jkgts1 Posted August 26, 2009 Share Posted August 26, 2009 So this was my first attempt at making one of these. I am not building this for any particular sanctioning race. Well I welded in the diagonal bar to the main hoop, then noticed how far away it was from the corner at the top. I got a bit carried away didn't realize it at the time. Do you guys think that I should cut it out and put in another one with the top part of the bar closer to the bend? This is 1.5", .120 wall 4130 tube by the way, if it will help with the decision. Thanks Quote Link to comment Share on other sites More sharing options...
jkgts1 Posted August 26, 2009 Author Share Posted August 26, 2009 Anyone? Quote Link to comment Share on other sites More sharing options...
johnc Posted August 26, 2009 Share Posted August 26, 2009 For a roll bar you're probably OK. But, if it bugs you now, its going to bug you a lot more two years from now. Quote Link to comment Share on other sites More sharing options...
jkgts1 Posted August 26, 2009 Author Share Posted August 26, 2009 That is what I figured. I was thinking "if I have to ask, I better just change it." Thanks Quote Link to comment Share on other sites More sharing options...
JMortensen Posted August 27, 2009 Share Posted August 27, 2009 Don't put it right in the corner either. That works great for a sedan, but in a Z you'll need some space for the seat to scoot back in between the diag and the side of the hoop, assuming you're say 5'10" or taller... Quote Link to comment Share on other sites More sharing options...
Nelsonian Posted August 27, 2009 Share Posted August 27, 2009 JKGTS1, What is the plans with the tubing in the engine bay? any more shots of that? Quote Link to comment Share on other sites More sharing options...
jkgts1 Posted August 27, 2009 Author Share Posted August 27, 2009 Don't put it right in the corner either. That works great for a sedan, but in a Z you'll need some space for the seat to scoot back in between the diag and the side of the hoop, assuming you're say 5'10" or taller... Yeah, I'm just going to move it in a few inches more. As far as being 5'10" or taller, that is where I am lucky, I'm only about 5' 6". One of the only times I'm glad i'm short. Nelson, As far as the tubing in the engine bay goes, nothing permanent yet, but it's nothing you haven't seen before. A lot of people have done great stuff with tubing, like Jon. Quote Link to comment Share on other sites More sharing options...
TheBandit Posted August 27, 2009 Share Posted August 27, 2009 I would definitely move it. It's worth the time to cut it out, otherwise it will bug you forever. If you can get the hoop out of the car, it will be a lot easier to cut & cleanup the area where you currently have it welded. Quote Link to comment Share on other sites More sharing options...
jkgts1 Posted August 27, 2009 Author Share Posted August 27, 2009 I would definitely move it. It's worth the time to cut it out, otherwise it will bug you forever. If you can get the hoop out of the car, it will be a lot easier to cut & cleanup the area where you currently have it welded. Yeah, I finished cutting it out last night. I haven't welded the hoop to the car yet so taking it out was no problem. Quote Link to comment Share on other sites More sharing options...
