HeatRaveR Posted July 30, 2009 Share Posted July 30, 2009 Ugh, I can't stand people who toss gum on the ground when there's a #@% garbage can right there! So as a result, I unknowingly stepped in some gum and got in the passenger side for a road trip, the whole time, embedding the gum in the floormat. I got out what I could with a napkin, but what's the procedure for removing gum from carpeting? Oil? Degreaser? I've read that chocolate or peanut butter can break gum apart, but that sort of seems like I'll then have a different gunk embedded in the carpet instead. Quote Link to comment Share on other sites More sharing options...
kiwi303 Posted July 30, 2009 Share Posted July 30, 2009 It's not the peanut butter itself you need, but the peanut butter oil that seeps out of some brands of PB. The PB Oil is a very penetrative oil and gets through and makes the gun unstick. then shampoo the PB oil stain out. Personally, I'd just look up your local Kirby dealer/distributor in the phone book and get a spray bottle of either the citrus cleaner or the food stain remover, both do an excellent job on gum, even old gum thats been trodden in for years. Quote Link to comment Share on other sites More sharing options...
jyz77 Posted July 31, 2009 Share Posted July 31, 2009 zippo lighter fluid ! also wd40 always worked for me . Quote Link to comment Share on other sites More sharing options...
srbigbutt Posted July 31, 2009 Share Posted July 31, 2009 I remember freezing some gum off using a dust can upside down! Quote Link to comment Share on other sites More sharing options...
big-phil Posted July 31, 2009 Share Posted July 31, 2009 yes freeze it Quote Link to comment Share on other sites More sharing options...
forchunet Posted July 31, 2009 Share Posted July 31, 2009 omg I don't know anything about no gum on carpets but dang phil that color is niice! Quote Link to comment Share on other sites More sharing options...
78nismoZ Posted July 31, 2009 Share Posted July 31, 2009 I also agree with the freezing it, but I have heard about the peanut butter as well.... Quote Link to comment Share on other sites More sharing options...
HeatRaveR Posted July 31, 2009 Author Share Posted July 31, 2009 Do you guys think adhesive remover might work? Quote Link to comment Share on other sites More sharing options...
78nismoZ Posted August 1, 2009 Share Posted August 1, 2009 When you mentioned adhesive remover, I think goo-gone. I actually think goo-gone might actually work I have used it a bunch on many different things...Just test in an inconspicuous area Quote Link to comment Share on other sites More sharing options...
Supra510 Posted August 1, 2009 Share Posted August 1, 2009 Goof Off http://www.goof-off.com/ It got gum out of clothes that had gone thru a complete drier cycle so it should work for this. You can get if pretty much anywhere. Quote Link to comment Share on other sites More sharing options...
heavy85 Posted August 2, 2009 Share Posted August 2, 2009 Scissors, knife, random sharp object ... jigsaw, cut-off wheel ... I could go on the possibilities are endless although a 'carpet' knife seems to most appropriate. Cameron Quote Link to comment Share on other sites More sharing options...
HeatRaveR Posted August 2, 2009 Author Share Posted August 2, 2009 Welp, looks like the adhesive remover worked! Just a few drops on and then just quickly "grabbed" repeatedly at the gum till it came out. ^__^ Thanks for the feedback guys. Quote Link to comment Share on other sites More sharing options...
srbigbutt Posted August 2, 2009 Share Posted August 2, 2009 How hard is it to not think about where that gum has been and not be totally grossed out!! Quote Link to comment Share on other sites More sharing options...
starfishdata Posted August 5, 2009 Share Posted August 5, 2009 Just a little note for those who smoke or someone else has burned a hole in your carpet. Or if you accidently rip out a little tuft of carpet while removing your girfriends favorite hard candy:frown: Cut a tuft from a non visible spot, like under the door sil, and roll it into a ball and stick it to the spot with a few drops of super glue. Then take a sharp pair of sisors and trim it flat with the surrounding area and volia no more hole. Work wonders and id give to credit to the site where i learned it but it was a few years back. Quote Link to comment Share on other sites More sharing options...
78nismoZ Posted August 7, 2009 Share Posted August 7, 2009 Glad to hear that it worked for you. Quote Link to comment Share on other sites More sharing options...
