Spark from coil, nothing past dizzy on MSI V3 Extra
FlatBlack
I posted this on MSExtra, needing some help getting my 78 280Z Turbo swap to run. I got my map from mikeatrpi, he is running a modified VR dizzy off his N/A motor.
Here is the map I am running:
http://forums.hybridz.org/showpost.php?p=1044528&postcount=112
After hooking up the IGBT circuit according to the DIYAutotune writeup:
http://www.diyautotune.com/tech_articles/how_to_megasquirt_your_280zx_turbo.htm
I am getting RPM in Megatune, when the car is cranking over, and with the stim board.
The dizzy is hooked up to the relay board according to the DIYAT diagram.
The D2 diode was wired in backwards by the previous owner, so I jumpered it as the megamanual suggested:
# For most installations, diode D2 {1N4001DICT-ND, the marked 1N4001} is not needed. Do not install D2, install a jumper (made from a snipped off lead) in its place. It is located beside D1, closer to the heat sink.
Note: this diode (D2) is needed only if the ignition system has a large offset bias - most systems do not have such a bias. So, to start, you can either solder in a jumper wire in this location, or, you can install the diode D2, and then install a jumper around the two leads of the diode - in effect shorting it out. The latter will allow you to snip the jumper later on if needed, putting the diode back in circuit. Solder the diode in observing the banded end as on the board, then solder a wire jumper across the diode itself.
When the wire from the coil to the distributor is taken off and 'jumped' to metal on the car or a spark plug is hooked up, it will fire, but seems to be 'weak' spark.
I bought a brand new cap and rotor for my distributor, and after trying to get it to fire today we took the cap back off and there are no 'fire' marks on the points or the rotor.
When cranking the car, no spark is getting to the plugs when the plugs are out of the motor.
I'm not sure if the problem is in the wiring in the board or the wiring harness [not getting enough power or something like that], or wrong settings of my msq.
Any advice for me?
This is a MS1 V3.0 Extra Code board with the IGBT circuit wired up to trigger spark, I'm using the 029y4 Version of MegaTune, when I go to the configuration setting and select "extra.ini" it says the code is 029y3.
  • Replies 57
I recall that it was blinking, Trumpet says he can't remember if it was a solid light or if it was blinking. I'll go check it out after work.
I lined up the dizzy shaft notch with the oil shaft notch according to the "How to rebuild your Nissan OHC motor" book, but I wonder if there is a possibility that the rotor is off so much that it can't spark to the point on the cap.
I made it out to the shop last night. I had to reset the dizzy shaft. It is now facing in the proper direction.
I had other people tell me that there was no spark hitting the spark plug wires, but I never confirmed this. There is now spark getting to the plugs. I had an extra plug hooked up to cyl 1 and cyl 6 wires and they were both sparking.
I could have sworn that I heard it fire in two cylinders the first time I tried to crank it, but I didn't smell any exhaust gas [open DP currently] and it could have all been in my head.
I ran down my battery again trying to adjust random settings and get it to start. Never did get it to run though. I need someone out there to help me, hopefully I can get Chris out there later this week.
I guess it's all an issue of timing now, so I'm going to have someone physically rotate the dizzy head around while trying to crank it, hopefully that will help?
There are two possible ways that you can mount the distributor, I didn't see a directional key. I'll try to find a picture of a stock setup. I wonder if I have the dizzy head mounted 180* off. The motor was on TDC compression stroke when I reset the dizzy shaft, so that should be good.
The LED was flashing the whole time I was cranking it, and I saw the spark from the plug wires.
Chris suggested I might have "weak" spark, could this be a possibility?
Thanks for the input.
Mat, were you able to:
1) Put cylinder #1 to TDC and verify rotor position and wire connections - firing order - on the cap?
2) Set the correct trigger angle in megatune? Pull the fuel pump fuse and crank the engine while watching for 10 degrees fixed angle with a timing light?
So, went out to the shop with my roommate tonight. Nothing changed, but somehow the Z gods are not looking on me kindly. I once again have no spark past the coil wire.
It sparks with a purplish flame when I put a spark plug on it, but once again nothing at the cylinders.
Can anyone help me? I am not to the point of moving on to HEI or EDIS yet. I want to make this work.
I have a Z31 turbo dizzy available if that matters. I saw a Big Phil video and he swapped the internals into the 83 dizzy housing. I'm not sure if that will help though.
I get a RPM reading in MegaTune, and spark off the coil.
I can't figure out if this is a mechanical issue or MegaSquirt issue.
Why won't this work??? Can someone give me a MSQ running an 83 Dizzy on MSI V3 Extra?
Do I have my wiring harness hooked up wrong? If so, how am I getting RPM in MegaTune?
I tried uploading the data logs and it won't let me...
Mat - Were you able to set the trigger angle, per our google chat yesterday?
I'm going to guess "no" because its not sparking to the cylinders. Maybe you can play with the numbers anyway and see if it helps?
Also - what color is the coil wire spark to a ground point?
Edited by mikeatrpi
whups
I'm pretty sure it's mechanical at this point. The ECU is working, the coil is sparking, but the spark isn't getting through the distributor. I would suspect either your timing or the rotor phasing is off.
That's what I was thinking, I'm not sure what I need to do at this point though. I have already re-set the dizzy to TDC. Is there no adjustment in MS I can make for it being out of place?
I was thinking if I rotate the dizzy housing it should spark to a cylinder at least. The rotor arm is pretty big. I tried it yesterday and got nothing.
Yeah, no spark on Cyl 1 so no timing :/ Thanks for your help though. I will do it once it idles. If it ever does. I didn't see what colour the spark was to the body, I could check when I go out tomorrow.
http://forums.hybridz.org/showthread.php?t=107106&page=2
Mat, not sure if that link will help any but it seems (at least from my reading) that he had the same problem as you and is now running it w/o the GM HEI. Hope that helps, still new at this MS stuff.
Thanks for the link, Deric. Good read.
Would anyone suggest just moving on to HEI or EDIS? It's not really in the budget right now, but I can make it happen if it needs to. More work less sleep :) [until school starts at least].
Thanks for all of your help guys, the Z has been down for a month now :(
Your coil won't spark further than 1mm.
Your coil worked perfectly on James' car.
We've triple checked your wiring.
We've looked over the circuits on the board, everything checks out to the best of our abilities
You've tweaked every setting in Megatune
... The HEI module is $15 and AZ has a return policy.
I don't know why we're still talking about this :D
