Modified l28et manifold
wax
Ok well i have been looking around and to be honest none of those manifolds i see out seem to have much put in in the way of thought
And they are down right ugly if you ask me
So here is my take on the manifold situation
Its just starting out so easy on me
As you know or should know the general of thumb is plenum at 1.5 time engine capacity
So 2.8 = 4.2 on the plenum
Well we all know the std one is unlikely to be even 2.8 litres
So its out with the alloy cutoff wheel
and here we go
Thanks
just working on throttle bodies at the moment
Im looking for about a 65-70mm
I will just get the manifold sorted before i buy one
Tomorrow its in the runners with a die grinder getting there flow up
Just bring out the runners 3mm in diameter will bring up the area by 20% as well the cleaning up is going to help the flow alot as well
Not sure how much i can enlarge them but have een porting it this morning and i agree with you, the 1 and 2 runners are badly obstructed.
BY widening the front of the plenum i am hoping to get a much better approach on them.
Because my manifold started of as an egr manifold it has a nasty kick on the bottom of the runners.
I spent alot of time there getting rid of that.
Yeah thats what u have in mind,to come in it on an angle.
Im just making the top and the bottom at the moment and then i will band saw the front flat and at an angle with a plate on it to bolt a throttle body too.
Yeah i can clearly seem some differences.
I think its a very simillar casting with some added holes for the pressure relief valve etc
Like my one thats an egr intake , a pain really as you have to grind it all off
If you go to a hardware shop you can buy wheels for your grinder that cut alloy and man do they cut alloy
I was going to take some more pics but i havent finished the porting so i will wait until then to put some more pics up
On a side note buffing compound for an buffer makes a great thing to stop the cutting tip from clogging
Ok well got in there with the porting tools
when i started i couldnt fit a 32mm ball bearing down there now i can roll a 35mm one straight down there
I also cleaned out the short turn alot so that its a more direct flow
Im very happy with the result
the pictures dont show it as well as it should, but you get the idea
I have started to clean up around the outside of the manifold , the casting marks will all come off then i will take it down and get it sandblasted to give it that sand cast look again. My goal is to make it look like an aftermarket manifold and not a hand fab job
