Phillip Posted March 7, 2009 Share Posted March 7, 2009 Hey I couldn't find anything on swapping a 280zx NA Engine into a 280z, (probably because theres so much on the Turbo ones haha). My 280z's engine is knocking, so im trying to buy a 280zx for 350 bucks that the guy says has a good engine, Is my EFI wiring harness and computer from my 280z going to work with the 280zx NA? or am I going to need to use everything from the 280zx ? Thanks a bunch my 280z is a 1978 not sure what year the 280zx is though it is an NA though. Quote Link to comment Share on other sites More sharing options...
280zx 2by2 Posted March 8, 2009 Share Posted March 8, 2009 the ECUs are different so im going to have to say no, and there is that whole 280zx's have O2 sensors thing... you could just swap in the 280zx short block and attach all your other 280z goodies Quote Link to comment Share on other sites More sharing options...
Phillip Posted March 8, 2009 Author Share Posted March 8, 2009 Thanks, i'll be buying the parts car tomorrow if we can get it to turn over and engine runs good. it's been sitting for 4 years i think, my starter from my 280z should work with the engine right? Quote Link to comment Share on other sites More sharing options...
skib Posted March 8, 2009 Share Posted March 8, 2009 there both L28e motors and yes the starter will work. Quote Link to comment Share on other sites More sharing options...
hughdogz Posted March 8, 2009 Share Posted March 8, 2009 You might have an issue with the dropping resistors for the injectors. The earlier ECU's needed them, but the later ones do not. It will depend on the year of the ZX... [Edit: On second thought, it wouldn't matter as long as you're using the 280Z wiring and ECU] Quote Link to comment Share on other sites More sharing options...
zcrazy Posted March 11, 2009 Share Posted March 11, 2009 i used the ECU from my 77 for the 82 ZX motor i got... only thing i had to fix was the distributor connection.... but u should be fine with the 280Z ECU. Quote Link to comment Share on other sites More sharing options...
FlatBlack Posted March 11, 2009 Share Posted March 11, 2009 A Long Block L28 is a Long Block L28. You could even run a turbo motor in your car, the only difference between them on an N/A car would be compression. *edit* and distributors... Use the manifolds and sensors off of your 78 and you'll be fine. I'm running an F54/P79 out of a 1980 S130. Quote Link to comment Share on other sites More sharing options...
