4 Lug to 5 Lug bolt-on adapter
There has been many discussions here about using those. I had them on my stroker L6, and my rb26ttz without any side affects.
The only problem I had with them is the large black allen head steel bolts froze up in the alum threaded area. I'd be sure to use a thread anti seize if I were to use them again...
I have also used them with no negative effects - The flathead bolts' allen heads tend to strip easily, however ... and I definitely second Joel's recommendation to use anti-seize.
FYI: I have 4 of these that I intend to put up for sale...
So with these conversions hubs how much would it mess with your offsets?
I believe these act the same way as wheel spacers, that is they will effectively subtract wheel offset. So if your wheel is +30mm offset and your adapter/spacer thing is 30mm thick you are running a 0 offset wheel, a 0 offset wheel would be -30mm with the same adapter, etc.
