-6 or -8 fuel lines?
ruggedbert
What model year car? As stated 5/16th are fine for any power application, it depends on whether or not your pump can pump the required flow at the pressure necessary for your power goals. Many people are running stock 240z lines and pushing 350 hp; others stock 280z lines at over 400 hp. There was a great thread on this subject not too long ago.
The old sizing rules of thumb have more to do with low pressure, high flow carb pumps than EFI setups.
I am personally running -6 feed and return without issue.
My fuel system runs at almost 60psi and I'm running -10 supply to pump -8 to FPR -8 to rail and -6 return. This is for my LS1 and am running an aeromotive A1000 pump. I went over kill but I also probably will be swaping to a 400+ci motor while being FI'd.
