dsalni Posted April 19, 2009 Share Posted April 19, 2009 hello hybridZ, long time reader first time poster in the tech section. i'm currently in the process of lowering my 280z using ground control coilovers w eibach springs and tokico illumina struts. for now, i'll be using the stock spring isolators. now i know that on a 280z the rear isolators are taller than the ones on 240z's, and front ones are the same. my question is, could i use an extra set of front isolators that i have, on the rear of my 280z in order to get some extra drop? i know there's a bearing in the front ones, so that would have to come out, but in theory, would that work? if anyone knows, please chime in. i searched for a bit, and didnt come up with anything that would answer my question. thanks in advance! Quote Link to comment Share on other sites More sharing options...
Administrators RTz Posted April 19, 2009 Administrators Share Posted April 19, 2009 I've done it. I don't recall any snafu's. The bearing should stay. Quote Link to comment Share on other sites More sharing options...
dsalni Posted April 19, 2009 Author Share Posted April 19, 2009 RTz said: I've done it. I don't recall any snafu's. The bearing should stay. even better. thanks a lot! Quote Link to comment Share on other sites More sharing options...
Kevin.pk Posted April 20, 2009 Share Posted April 20, 2009 I am using front isolators in the rear. They fit with no problem at all and gave me the stance that I wanted with Tokico springs. Unfortunately the front end sits slightly too high for my liking now. Heres a pic of how it sits now. Quote Link to comment Share on other sites More sharing options...
dsalni Posted April 21, 2009 Author Share Posted April 21, 2009 nice, thanks for the input! Quote Link to comment Share on other sites More sharing options...
h4nsm0l3m4n Posted April 21, 2009 Share Posted April 21, 2009 I'm planning on doing this in the next few days. In the stock 280z rear isolators there are rubber bushings instead of bearings. Are the front isolators different in a way that you have to use a bearing instead of the bushings? Quote Link to comment Share on other sites More sharing options...
JMortensen Posted April 21, 2009 Share Posted April 21, 2009 The front struts turn, the rears don't. Having the bearing in there won't make a difference. Quote Link to comment Share on other sites More sharing options...
GrayZee Posted April 23, 2009 Share Posted April 23, 2009 So is there a way to use Eibach springs on a 280z AND still have the proper ride height? I would love to know as I have a set of Eibach's still in the box but they won't work on my 280z Quote Link to comment Share on other sites More sharing options...
