Gollum's Never Ending 280Z
This is about as level as I can hope for, measuring several points around the car, I think the car is about 0.5 degrees tail up, so I'm probably within half a degree difference between the engine angle and the chassis.
Positioning isn't perfectly square, and I'd like this to go back another 1/2", but it's close:
Will definitely clear the hood at this height.
Next time I'm out in the garage (hopefully tonight) I'm going to swap the sump support with another scissor jack so I can get a bit more precise on the height. Might weld some extra supports on a jack to give it a larger footprint and be less tippy (will still shim with wood for softness but would like it to not want to lean more than a few degrees.
In this position, The shifter would just barely make it into the OEM opening, but definitely sticking up a bit proud.
Overall this is definitely close to where it needs to be, but I would prefer being up another half inch or so, and another half inch back, but I think I might already be making contact in the tunnel somewhere. Going to investigate that, along with looking at what exhaust manifold clearance looks like in this spot.
Didn't snap pictures, but got the engine back in again after some firewall massaging and it's definitely sitting a bit better. I still feels like I'm hitting somewhere and it's not quite sitting where I want, but it's close. Also opened up the shifter opening width a touch which will definitely be required to fit the MGW shifter.
  • 3 weeks later...
More fiddling, I think I'm going to actually end up with the engine tail down around 3 degrees. Everything just ends up fitting better. I can't get the engine as slammed back, but I can run it higher up (solving not just pan, but also exhaust clearance issues). It had been a while since I'd refreshed my memory, but my pinion is sitting at 4.6 degrees nose up already. I planned on making an RT style mount, but seeing that again highlighted just how important that will be in order to keep angles in check. I'm sure engine down 3, diff up 4.6 wouldn't be a huge deal on cruise, but we all know how much the nose of the diff wants to rise under accel, and that's a level that's getting to be concerning. So I'll add that to the endless todo list.
The good news about running a bit more engine angle and getting the engine up higher and all the way back, is that I can move the engine mount attachment points on the chassis side down and away from the top side of the frame rail box.
So I cut off the tack welds and I'm making new sections to attach down on the side of the frame rail box and the TC rod attachment point. Once the mounts or made and I'm ready to weld these fully I'll box them in in a few areas.
Before the last time I pulled the engine I was getting an idea for how aligned I was and square to the pinion centerline and chassis. Its "easy" to get your transmission aiming at the diff center, but that doesn't mean the diff would be pointing at a centerline that intersects the crank snout. So I measured the transmission output and the engine front as square to the rockers as a ball park idea to make sure I wasn't too far away from where I wanted to be.
My results:PXL_20231209_235759554.NIGHT.jpg.f5ababe31354b44d668644b3ac0cd819.jpg
PXL_20231210_000558673.jpg.049b4b38cda1c4eb6afbb7bd0d6aa23c.jpgPXL_20231210_000612962.jpg.fef4a516b937037a1cad4251b0cad4f2.jpgPXL_20231210_000619194.jpg.32ef6cf282ac638a73e3ddeb1a1c8984.jpgPXL_20231210_000623823_MP.jpg.f35a2c9923c599c0b2dfa58c7777bda6.jpg
Probably not perfect measurement methods, but I was surprised how close it all seemed to be without much fuss. Will measure it all again as I get ready to tack mounts.
I took the time and got the reverse alignment info here for posterity. An engine should sit about 1" towards the passenger measuring at the steering rack. If your engine sits further forward you might want the crank snout a bit proud of a inch left (looking towards the rear) and if your engine is super short maybe a hair shy of an inch.
The larger point though is that if you perfectly center the engine in the engine bay, and point your transmission at the pinion exactly in line with the centerline of the pinion, you'll actually be introducing non-parallelism between the engine and transmission centerlines. If you add that on top of any unmatched angle between your engine tilt back/down and the pinion tilt up. The diff sits about 5 degrees nose up to begin with, so if you mount your engine level, it's not just the 5 degrees of difference you've added (which is a lot) but also likely some horizontal angle difference as well.
Did several tests and measurements to ensure this was square:
And then measured both directions from the steering rack bushings (could also easily see the offset from above)
Edited by Gollum
  • 4 months later...
So a bit of an update. The engine is up for sale. Already sold the transmission as well as exhaust/cats I had.
Why?
Because every time I fit the engine I was faced with the reality that either I needed to change the oil pan, intake, throttle elbow out, and then buy several manifolds to see what fits, or make custom manifolds. I'd resigned to the reality that I'd just have to make manifolds.
But I just don't have the time to sit down and hammer that out. It might be a 40 hour job if I could just hunker down and do it, after buying $500 worth of supplies. No big deal right? Except I simply don't get chunks of time like that (currently).
I want to just finish a swap and drive the thing. So I was entirely ready to just go LS instead. Over the counter swap parts are available, so it was just budgeting the money and doing it. Selling everything would be the necessary shot in the arm to raise the capitol to just make it happen.
...excpet...
...HOLY T56 PRICES PEOPLE! I kept an eye out for over two months. Facebook marketplace. Craigslist. Ebay. I now know most of the T56/TR6060 ratio sets by heart, and I definitely had some preferences, but I had in my mind what a "good deal" would look like for various sets and nothing was ever close. If I was just tossing money at problems I'd just get a new T56 Magnum and be on my way. But that's $3600, before a flywheel, clutch, master cylinder, slave cylinder, etc.
Then I realized that converting a K series wasn't actually as expensive as I thought it was. Started pricing everything out, and realized I could do nearly the entire swap for the price of just a new T56 Magnum.
At first I was thinking I'd used the cheap and very plentiful BRZ/FRS transmission, but so many horror stories of them being wrecked. The strange thing is that so many things indicate it should be a strong transmission, and some people drift them (one of the hardest modes of abuse for driveline parts) at 500+hp without issue. I wonder if it's just a shift fork design issue. Who knows. So I shifted and started researching AP1/AP2 transmissions.
Kept an eye out, and score!
Paid $800. Not 100% known to be good yet, I'll have to do some inspecting before assuming, but the guy was pretty up front about his experience. He was running 700+whp and had been through several transmissions, and this was his third. It held until he did his E30 transmission swap, and then later sold the car. He said when pulled it was still shifting great and not making any noise. It then sat outside for a year (in a bag he claimed) so fingers crossed I'm not replacing bearings or synchros. The bearing prices for this aren't bad. I can get all bearings and orings/seals for under $300 shipped to my door. But the synchros add up. The 1-2 synchro is like $266 on it's own iirc. (comes as a whole assembly  with the hub gear, shift ring, etc).
But it gets better. The seller was also very strapped for space and trying to see what else he could toss at me, and threw this in for free:
The tag was long gone, so it took me a bit to figure out what it is. It's a Precision 6262 with the Gen2 ball bearing cartridge. It has some mild turbine denting, but the housings look unscathed. Bearings have zero play (might be able to measure with a dial indicator, but can't feel it by hand) so I could probably run this as-is. But that said, I'm going to get this swap done NA first for several reasons (cost being one). Once I decide to go turbo, I can just swap in a new wheel (found a rebuild parts supplier with new wheels for $120), and voila a solid turbo pairing for this engine.
Speaking of engines, I haven't gotten one yet. I had a line on one, but due to issues with the seller we couldn't meet up. He's about 2 hours from me, so not sure when I'll get the opportunity to reconnect and see if I can get a motor.
But I did find this and picked it up locally yesterday:
Hard to read, but that says "K to F Adapter". There are a few companies making these, ranging from $240-300 depending on manufacture and reseller, but I picked this one up for $200 and it seems like I'll have to source my own bolts and dowels. I might be able to keep that under $20 so this still feels like a deal (though I'd still have the ship the above new prices, so maybe it's not bad no matter what).
I'm tracking all the parts in a spreadsheet (which I normally do anyway) and it's looking like the budget is landing around $3600.
Now, there's some hand waiving in that others should be aware of.
1. I'm going to use the existing Megasquirt MS3X box I have. Getting hondata/k-tuner would easily add $600+ to this.
2. I plan to use the OEM exhaust manifold. I simply don't see any good reason not to. I don't care if I'm losing 10 or even 20 horsepower. It's worth it to me to save time and cost to just drive the thing.
3. I already had steel and bushings in stock for doing engine mounts for the 4.6. Would easily add another $50-100 that I'm saving.
4. I have no clue what the driveshaft will cost. The AP1 transmission is a fixed flange, not a sliding splined output, so I'll need to find a shop familiar with making a shaft that can give me that half in of compliance or so necessary. Also, I'll likely need to find a converter flange to go from the AP1 output to a u-joint to cancel out the vibrations from the rear R200 ujoint. As of now I've got $500 for the driveshaft solution, and that could easily go up.
5. I'm also planning to save a few buckets by using 2NRS's K to F intake flange adapter, to use a S2000 intake. The "better" alternative is the Skunk2 Ultra Street manifold which has a reversible plenum. It's $550 and then you're still needing your throttle body, fuel rail, etc. Some of these might be source able or mix-match able with OEM parts, but for $120 I can get an adapter to use a full intake/throttle pull off out of a S2000 and that solves the problem soup to nuts. And considering some people have made well over 250whp NA on the S2000 intake I'm going to say it's "good enough" for me.
6. I'm also not buying into the "use this oil pump, use this water pump, remove balance shafts" internet myth ethos. I understand why people do that, and suggest that. But a lot of people are making changes with very little implications as to the reality of the why. These are $900-1100 motors, all day long. They might go up like B series have, eventually. But for right now, they're still dirt cheap. When people like Richard Holdner go and dyno a completely stock K24A2 with balance shafts up over 8700rpm, 280+hp NA, and 600+hp boosted, you have to wonder where the failures are. And if you go looking, and find one, let me know. I know MotoIQ, 4Pistons, Drag Cartel and other big names all say the same thing. And I'm sure if I was building a 10k motor, I'd also go with a better oil pump, remove the balance shafts, and gain oil capacity as well as ground clearance at the same time.  ...or I can just buy a spare motor to store in my garage.
So stay tuned. I hope to have an engine in the next few weeks and start mocking things up.
Edited by Gollum
  • Like 1
Wow, quite the shakeup Nate! Is that an AP1 or an AP2 box? They've got different ratios and synchros. I think the S2k box is longer than the Nissan, curious where the engine will sit when the shifter is situated.
While I'm not a proponent of 4-cylinders in Z's, the K20/S2k box is a sweet drivetrain combo. I've got a spare AP2 S2k motor/gearbox/ECU/wiring harness drop-in that I'm still trying to figure out what to do with it... my best idea so far is to drop it into a Merc 190E to make a faux 190E Evo. This idea is however is purely in my dreams, as I have no time for any of this :lol:. I commend your efforts!
AP2 box is on the left, there's extra ribbing around the countershaft boss.
Pic is from Billman250 of s2ki: https://www.s2ki.com/forums/s2000-under-hood-22/ap1-tranny-vs-ap2-tranny-931368/page2/
Yeah, I've never been a huge fan of 4 cylinders in a S30. It's one of those "sure, it's okay for you, but it's not for me" kind of things. But the K series is definitely more interesting the more I learn about it.
My trans I picked up is definitely an AP1, and I'm aware they're slightly less desirable than the AP2, I haven't found any good indication that they're weaker.
(note the 'AP1' as the 4-6 characters)
AP1 bellhousing with internal slave cylinder conversion (will likely try to source parts to convert back to external slave)
As for placement, yes it's a long transmission, but the design would lend itself decently well to modification if necessary, as the shift rod is of a single rod design and already travels a long distance to the interface with the forks.
That said, it's looking like it will work "as is" for at least a first iteration:
The engine might sit further back than this, but probably not much.
Which puts the shifter here:
If I put the tranmission back to where that shifter is just touching the back edge, then the bellhousing face is definitely behind the plane of the firewall. So I think it'll work without fuss.
And for those playing at home:
AP1 Net ratios (has internal reduction)
3.634
2.372
1.718
1.347
1.126
0.941
AP2 Net ratios (same 1-4 but different 5-6 and reduction gears)
3.785
2.470
1.789
1.402
1.139
0.922
And with a 3.545 R200 on 23.85" tall wheels:
AP1
AP2
You can see that 6th in particular sits quite a bit further out, increasing overall spread of the AP2, but the added reduction makes 1-4 end quite a bit sooner, while giving relatively identical RPM drops as the AP1. The AP1 by contrast, gives you slightly longer legs 1-4 but 5th and 6th stay a bit tighter with smaller RPM drops as compared to the AP2 for 5th and 6th.
Either way, the fact both transmissions have internal gear reduction and yet are geared surprisingly narrow, makes this a good fit for a higher revving engine in a chassis that isn't running super high ratio differentials. In a perfect world I think I'd still opt for at least a 3.7 diff, if not maybe as high as a 4.10, but let's compare this to something like the CD009.
CD009
Notice that the RPM drops between gears are much larger, and the overall spread is much wider. This would certainly work well for a VQ which has a much broader torque range and falls off a bit on the top end, yielding a wider HP curve. But for a K24 where you want to stay up on VTEC to have fun, the CD009 trans would suit something like a 4.44 final ratio much better.
The BRZ/FRS transmission for reference, has a pretty sizable drop 1-2, but stays decently tight 2-5 and a big drop into 6th which is fantastic if you want to run a super high ratio diff but still want a good highway cruise RPM.
BRZ/FRS
Now, another common option for K series transmissions would be the BMW E30/E36/46 transmissions, so we might as well add those to the comparisons (since I have dozens of these transmission ratios saved anyway).
The BMW 6 speed:
The BMW (E30) 5 speed:
The BMW (E36) 5 speed:
The BMW E46 also had a 5 speed option for a bit, and is relatively close/similar to the E36 5 speed. The ZF 5 speeds all end with a 1:1 5th gear, which ends up being pretty awkward so the better suited option would be the ZF 6 speed, but even that one has an awkward "rising" spread shift, or gets tighter and tighter. This might be good for a lot of driving situations, but my goal is making a car that's fun on the street, as well as fun doing HPDE/Autox events. I want as narrow of a spready as I can get 1-3 if not as narrow as possible 1-4. To that end, the AP1 or AP2 are both stand out options.
Also, just because, here's the AR5
Would suit a V8 torque range nicely... Shifting a 6500 drops you to 3900, 4300, 4300, 4700 rpms. Very wide 5 speed, with decently spaced gears, though maybe a slightly close 1-2 shift. Not so idea for something super high revving, but I can see why a lot of LS people use it.
  • 4 weeks later...
I saw your other post about k24 weights and responded there before seeing if you had a build thread...anyway.
I'm *nearly done* with this swap. I have a spreadsheet of everything I've used on my swap down to single bolts. Once I get the car running I'll have a huge write up with that spreadsheet, links to videos/posts I found helpful, full documentation of component weights(Honda vs Datsun). If you have any specific questions I'm happy to help.
I'm also going to be selling mounts and while they won't contribute to meeting your $4k goal, it would save you a lot of time. My swap was done in Solidworks from 3d scans in an attempt to minimize body modifications. I did need to notch the trans tunnel reinforcement to clear the shift linkage tube on the s2k trans and the hood latch bracket so I can remove the valve cover. Otherwise the engine is in the ideal location with the oil pan at the same level as the L series pan, just enough room to remove the water housing, and the shifter is in almost the exact OEM location. I welded the top of the Z shifter to the S2k lower portion and used the OEM rubber shift boot/seal ring.
I considered the same transmissions, but ended up with the S2k trans as well. I thought it might be a bit cheaper since the adapter flywheels for the BMW, BRZ, and CD transmissions are spendy, but the S2k clutch kits are quite expensive. I paid 750 for the trans with shifter, 525 for the clutchmasters flywheel, 240 for the adapter, 360 for an ACT disc, 155 for a OEM Honda TOB, 150 for a OEM pressure plate, and 160 for the missing clutch slave, slave boot, fluid, misc little parts.
Since your K2F adapter didn't come with bolts, here's a pic with notes. I ended up sanding most of the 52/42 length bolts to 51mm. They started out as 55-60mm bolts, but the adapter plate is so thin I wanted the extra 1.5-2 threads vs 50/40mm bolts. The 68mm bolt also holds the starter and 7mm of thread engagement with a 65mm M12 bolt is questionable. This was a PLM adapter, I would not recommend buying anything from them. It was missing one bolt hole(5oclock) and another(7oclock) was off ~2mm. I was able to open up the lower trans brace with a die grinder. I bought most of my hardware from Bel-Metric
Edit: looking at your spread sheet. The OEM coolant inlet fits, don't buy one of those swivel neck turds. The factory thermostat has a bypass so coolant continues to circulate in the engine while it is closed. Those swivel neck versions don't have that unless you buy the $200+ version from Ktuned(?). I bought one of the ebay upper outlet housings without the additional bleed neck. The bleed neck won't fit with my current setup, but for only a few $ more I'd go that route. I'm concerned bleeding the coolant system is going to be difficult. I'll know in a few days...
I also bored out the outlet. The ID on these cheap ORB fittings is tiny, I think it was 24mm. OD is 32mm and I bored mine to 29mm.
Edited by manimal
  • Thanks 1
This is fantastic information. I also need to get some dowels but I have that information assuming it's correct:
Dowel Pins
4x 15.25mm (Length) x 12.70mm (Diameter)
And yeah, I ordered the upper coolant housing version that had the fill neck. I don't have a hood latch, so I wasn't worried about colliding there.
As far as mounts, my factory perches are already cut off anyway. And I also already have metal materials and bushings from the Ford swap attempt that I plan to reuse. Luckily mounting is a small piece of the time pie, so it's not a huge expenditure.
I wasn't sure yet on a swivel neck housing for the t-stat, and I wasn't sure I liked the idea of tossing parts at something when the OEM parts might work. And yeah, I'm definitely keeping the internal tstat bypass. I'm aware of how bad that would be to entirely eliminate for the pump life, though my research suggests it's probably better to cap off my heater line (since I won't be running a heater) versus routing that in as a second internal bypass.
I'm also not adverse to hammering/cutting the transmission tunnel. I already have the reinforcement box that the stock ears are welded to. I'm also not adverse to having the oil pan a touch under the stock L series location, as the stock L series pan actually sits ABOVE the bottom of the floor pan and the lowest point of the radiator from factory. I don't plan to drag the oil pan, but I do plan to eventually build a belly pan and expect to run my engine as low as I can realistically get to that pan.
Sounds like your clutch setup will be pretty trick and I'm sure it'll be wonderful. I'm rolling the dice, and going with the ebay xtd option. It might be crap. We'll see.
In other news, some goodies have arrived:
The MAP sensor on the TB was damaged in shipping, but not a huge deal since I wasn't planning on using it anyway.
Intake came with K2F intake adapter and hardware and all looks to be in good shape.
Now to just get my two stuck flex plate bolts out (it's been fun). Then I can get manifolds attached and lay the engine in for initial look of how things will lay out. Then onto transmission fitting and planning out the engine mounts.
The dowel sleeves that came with my PLM adapter are 13.5mm diameter(13.53, but cheap calipers so YMMV). Length is 16mm, but they could be 25mm+ and not cause an issue. The PLM supplied dowel sleeves are aluminum and I was lucky to have the steel dowel sleeves in both the s2k trans and k24 so I didn't need to use them. I didn't measure the dowels before mating the engine/trans and installing it.
My swap mounts involve welding parts to the "frame rails" of the car. There's no reasonable way to utilize the OEM mount location unless you want to move the engine forward 4-5 inches and make a custom subframe. I also cut the OEM mounts off the subframe to clean it up and save ~0.5kg(I'll have to check my notes on that)
My clutch setup isn't anything special, it's mostly OEM with an up-rated disc. I agonized over it for a while, most postings said all of the aftermarket clutch parts for these cars are garbage. It's going to be my daily and I figure spending a bit more for peace of mind was worth it. Mainly I mention the cost because I thought I'd be saving by going with the s2k trans and $250 adapter vs the other options, but the least expensive reliable clutch option for the s2k trans was a few hundred more than for other swap transmissions. LHT performance(youtube) does mostly s2k content and recently put out a video of a clutch replacement where the exedy pressure plate broke on a stock power car.
When it's time to install the flywheel make sure you have the right bolts. The OEM B-series bolts are the correct length with the clutchmasters flywheels, part #90011-PH3-000. There is a cheaper flywheel bolt that's a few mm longer which will bottom out before fully seated, though it's close enough that the flywheel will appear tight. I don't recall which bolts they are, but they'd work if you sanded them down a hair and I recall them being ~half the cost of the above part #.
  • 2 months later...
No updates, sorry y'all. Dealt with the passing of my father (unexpected) this June. So spent a month away which as many might know doesn't just kill momentum but also motivation. I'll be back at it eventually, but might not get back in the garage until later this autumn.
  • 3 weeks later...
Sorry Nate. :( Family always comes first, do what you need to do and the garage will be calling when you're ready.
  • Like 1
  • 3 weeks later...
Well it's far from exactly where it needs to be, but getting a picture for how it will fit and come together.
SEMA ready!
But in all seriousness, plenty of room for the rear sensors and water neck + cap
Hood should clear by a mile in this position (since the center sits fairly proud of the inner fender seam).
I think this would leave enough space for pulling the pan without pulling the engine as well as plenty of space for getting belts on.
I thought for sure this would sit further forward leaving so much room behind the engine at the firewall.
So, that leads us to the real challenge, making the OEM exhaust manifold fit:
Now, I already planned on putting a v-band on that so the OEM bracket can come off anyway.
So I'll need to take some measurements of the ID/OD at various points, and see if I'd have to put on a 4" v-band then maybe transition to a neck down to a 3" to get it cut far enough up to work.
Alternatively I could cut the runners up by the head and add some angle up there (could just cut them 90% through, close the gap and weld them easily enough). This would definitely tuck the manifold in closer to the block, though either way there's still the planned cutting at the other end for a v-band. Just might give me more room and options.
And in all that, I need to also figure out fitting the mounts around the manifolds. The intake side should be "easy" because the manifold doesn't want to occupy the same space as the mount, but the steering shaft does. So there's that.
I might mock up the intake manifold this weekend simply for some aesthetic motivation.
Edit: Oh, and the oil pan is sitting about 3/4" below the cross member. Still well above where the floors sit, but I have the space. Might be worth it raising the whole thing up that much since I have that clearance (and more) above the transmission currently. Won't entirely solve the exhaust manifold fitment, but might make it a touch better.
Edited by Gollum
When you do the final assembly on your motor, use hondabond on the rear water neck. I tried to use the included orings and it leaked. I put a generic temp sensor from ebay in the 1/8" npt port on the water neck and connected it to the factory wiring. My OEM water temp gauge works fine and reports a position which seems to match what Hondata is telling me. Careful with a lot of the cheap temp sensors. I tried two different amazon sellers which had 3pks listed as 1/8npt, but after multiple returns they kept sending M10x1.0 sensors. The single $10ish sensor I bought off ebay was 1/8 npt.
  • Like 1
No pictures, but got the driver's side plate made for the engine mounts. Kind of "fun" since each bolt is on a different plane, but just takes some fiddling around.
I ended up moving the engine towards the drivers side to generate more clearance for the exhaust. This whole powertrain is so much more lithe than the Ford engine it's comical, so it appears as though I should be able to keep the engine/trans parallel to the diff even with the offset. And since there's only the intake on the driver's side, clearance on that side so far looks great. I'm not even close to anything touching the steering.
