S-30 Door Interchange
I did a search on this but didn't come up with anything.
Does anyone know if there is a difference in S-30 Doors from 70 -78 other than the inside door lock? Are the two big hinges and bolt patterns the same? I have a 76 280 with beatup bondo doors and want to replace them with some good clean doors off a 1974 240.
  • Administrators
As I understand it, the '70-'76 doors will interchange. Minor differences internally on how the window and latch stuff functions, but nothing that affects the physical use of those doors on other cars within that year spread. Keep in mind, the newer the door, the heavier it will be due to increasing side crash protection measure being employed.
Now the in ’77 Nissan made a significant change to the doors internally and in the striker. This carried through to the ’78, both ’77 and ’78 doors are exactly the same and only interchangeable between these two years. Internally was major redesign as well with a whole new window regulator, that is much smoother less prone to hanging up, (at the expense of added weight), a whole new latch system that is harder to “slim-jim” and will allow you to lock the door prior to shutting it, (requires holding up the door handles while closing the door). The ’77-’78 interior door panels are only interchangeable between the ’77-’78 doors as the window crank handle AND the door lock knob were moved to different location, i.e. holes for such moved significantly.
I've got an very early '70 parts car, couple other 240-'s, a 75, '76 and two '77's. I'll go out and take some pics of the hinges and latches for you.
  • Administrators
Got some pics for ya.
The orange one is the early series one 1970 240-Z VIN 2848
The white car is a ’75 which has the same door as the ’76.
The pinkish/Maroon car is a ’77.
Hinges for all doors appear to be the same in the same locations.
Body Strikers. Orange = ’70. White = ’75, Maroon = ‘77
Door Strikers. Orange = ’70. White = ’75, Maroon = ‘77
’77 door with panel removed. Note the 4 MAGENTA circles. That is the ’77-’78 window track adjusters. The MAGENTA Arrow on the window crank points to the early crank location, pre’77. The GREEN circle shows one of many new lock revisions and the GREEN arrow points to the earlier door lock location.
Hope this helps,
Paul
  • Like 1
Not only that, but the actual frame in the chassis is slightly different. Meaning the door won't seal properly if you manage to fit one door a non fitting chassis.
The hinges will fit without any problems, and you can even get the to "fit" along the body lines.
My first Z had a 75 door on a 78 chassis, pretty much is the cause of my floors disappearing before the previous owner gave it to me :P
wow... you learn something new everyday. Thanks for that tid bit of info.:icon14:
Now I can stop locking it with the key. I fell dumb for not knowing about that. haha
Geez, and here I was planning on swapping a set of '77 doors onto my '76 with a slight modification to the striker pin on the body. Since my driver's door just won't close unless you slam it hard.
Do a search, this issue of slamming to close has been previosly addressed before, and fixed.
that part of my door must be broken, because I just lock my door and shut it
Mine works that way depending on how hard I shut it. If I shut it very gently the door lock knob doesn't pop up all the way and the door remains either locked or it pops just enough that if someone jiggled the handle it would open. If I close the door hard it pops all the way unlocked. It's really just hit or miss because of worn/misaligned parts I'm sure.
Now, I know I can hold the handle up and close it and be sure the door is locked and secured.
Yea I removed the door panel already from examination the knob on top and the key cylinder works fine just that doesnt work properly. At the moment I'm trying to remove the metal trim around the window so I can gain access to the lock mechanism but one of screws broke inside the thread hole :/
for me then, it could be that because my door seal is uhh...worn/gone, I hardly have to push the door to get them to shut. it's nice, and the car doesn't leak (get ssome wind noise when I have the windows up)
so I guess I'm not too worried about it lol
  • 8 months later...
I want to add some information. The 70-73 interior panels and armrests do NOT interchange with a early 260Z door. The 240Z had a 2 piece pull and armrest deal. The 260Z and up went to a 1 piece unit. There are many differences on the steel stamping on the steel door frame. I am pretty sure but not positive that the 74.5 260 and 75- 8/76 doors and interior stuff are the same as the early 260Z door. If one is looking for complete compatibility then this means that 240Z owners would want to stay with 240Z doors and 260Z owners should look for early 260Z ( and possibly the 74.5 - 8/76) doors. (Still hunting for that elusive early perfect 260Z door)
If you want to hammer/ weld / raise some metal on the door frame in order to install interior panels and arm rest, you could probably make the switch. If you dont care about interior panels or are going to do some modifications - please ignore this. I will post some pictures after the Feb 20 switch in BB providers.
This is an interesting topic for those of us that were fortunate enough to wind up with the 74s.
I've located an early 74 with a good set of doors complete with regulators and glass.
I'll be able to inform as to the fit on my late 74 soon.
