$400 for an L28ET?
Cutlass372
Hey, Local to me there is an 83 280zx turbo in a junkyard with a running motor. I have been talking with the guy and he said he got it running today and had it running for 1/2 an hour. He said he would work with me on the other things I would need for the swap into my 72 240z. Does this seem like a good deal? The yard is only 10-15 mins from my house, I don't think I could find a better deal then this locally. He also said he has a 76 280z, does the gas tank from that work with the swap I need?
Thanks for any help, Elliot.
EVERYTHING (turbo, manifold, injectors, J-pipe, etc.) on the motor? Hopefully that includes the wiring the FI wiring harness, coil and ignitor, ECU. You will also want the Fuel pump.
You will have the P90A hydrolic lifter head.
Please stop the misinformation. Not all P90A heads are hydraulic.
some of the early P90A heads are solid, the rest (and most common) are hydraulic.
I don't think the tank will fit in a 72.
ya ZX tank woulnt fit
grab a 75-76 tank
Should I get it though? $400 for the WHOLE motor? I just don't know about the other parts, but i wouldn't expect a lot for money. I will have to figure that out.
your going to want a baffled tank for the EFI, so yes.
if its $400 for the motor and everything on it, the ECU and wiring, and the bits you need to do the swap than yes, its worth it.
If it is an 83 as he stated, it is a hydraulic.
Late 82 they started switching over, however, some 82 P90A heads are solid even though they say P90A. I do believe this is only for 82 though.
well, if you pull the harness and ECU out and feed it through the dash, it is attached to the engine. Id try to get him to throw everything in for $400.
USUALLY, at U pull it type yards, they will sell you everything, valve cover to oil pan, including the harness and ECU for their "complete engine" price. at least the U pull it yards I go to they do.
ya thats how I got mine, about $300
YES, GET IT!
That is a great deal as long as there are no obvious knocks, leaks, smoking or low compression on the motor. A steady idle, and smooth revving would be nice too, but those just might be old electronics problems. Make sure that YOU see and hear it running before handing over the cash.
If he is going to help you find what else you need for the swap, that'll be great too.
I would say, unless you have a place to keep the car and have a plan in mind for specific parts in the car, don't worry about offering to buy the whole car. Having another car around can be more trouble than it's worth sometimes (not always).
Hydraulic head is ok - doesn't have to be adjusted :-). Tell him everything you will need (harness, ECU, fuel pump and whatever else) and see what he says about the price.
