Weird Knocking Sound
If you can assume that the engine was working fine until the exhaust change then I would bet the value of the car, that it was just incorrectly installed and the gasket leaks.
Those gaskets need to be installed with knowledge about how the interfacing components will sealup while tightening them. You have an aftermarket header that obviously does not fit correctly with the orginal Nissan intake. This will only compound the issues NORMALLY associated with these L-series engines.
Having the intake AND the exhaust on the same mouting plane makes it very hard indeed. Newer designs have gotten away from this for a lot of reasons, heat, fuel lines over hot headers, and the simple fact that they are nearly impossible to align and install correctly.
