Ruiz Racing Posted March 13, 2009 Share Posted March 13, 2009 i thought i blew the headgasket because my car was making the largest whit smoke cloud i have ever seen! but when i took off the head the headgasket was fine. moreover, there was at least 3 cups of pure antifreeze in my charge pipe and in my intake manifold. how is this even possible????? i looked for cracks but i found none. could it come threw my throttle body? Quote Link to comment Share on other sites More sharing options...
Pyro Posted March 13, 2009 Share Posted March 13, 2009 charge pipe? got a turbo? what is your setup (year, turbo, na, set?) Quote Link to comment Share on other sites More sharing options...
Ruiz Racing Posted March 13, 2009 Author Share Posted March 13, 2009 1981 280zx turbo. there was anti freeze between my turbo and throttle body. Quote Link to comment Share on other sites More sharing options...
FlatBlack Posted March 13, 2009 Share Posted March 13, 2009 Is everything stock or is there a different turbo? How many miles? Quote Link to comment Share on other sites More sharing options...
Ruiz Racing Posted March 13, 2009 Author Share Posted March 13, 2009 mostly stock. n-42 intake its been on there for a year. lots of miles. has all the stock vacum lines. Quote Link to comment Share on other sites More sharing options...
naviathan Posted March 13, 2009 Share Posted March 13, 2009 I believe there's a couple of heater blocks with coolant lines running to them on the intake. One should on the throttle body the other under the AAC Valve. Check those for leaks. Quote Link to comment Share on other sites More sharing options...
Ruiz Racing Posted March 13, 2009 Author Share Posted March 13, 2009 naviathan said: I believe there's a couple of heater blocks with coolant lines running to them on the intake. One should on the throttle body the other under the AAC Valve. Check those for leaks. has this ever happend to anyone? it has to be the aac or the the throttle body. but it very strange. Quote Link to comment Share on other sites More sharing options...
woldson Posted March 14, 2009 Share Posted March 14, 2009 This one makes me very curious. Quote Link to comment Share on other sites More sharing options...
jerryb Posted March 14, 2009 Share Posted March 14, 2009 Pure antifreeze? Is somebody yanking your chain? What happens if you remove it and run the car for a while. Does it return? Quote Link to comment Share on other sites More sharing options...
Swervey McZCar Posted March 14, 2009 Share Posted March 14, 2009 Do you have coolant/water in the oil? I am getting my head checked right now because of the same symptom (plus coolant in my oil). I suspect that coolant was entering my oil (however) and turning to steam when it mixed with the hot oil. The breather tube on top of the valve cover picks up the steam from the valvetrain and it enters the intake there. When it cools or hits air above normal atmospheric pressure it can become water/coolant again. It is the only explanation I could come up with. Now the bigger question is how did the coolant enter my and yours oil? How does your dipstick look? Milky? Over full? My car used quite a bit before I figured out that the cause wasn't my leaky heater bypass fitting. The oil level was still about right but it was nasty. Quote Link to comment Share on other sites More sharing options...
Ruiz Racing Posted March 15, 2009 Author Share Posted March 15, 2009 jerryb said: Pure antifreeze? Is somebody yanking your chain? What happens if you remove it and run the car for a while. Does it return? i am porting head right now so well see. i am the only person i let touch my car. and i don't think i am lying to myself. ok maybe, it is a 50/50 mix of water and coolent. no oil. at all. Quote Link to comment Share on other sites More sharing options...
scoutman75 Posted February 28, 2011 Share Posted February 28, 2011 had the same problem with my 83 turbo car the heater control valve had failed and was sucking water through the entire vaccum system Quote Link to comment Share on other sites More sharing options...
NicksT04=S30 Posted March 18, 2011 Share Posted March 18, 2011 i have a turbo throttle body off an 82 or 83 i think it has water in and out lines on the top of it and could those be your problem? Quote Link to comment Share on other sites More sharing options...
