turbeau Posted February 27, 2009 Share Posted February 27, 2009 i drove the car around the block to check the plugs. going about 20 mph in third gear the tranny started shaking badly and i put it in neutral. i couldnt put it back into gear so i pulled over. with the car off and parked i tried to run through the gears with the clutch in. most were difficult to put in, some would not go in. with the engine running no gears would go in, and reverse would just grind cause the engine was spinning. when i would start the car in gear the tranny would shake really hard then start grinding and i would go back to neutral. with the car in gear i rolled backwards and there was loud clunking sounds, sounded like from the differential. i looked underneath and i could not verify anything unusual. had it put on a flatbed and towed back to my house. what do you think? Quote Link to comment Share on other sites More sharing options...
islanddozer Posted February 27, 2009 Share Posted February 27, 2009 any slippage on the clutch before hand? Sounds like the syncros are gone in the tranny. Roll it out of gear, hear noises ? Quote Link to comment Share on other sites More sharing options...
Flexicoker Posted February 27, 2009 Share Posted February 27, 2009 I think your clutch is not disengaging all the way. I had the same problem (minus shaking) and it was because my clutch slave cylinder was leaking and emptied the reservoir. Check all of the hydraulics and try topping it off and bleeding the system. I've also had the same problem when I got the incorrect height pressure plate from clutchnet. Quote Link to comment Share on other sites More sharing options...
ezzzzzzz Posted February 27, 2009 Share Posted February 27, 2009 It's your clutch hydraulics. Trannys don't just dump like that. Quote Link to comment Share on other sites More sharing options...
blue72 Posted February 27, 2009 Share Posted February 27, 2009 That's what I was going to mention. Check over the clutch line, reservoir housing and all fittings for leaks would be my first suggestion. Quote Link to comment Share on other sites More sharing options...
Daeron Posted February 27, 2009 Share Posted February 27, 2009 Tclutch line, ANY DOUBT on the soft rubber lines, just replace them. Quote Link to comment Share on other sites More sharing options...
turbeau Posted February 28, 2009 Author Share Posted February 28, 2009 when i rolled back in neutral there where no sounds, clutch resevoir is full but grimy, no clutch slippage previous to incident. tomorrow i will drop tranny and inspect. thanks for help so far Quote Link to comment Share on other sites More sharing options...
jasper Posted February 28, 2009 Share Posted February 28, 2009 How can bad hydraulics cause a vibration issue.......I DON'T THINK SO. Quote Link to comment Share on other sites More sharing options...
islanddozer Posted February 28, 2009 Share Posted February 28, 2009 when i rolled back in neutral there where no sounds, clutch resevoir is full but grimy, no clutch slippage previous to incident. tomorrow i will drop tranny and inspect. thanks for help so far Well that eliminates any rear end trouble. let us know how you made out. a couple of pics go a long way Quote Link to comment Share on other sites More sharing options...
Daeron Posted February 28, 2009 Share Posted February 28, 2009 How can bad hydraulics cause a vibration issue.......I DON'T THINK SO. by not fully disengaging the clutch disc and never actually allowing the clutch to let go when you try to shift. Quote Link to comment Share on other sites More sharing options...
jasper Posted February 28, 2009 Share Posted February 28, 2009 " i drove the car around the block to check the plugs. going about 20 mph in third gear the tranny started shaking badly and i put it in neutral. i couldnt put it back into gear so i pulled over. " Hydraulics don't cause vibrations. Broken clutch discs can, but not hydraulics. Quote Link to comment Share on other sites More sharing options...
blue72 Posted March 3, 2009 Share Posted March 3, 2009 Just read through this thread with my dad by my side. He agrees with Jasper and thinks the clutch disk had a come apart. Quote Link to comment Share on other sites More sharing options...
jc052685 Posted March 3, 2009 Share Posted March 3, 2009 "i drove the car around the block to check the plugs. Going about 20 mph in third gear the tranny started shaking badly and i put it in neutral. I couldnt put it back into gear so i pulled over. " hydraulics don't cause vibrations. Broken clutch discs can, but not hydraulics. +1 Quote Link to comment Share on other sites More sharing options...
turbeau Posted March 5, 2009 Author Share Posted March 5, 2009 yeah that is what i hope, this weekend i will drop the tranny and open it up. if the disk did break maybe i torqued it down incorrectly? it is fairly new clutch (~3000? miles) thanks agian for the looks and help, the Z community is great! Quote Link to comment Share on other sites More sharing options...
saxfiend1967 Posted March 5, 2009 Share Posted March 5, 2009 I know this sounds stupid but just for the heck of it check trans mount and driveshaft to diff bolts my driveshaft came lose and did the same thing Quote Link to comment Share on other sites More sharing options...
1 fast z Posted March 5, 2009 Share Posted March 5, 2009 I bet your straps that hold the PP to the CC have broke. Quote Link to comment Share on other sites More sharing options...
turbeau Posted March 9, 2009 Author Share Posted March 9, 2009 i opened the tranny and took the clutch off, and all the flywheel bolts were loose. one had come so far out it had hit the clutch disk. its my ignorant fault for not torqueing the bolts down properly when i installed it. what a homer. the pilot bearing is messed up and i tried using the pull-out tool, but it didnt work. do you have any suggestions or tricks for getting a stubborn pilot bearing out? Quote Link to comment Share on other sites More sharing options...
jc052685 Posted March 9, 2009 Share Posted March 9, 2009 dremmel with a carbide bit a notch in onee side then just use a chisel and a hammer to break it out. Quote Link to comment Share on other sites More sharing options...
islanddozer Posted March 9, 2009 Share Posted March 9, 2009 i opened the tranny and took the clutch off, and all the flywheel bolts were loose. one had come so far out it had hit the clutch disk. its my ignorant fault for not torqueing the bolts down properly when i installed it. what a homer. DOH!!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
jasper Posted March 9, 2009 Share Posted March 9, 2009 Very easy. Couple of ways. You could cut through the bushing with a thinned/modified hack saw blade. If you have access to a slide hammer with a vice grip attatchment, you can insert a bolt head first, and cock it. It will wedge nicely. Give it a yank. Quote Link to comment Share on other sites More sharing options...
