spring rate was too low and it wouldnt start because it was too rich. Very unlikely, but hey, it could happen. Quote Link to comment Share on other sites More sharing options...
woldson Posted February 11, 2009 Share Posted February 11, 2009 If you play with it, make sure you put a mark on it for reference. I've fiddled with that wheel lots, kinda fun. Make sure you have a good hold of it when you loosen the screw;) Quote Link to comment Share on other sites More sharing options...
islanddozer Posted February 12, 2009 Share Posted February 12, 2009 If your plugs were soaked in fuel I would suggest hooking up a guage to your fuel regulator on the fuel rail Quote Link to comment Share on other sites More sharing options...
VinhZXT Posted February 12, 2009 Share Posted February 12, 2009 Get yourself a service manual. If you have fire and fuel then it has to be the timing. Remove your valve cover and put your #1 piston on TDC and check for the timing marks on the sprocket and the shiny chain link and the rotor in the distributor is pointing to #1 spark plug. That's how you check your timing. I had a car with this same symptoms before and when I check the timing chain some how is off by 1 chain link. GL Quote Link to comment Share on other sites More sharing options...
vspec Posted February 13, 2009 Author Share Posted February 13, 2009 i have a gauge on my fuel rail and adjusted it to what was recommended in my service manual. also if i disconnect the fuel lines from the rail it fires up and idles then dies when it runs out of fuel. Quote Link to comment Share on other sites More sharing options...
nismopick Posted February 13, 2009 Share Posted February 13, 2009 Your motor is fouling out. Did you do this? Check your CHTS and AFM connections. Quote Link to comment Share on other sites More sharing options...
vspec Posted February 13, 2009 Author Share Posted February 13, 2009 yeah i bought a can of electrical contact cleaner and cleaned every connector i could find. my brake lights work now lol. but my starter took a crap so now i have to get a new one before i can test it out. Quote Link to comment Share on other sites More sharing options...
