rytherwr Posted March 1, 2009 Share Posted March 1, 2009 Got the hot rod running and sitting on the dyno...breaking in the engine, changing oil, fixing leaks, etc, etc...changed the oil and made a couple of 1/4 pulls just to put a load on it and was pleased with the results...537 lb ft of torque at 3400, 470 hp at 5300 at 3 lbs of boost. That is with really conservative timing and around 11:1 AFR. Once we get at it, ease the timing up and move the AFR closer to 12:1, I believe it will be where I want it. Built the engine to make the power at 6000 or a little less...so far, so good...) More when we get there. Wayne Quote Link to comment Share on other sites More sharing options...
DavyZ Posted March 2, 2009 Share Posted March 2, 2009 Wayne, I was reading the numbers you just posted and I thought, "Boy that looks strange: 537 lb ft of torque at 3400, 470 hp at 5300 at 3 lbs of boost..." But then I realized that this was only at 3 LBS OF BOOST!!!. I'm really looking forward to the final dyno numbers on this engine. Great work, Wayne!! Davy Quote Link to comment Share on other sites More sharing options...
deja Posted March 2, 2009 Share Posted March 2, 2009 Great progress Wayne. What is your dream boost/HP target? Quote Link to comment Share on other sites More sharing options...
rytherwr Posted March 2, 2009 Author Share Posted March 2, 2009 Heck, Davy...that was just a stab-load and untuned to boot... Dale...my hopefully not-so-dreamy goal is 750-800 hp and 950 lb ft of torque on 93 octane pump gas and alcohol running through the intercooler at 12-14 lbs of boost. On race gas, I am looking for 1100 to 1200 hp and around 1200 lb ft of torque at 17-20 lbs of boost. ) wayne Quote Link to comment Share on other sites More sharing options...
Zeddicus Posted March 2, 2009 Share Posted March 2, 2009 and i thought that my 375whp goal was up there..... that is completely insane man, sounds like a blast Quote Link to comment Share on other sites More sharing options...
deja Posted March 2, 2009 Share Posted March 2, 2009 OMG!!! You are insane, I knew it now it has been confirmed. I can't wait for DNI. rytherwr said: Dale...my hopefully not-so-dreamy goal is 750-800 hp and 950 lb ft of torque on 93 octane pump gas and alcohol running through the intercooler at 12-14 lbs of boost. On race gas, I am looking for 1100 to 1200 hp and around 1200 lb ft of torque at 17-20 lbs of boost. ) wayne Quote Link to comment Share on other sites More sharing options...
chevydoc Posted March 2, 2009 Share Posted March 2, 2009 I got a question? Running those power numbers, did you reinforce the frame or build a new one? Quote Link to comment Share on other sites More sharing options...
dr_hunt Posted March 2, 2009 Share Posted March 2, 2009 Wow that is great. I was amazed that I was able to build 5psi of boost under no load. What build specs do you have on that new 415 motor? Quote Link to comment Share on other sites More sharing options...
rytherwr Posted March 2, 2009 Author Share Posted March 2, 2009 Dale..as long as we're dreaming, might as well dream big, eh? Chevydoc...yes Doc, Specs to follow: Engine: 415 SBC 3.875 stroke/4.125 Bore, 8.6:1 compression ratio World Products Motown Block 4 bolt mains, O-ringed, splayed billet main caps, priority main oiling Scat forged crank and H-beam 6" rods JE custom turbo pistons, hellfire rings AFR Eliminator Competition aluminum heads 227 cc, completely CNC machined 2.08/1.65 intake and exhaust valves Jesel aluminum shaft rockers @ 1.65:1 rocker ratio Manton custom length pushrods 3/8" diameter, .120 wall thickness Melling high pressure oil pump Milodon stroker oil pan Cloyes timing set and cover Comp Cams special solid roller camshaft: Grind CS 4872S/4872S SR 113 230/230 degrees duration @ .050 lobe lift .369/.369 " Lobe separation 113 degrees Comp Cams 954-16 valve springs Comp Cams solid roller lifters Milodon Copper head gaskets (.050)/o-ringed block Edelbrock Pro XT intake manifold 90mm throttle body F.A.S.T. 96 lb/hr low impedance injectors running at 52 psi Electromotive ECM and distributorless ignition High volume mechanical water pump(would run electric but too much EMI) 7" crank pulley/5" water pump pulley 200 amp alternator Banks twin 76mm turbochargers twin 44mm wastegates Banks cast iron turbo exhaust manifolds dual 2.5" inlet, single 3" inch outlet intercooler The rest of the car: aluminum dual-pass radiator with dual 13" fans Godley TH 400 transmission and driveshaft 8" 3500 stall converter 4 link/coilover suspension Full frame and cage 9" Ford rear with 3.50 gears/spool 13X15X32" Mickey Thompson ET Streets Aeromotive Eliminator electric fuel pump Aeromotive electronic fuel pump controller Aeromotive boost-referenced fuel pressure regulator -12AN from tank through 100 micron filter to fuel pump -10AN from pump to fuel rails -8AN return line E-Boost2 electronic boost controller Cooling Mist Varicool alcohol injection system 3" downpipes into 3" dynomax straight-throughs And that is about all I can remember...) Wayne Quote Link to comment Share on other sites More sharing options...
Z-Gad Posted March 2, 2009 Share Posted March 2, 2009 Nice Wayne!! Gotta love it ... 3 LBS of boost!!! Quote Link to comment Share on other sites More sharing options...
rytherwr Posted March 2, 2009 Author Share Posted March 2, 2009 Thanks, ZGad...it's a shame I have to do all this just to try to keep up with you and your six cylinder....I feel embarrassed...) Wayne Quote Link to comment Share on other sites More sharing options...
JustinOlson Posted March 2, 2009 Share Posted March 2, 2009 Insane! Twin 76's? Should be good for 1500+ Quote Link to comment Share on other sites More sharing options...
rytherwr Posted March 2, 2009 Author Share Posted March 2, 2009 I believe you are right, Justin, however, trying to be conservative...this is a street-driven car, ya know.. Wayne Quote Link to comment Share on other sites More sharing options...
rytherwr Posted March 2, 2009 Author Share Posted March 2, 2009 Can't seem to post pics (JPEG) from any computer. did the rules change, site not working properly, or is it operator head space..? Can anybody shed some light? first time I have not been able to upload. Wayne Quote Link to comment Share on other sites More sharing options...
deja Posted March 2, 2009 Share Posted March 2, 2009 Something seems to be wrong. I tried uplaoding a photo and got: Warning: move_uploaded_file(../album.hybridz/uploads/13171/skirt-done1.jpg) [function.move-uploaded-file]: failed to open stream: Permission denied in /var/www/album.hybridz/image-inc.php on line 48 Plus most time the site is timing out making me hit refresh to get to any link. rytherwr said: Can't seem to post pics (JPEG) from any computer. did the rules change, site not working properly, or is it operator head space..? Can anybody shed some light? first time I have not been able to upload. Wayne Quote Link to comment Share on other sites More sharing options...
dr_hunt Posted March 2, 2009 Share Posted March 2, 2009 Not sure but SD said something about you having to let him drive your car or something like that. I'll check on it. Quote Link to comment Share on other sites More sharing options...
chevydoc Posted March 3, 2009 Share Posted March 3, 2009 Chevydoc...yes Can you walk me through what you did? Or post a picture. I have a rough idea of what I think will work but if something is tried and true that would be helpful. Thanks Doc Quote Link to comment Share on other sites More sharing options...
PanzerAce Posted March 3, 2009 Share Posted March 3, 2009 Jeebus Quote Link to comment Share on other sites More sharing options...
rytherwr Posted March 3, 2009 Author Share Posted March 3, 2009 Chevydoc, can't seem to post pics at this point, however, I back-halved the car, used two X two stock to replace the original and ran them from the back half and tied it in with the front frame rails as well as a roll cage. Wayne Quote Link to comment Share on other sites More sharing options...
chevydoc Posted March 4, 2009 Share Posted March 4, 2009 Cool thanks, I don't feel like an old moron now. I couldn't post picture either. Quote Link to comment Share on other sites More sharing options...
