Which Injectors?
jayzrocket
I need a little direction pleeze.
I have a mostlty stock zxt w/ a few minor mods. Fresh T-3, 10lb cotroller,
Blitz bov from 180sx, decent intake w/ 60mm tb, adjustable fpr, and just purchased an 11mm o-ring fuel rail. I was wondering if anyone here has any suggestions for which injectors to use w/ the factory ecu? The gentelman that I bought the rail from said that the yellow top supras would be fine, but I remeber reading in the fuel injector upgrade opions tread that to steer clear of them because of the cc rating. Maybe these would be ok with the fact ecu. And shouldn't I stick w/ low impedence? And are the yellows Hi or Low's?
Thanks in advance,
J.
You could try running some Mitsubishi Eclipse injectors, RX-7 or some of the Supra injectors. Here is some info for you:
Eclipse injectors:
Non-Turbo 1.8L - N210H Injectors-casting #INP-057 (210cc High Impedance)
Non-Turbo 4G63 - N240H Injectors-casting #INP-059 (240cc High Impedance)
Turbo 4G63 A/T - B390L Injectors-casting #INP-008 (390cc Low Impedance)
Turbo 4G63 M/T - B450L Injectors-casting #INP-009 (450cc Low Impedance)
2G Turbo BlackTops -MDL450 casting #IPN-081 (450cc Low Impedance)
2.4 - MDH275-casting #IPN-065 (275cc High Impedance)
http://www.lextreme.com/rx7injectors.html - RX-7 injectors info
This page has some good injector info, all these are sold as reconditioned and he sells some Z stuff specifically:
http://osidetiger.com/reconditionedinjectors.aspx
If your ecu runs low impedance injectors, you can use high imp. injectors with a low imp. ecu, you cannot use low impedance with high imp. ecu, unless you use drop resisters.
Im running ford probe injectors(324cc high impedance), on my low impedance z31 ecu.
single cam 240sx injectors are 260cc and o ring, stock l28et injectors are 270cc, if you want to stay relatively stock, to keep from tuning.
  • 7 months later...
Backing up the truck here...really? Can anyone else confirm this?
If so, I would reckon the Eclipse 210cc injectors will work for my stock L28..
