TT 415 running and on the dyno
Got the hot rod running and sitting on the dyno...breaking in the engine, changing oil, fixing leaks, etc, etc...changed the oil and made a couple of 1/4 pulls just to put a load on it and was pleased with the results...537 lb ft of torque at 3400, 470 hp at 5300 at 3 lbs of boost. That is with really conservative timing and around 11:1 AFR. Once we get at it, ease the timing up and move the AFR closer to 12:1, I believe it will be where I want it. Built the engine to make the power at 6000 or a little less...so far, so good...:o) More when we get there.
Wayne
Wayne, I was reading the numbers you just posted and I thought, "Boy that looks strange: 537 lb ft of torque at 3400, 470 hp at 5300 at 3 lbs of boost..." But then I realized that this was only at 3 LBS OF BOOST!!!.
:2thumbs:
I'm really looking forward to the final dyno numbers on this engine. Great work, Wayne!! :D
Davy
Heck, Davy...that was just a stab-load and untuned to boot...
Dale...my hopefully not-so-dreamy goal is 750-800 hp and 950 lb ft of torque on 93 octane pump gas and alcohol running through the intercooler at 12-14 lbs of boost. On race gas, I am looking for 1100 to 1200 hp and around 1200 lb ft of torque at 17-20 lbs of boost. :o)
wayne
OMG!!! You are insane, I knew it now it has been confirmed. I can't wait for DNI.
wayne
Dale..as long as we're dreaming, might as well dream big, eh?
Chevydoc...yes
Doc, Specs to follow:
Engine:
415 SBC 3.875 stroke/4.125 Bore, 8.6:1 compression ratio
World Products Motown Block
4 bolt mains, O-ringed, splayed billet main caps, priority main oiling
Scat forged crank and H-beam 6" rods
JE custom turbo pistons, hellfire rings
AFR Eliminator Competition aluminum heads 227 cc, completely CNC machined
2.08/1.65 intake and exhaust valves
Jesel aluminum shaft rockers @ 1.65:1 rocker ratio
Manton custom length pushrods 3/8" diameter, .120 wall thickness
Melling high pressure oil pump
Milodon stroker oil pan
Cloyes timing set and cover
Comp Cams special solid roller camshaft:
Grind CS 4872S/4872S SR 113
230/230 degrees duration @ .050
lobe lift .369/.369 "
Lobe separation 113 degrees
Comp Cams 954-16 valve springs
Comp Cams solid roller lifters
Milodon Copper head gaskets (.050)/o-ringed block
Edelbrock Pro XT intake manifold
90mm throttle body
F.A.S.T. 96 lb/hr low impedance injectors running at 52 psi
Electromotive ECM and distributorless ignition
High volume mechanical water pump(would run electric but too much EMI)
7" crank pulley/5" water pump pulley
200 amp alternator
Banks twin 76mm turbochargers
twin 44mm wastegates
Banks cast iron turbo exhaust manifolds
dual 2.5" inlet, single 3" inch outlet intercooler
The rest of the car:
aluminum dual-pass radiator with dual 13" fans
Godley TH 400 transmission and driveshaft
8" 3500 stall converter
4 link/coilover suspension
Full frame and cage
9" Ford rear with 3.50 gears/spool
13X15X32" Mickey Thompson ET Streets
Aeromotive Eliminator electric fuel pump
Aeromotive electronic fuel pump controller
Aeromotive boost-referenced fuel pressure regulator
-12AN from tank through 100 micron filter to fuel pump
-10AN from pump to fuel rails
-8AN return line
E-Boost2 electronic boost controller
Cooling Mist Varicool alcohol injection system
3" downpipes into 3" dynomax straight-throughs
And that is about all I can remember...:o)
Wayne
Something seems to be wrong. I tried uplaoding a photo and got:
Warning: move_uploaded_file(../album.hybridz/uploads/13171/skirt-done1.jpg) [function.move-uploaded-file]: failed to open stream: Permission denied in /var/www/album.hybridz/image-inc.php on line 48
Plus most time the site is timing out making me hit refresh to get to any link.
Can't seem to post pics (JPEG) from any computer. did the rules change, site not working properly, or is it operator head space..? Can anybody shed some light? first time I have not been able to upload.
Wayne
Chevydoc, can't seem to post pics at this point, however, I back-halved the car, used two X two stock to replace the original and ran them from the back half and tied it in with the front frame rails as well as a roll cage.
Wayne
